In Acrobat Pro DC, I do not have the option for duplex printing on my mac. Any suggestions? When I print from a browser, it works just fine.
Mike
The problem with this are the printer drivers who do not tell the OS that they can do duplex. That way Acrobat can not use that parameter in it's dialogue.
Hi Mike,
As mentioned, you are not getting an option for duplex printing on Mac, could you try clicking "Multiple" under print dialogue box and see if print on both sides of paper option is visible:
Below is the screenshot:
Let us know how it goes.
Shivam
I have the exact same problem.
iMac:
Model Name: iMac
Model Identifier: iMac14,2
Processor Name: Intel Core i7
Processor Speed: 3.5 GHz
System Version: macOS 10.12.6 (16G1036)
Acrobat Reader DC
Architecture: x86_64
Build: 18.9.20044.251705
AGM: 4.30.72
CoolType: 5.14.5
JP2K: 1.2.2.39492
This page implies all should be well, but it is not.
Here is my view of the Print > File form. No duplex option.
When I choose "Multiple", I don't see any improvement.
I managed to work around the problem.
Easy? Sort of
Intuitive? Not at all. I wasted time, ink and brain power to work this out.
Here we go, step by step. Note the choice of "reverse pages" - for some reason Adobe sent the pages in the wrong order as far as my printer is concerned. If Iwere printing one page per side, it probably wouldn't matter.
I am only interested to use Adobe Reader because Preview has developed a knack of crashing whenever I use my printer setup of colour, duplex, two pages per side. I like duplex, two per side as it saves trees and ink.
I also wanted to try a different, paper and ink-saving approach. Namely, to use the print dialogue to save the output as a PDF. The Adobe engineers were one step ahead of there though, in that I get the message that "Preview is not supported". Take that potential paying customer!
In summary, the trick seems to be to set up Reader DC's File > Print... dialogue to send the pages one at a time to the printer, then use the Printer... button to configure the printer to dump them to paper. But beware! The final twist is DC Reader sends the pages to the printer in the wrong order. It shouldn't matter if you only want one page of document per side of printer. But in my hippy, tree-hugging, miser mode of duplex (where the problem started) and two pages per side, I wasted paper and ink.
Open File > Print... and choose the pages to print. Remember that page 1 of the page the printer sees is the first page of the range you want to send to the printer, not page 1 of the document. Click Printer... | Click Yes in this useless dialogue box (or get rid of it by checking the "do not show..." box first). |
Now you are greeted by your printer's driver dialogue. Set it up as you require, then click Print | Finally click Print again, cross your fingers and sit back. |
I can only print two-sided in Adobe, so I have the opposite problem.
THIS IS NOT A PRINTER ISSUE; it's an Adobe-Mac interface issue. See the printer dialog screenshot below. Clearly two-sided is turned off, but it makes no difference.
After wasting so much time I finally was able to print from Preview.
Stop trying to pass the buck Adobe.
Her
I too had been unable to NOT print double-sided and resorted to printing PDFs through Preview. However, yesterday, just for yucks, I printed a two-page doc through Acrobat. The second page of the doc was one of those three-word spillovers from the first page and it didn't matter if it printed two-sided. Lo and behold the two pages printed separately! I'd done absolutely nothing to affect this change in functioning.
So...I dunno. Whose fault could it be but the print driver gods?
First I'm not Adobe, second the program is called Acrobat not Adobe and third Preview has other issues as it implements only a subset of the PDF format.
Hi Best Of Bodmin
Thank you thank you thank you.
After wasting time searching the forums trying to print duplex on a screen that did not show that option, your post was simple & straight to the point.
Thanks so much for making this headache go away with your post.
Really appreciate your simple solution to a problem that was driving me crazy.
There is no reason to do a convoluted work around. How awful. I had the same problem printing from my new-to-me laptop to my Brother printer. I solved the problem by going into the device properties and making one change. Now it shows the option to print two sided and flip on long or short edge. Note: I am working on a Windows 10 laptop and my printer is a Brother HL-L2315DW.
In the search box of Windows type "Printers" and select Printers & Scanners system settings.
