1 Reply Latest reply on Nov 16, 2017 12:26 AM by Andrea Valle
    Is Acrobat digital signature compatible with the French RGS (référentiel général de sécurité) ?
      We have Acrobat Pro XI and we want to answer to a tender from the French governement and they ask us for a digital signature that complies with the Level 2 of the French RGS (référentiel de sécurité).  Do you know if Acrobat digital signature comply with that?  If not, can you help me find a way to get this certificate.  Thanks.
        • 1. Re: Is Acrobat digital signature compatible with the French RGS (référentiel général de sécurité) ?
          Andrea Valle Adobe Employee
          Hello Marie-Christine,
          short answer is yes, Acrobat supports the creation of digital signatures that comply with RGS Level 2 (also known as RGS "Two Star").
          There's an important piece of information to add. A digital signature is a cryptographic function that requires a digital certificate to be calculated. The digital certificate (or Digital ID) is the way to attest your identity through the digital signature.
          Acrobat supports multiple ways to handle a certificate for signatures: you can use a smart card or USB token, you can use file-based certificates and you can even create your own self-issued certificates. However these mechanisms have different legal value: it's clear that if you create your own certificate you can write whatever identity information in it...
          A Level 2 RGS certificate must be based on hardware support and must be issued by an authorized Certificate Authority, an independent identity provider that will proof your identity before issuing a signing certificate including your identity information.
          So in order to apply the type of signature you have been required - in case you don't have one already - you first have to procure one of such RGS** certificate from one of the French Certificate Authorities that you can find listed in our AATL and EUTL pages:
          Adobe Approved Trust List Members, Acrobat
          European Union Trusted Lists
          Please ensure they offer certificates and devices that work with Adobe Acrobat and with your PC's Operating System.
          Kind regards
