3 Replies Latest reply on Nov 14, 2017 10:43 PM by kautuksahni
    issue with cq.jquery clientlib
    snehag07
      I am using cq.jquery clientlib . but it always shows following error on page load.
      following are contents of http://localhost:4503/etc/clientlibs/foundation/jquery.js
      Can anyone help here?
        • 1. Re: issue with cq.jquery clientlib
          smacdonald2008 Adobe Employee
          How are you using it - what syntax are you using.,
          • 2. Re: issue with cq.jquery clientlib
            If you are having issues - try on a fresh AEM install and see if you are still getting the same error - this will tell us:
            1 - if it does not work on a fresh install - you are doing something wrong in the syntax
            2 - it works on a fresh install - which means there is something wrong with your instance,
            • 3. Re: issue with cq.jquery clientlib
              kautuksahni Adobe Employee
              Please have a look at the documentation:- Using Client-Side Libraries
              Using JSP [Using Client-Side Libraries ]
              Add a ui:includeClientLib tag to your JSP code to add a link to client libraries in the generated HTML page. To reference the libraries, you use the value of the categories property of the ui:includeClientLib node.
              1
              2
              <%@taglib prefix="ui" uri="http://www.adobe.com/taglibs/granite/ui/1.0" %>
              <ui:includeClientLib categories="<%= categories %>" />
              For example, the /etc/clientlibs/foundation/jquery node is of type cq:ClientLibraryFolder with a categories property of value cq.jquery. The following code in a JSP file references the libraries:
              1
              <ui:includeClientLib categories="cq.jquery"/>
              The generated HTML page contains the following code:
              1
              <script type="text/javascript" src="/etc/clientlibs/foundation/jquery.js"></script>
              Using HTL [HTL and ClientLibs ]
              Calling Client Libraries from HTL
              Because HTL is meant to be a general language, without specific AEM features, there is no data-sly-clientlibs feature for instance.
              The best example is from the new foundation page component, this is located at /libs/wcm/foundation/components/page/head.html.
              There, you see the following thing:
                   data-sly-use.clientlib="/libs/granite/sightly/templates/clientlib.html"
              This declares a “clientlib” object, which is implemented as a template.
              After that, you see statements like following one:
                   data-sly-call="${clientlib.all @ categories='cq.jquery'}"
