• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Content aware fill doesn't fill entire selection.
Explorer ,
Nov 14, 2017 Nov 14, 2017
I use content aware fill a lot. In CS 5 there was no problem.
I recently upgraded to CC 2018. Unfortunately CAF doesn't fill entire selection.
I can't find any solution.
See picture before CAF en after CAF.
Views
762
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
Hi
I tried with your image and did not get as bad a result - although the hair crept into the fill so:
1. Start with a selection around the top - missing the person and copy that to a new layer (Ctrl+J)
2. On the new layer - select the triangles leaving some overlap
3. Shift +F5 and choose content aware
4. Ctrl+D to deselect (and in my example, then turn back on the original layer)
Dave
Votes
Translate
Translate
Report
Report
Explorer ,
I tried this, but no better result.
In CS5 I just had to select the white parts and CAF and done.
Quick and easy.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Hi TomWeyts,
Either of these options may not work, although I wanted to chip in to see if I could help in any way.
My first suggestions which I am fairly sure you will have already tried is to select a much larger selection, although if this doesn't work do the complete reverse and make smaller selections at a time then content-aware fill that way. This way will obviously take much longer, although the desired effect may look much better.
If you decide to content-aware fill in much smaller areas, I would suggest duplicating your layer then creating a mask and painting out all of the areas you don't want to be seen in your content aware such as skin and hair tones.
I hope this helps in some way, any questions I'll hope to respond ASAP.
Cheers,Alex
Votes
Translate
Translate
Report
Report
Explorer ,
Also tried smaller selections. Same problem.
Quick and easy.
Votes
Translate
Translate
Report
Report
Explorer ,
I have the feeling it's some kind of preference...
Votes
Translate
Translate
Report
Report
Community Expert ,
You can try resetting your preferences (Preferences >General> Reset Preferences on quit then close and restart Photoshop)
Also, if you have not already done so , try updating to todays released update to CC2018. I have not seen your issue in v19.0, but if you are going to reset things , you may as well upgrade and be rid of other known bugs.
Dave
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 15, 2017 Nov 15, 2017
Resetting the preferences seems to have done the trick.
But know we don't know what caused the issue. But it works again as it should.
So thank you guys for helping out.
I will do some more tests to see if it's completely solved.
Votes
Translate
Translate
Report
Report
Explorer ,
Strange things happening. I did some tests.
1. I opened a picture rotate it, enlarge canvas. I get white areas. I select the white areas and CAF and it works like it should.
2. I open the same original picture rotate it, enlarge canvas, select an oval shape, make a path.
Again I select the white areas and CAF the white areas and it does the same thing like the picture above (first post)??? CAF doesn't fill entire selection.
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 16, 2017 Nov 16, 2017
I deleted all my oval selection tool presets and made new ones.
This didn't solve my problem.
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
If I make the background layer into a normal layer (in this case the white areas are transparent) the CAF works as it should.
It's kind of an solution for me, but I still wonder why it doesn't work as it should.
Votes
Translate
Translate
Report
Report
Hey TomWeyts,
If you message me on my Adobe profile through the messenger, we can arrange for you to send me your project file over WeTransfer and I can check if this issue is equally the same on mine.
Cheers,
Alex
Votes
Translate
Translate
Report
Report
