I am noticing a variance in the space between the questions and responses in my Muse form notification email. See attached images. Does anyone know what determines the amount of space in between?
When the email gets delivered to your email address it comes in a <table>
the elements are distributed in several <td>s and <tr>s and the space between them (and with of tr's and td's) is controlled/determined by CSS.
and when mail uses several mailing server to deliver the email. The CSS for each mailing server can be different from each other. Thats why you are seeing this difference.
Toufic - thank you for the reply. After some additional testing in Muse I do not believe the space variance is determined by different CSS on the server side. Reason being, I have several forms that output the same amount of space in-between the columns. If I add or remove one field, the space in-between the columns changes. See attached sample.
