1 Reply Latest reply on Dec 25, 2017 1:25 PM by gkaiseril
    how to hide dropdown default item
    orlandeum12968704
      iam new in adobe component field.
      i have a drop down, with 4 item. where 1 item was a default item.
      i set "--select--" as default item.
      what i want is when i click on the drop down. item `--select--` was hidden or not show.
      but then i click on my custom button where it is a reset form. the drop down value back to pointing at `--select--`
      thanks
        • 1. Re: how to hide dropdown default item
          If you are the developer of the form, then you can just use a space instead of the "--select--" string if you want to control the displayed value. If you want to hide the "--select--" text when printing, you can add some custom JavaScript to the "Will print" action to hide the field and then add some JavaScript to the "Did print" action to display the field.