Select the correct printer and "Manage"
Select Printer properties and look in the Features box. If it says Double-sided: No you need to fix that.
Select Device Settings, and under Installable Options, look for Duplex unit and change to Installed (mine said Uninstalled)
Apply
After that, the option to print duplex is now available from every application, not just Adobe Acrobat.
Best wishes. Hope this solves your problem.
Thank you demigeek, for this simple and precise solution. All the other stuff looks like bandaids and work arounds instead of addressing the real issue. You are the bomb!
I have been plagued by Acrobat printing everything double-sided (AcrobatDC current version; Mac OS 10.14.2; Epson Workforce845, current driver). The only place I can find ANY choice for single- or double sided printing is deep in the OS print dialogs and that has double-sided UNchecked. When I go to the print dialog box and click on "Multiple" there is no choice for me to print single- or double-sided (see below). I thought I could work around by selecting Multiple and then setting the "Pages per sheet" to "Custom..." "1 by 1." But this didn't work. How do I stop this?! Right now my only solution is to open PDF docs in Apple's Preview app which doesn't default to duplex but that seems unacceptable.
What I have found is that on a Mac, only Adobe ignores the native interface of the printer in its own user interface. To access the native interface and incorporate its options in the least number of keystrokes, do the following:
1. Open the print dialog
2. Do NOT choose anything (that includes which printer you're using, which pages you're printing, etc.) except ...
3. Click on <printer> at the bottom of the dialog. You will get a warning about losing the wonderful capabilities of Acrobat -- ignore the warning (in fact, choose the option to never display the warning again). The native interface will now pop up.
4. Choose the printer you want; choose duplex or not; if you want to include a cover page from another source (like is done with FAX's), click on <details> and follow that route.
5. Click on <print>. This will take you back to the Acrobat interface where you can now make further modifications or just click <print>, which should give you what you want.
This is still true: Re: In Acrobat Pro DC, I do not have the option for duplex printing on my mac. Any suggestions?
This is a wrong assumption. Adobe presents a first screen, where it puts options that are needed for correctly printing a document. To avoid having people to pass to a second screen, it also tries to include the duplex (print on both sides) option. It can do that only and really only when the printer driver passes the correct information to the OS which in turn passes that information to the applications. Some printer drivers, however, do not pass the information on and keep their capabilities a secret.
In that case Acrobat has no choice as to assume that the printer does not duplex printing. This forces the user to go to the second, printer driver owned dialogue, to set the right parameters.
There is nothing Adobe can do to improve this situation. Users should ask the printer manufacturers for conforming drivers.
I hate to keep disagreeing with you, but I have had my HP OfficeJet Pro 8100 since it was released -- it is really old. HP stopped supporting it on Mac's a number of years ago, but that did not stop Reader and Acrobat from picking up the old driver interface rules and using them. Up until a recent Adobe update in the same six months, and all of a sudden, with no change in HP's printer drivers, Adobe stopping providing double-spaced printing by default. In my mind, this is sloppiness on the part of Adobe.
Additionally, since MS appears to have full access to HP's printer drivers' codes, it would be strange that an Apple product doesn't, especially when MS Office for Mac has exactly the kind of printer interface we appear to want in Acrobat.
Microsoft is not Apple is not Adobe...
For what it's worth I have had the same problem printing double-sided from Acrobat Pro Dc on an HP Envy 5540 which is about 1 year old. I don't have any printing problem other than in Adobe products. Clearly the claim that the printer drivers are not talking to the OS is nonsense. I used mijcar's suggestion above, which works well thank you, but it isn't a very elegant solution.
Nonsense is a great word. What other applications are you using? Please show also a screenshot from those print dialogue box.
I am running Mac OS 12 Monterey. Brother has only updated certain printer drivers for use with Mac OS 12. I have a Brother L2340D and it is supported and does not automatically print double sided. I also have a Brother MFC 9340-CDW and Brother has not updated the driver for use with Mac OS 12 and therefore Acrobat automatically prints double sided and I can't change that, not even through the printer's dialogue box. Therfore, you should check the OS system you are using and go to the printer manufacturer's website to see if they have updated the driver for your printer's use with your OS.
