• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Pretranscoding
Guest
Nov 15, 2017 Nov 15, 2017
I wanna know what formats does encore accept, to avoid having it doing the transcoding when authoring a DVD.
Views
252
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Nov 16, 2017 Nov 16, 2017
For DVD, you need to use MPEG-2 DVD, period. Of course, set the bitrate so the encoded video will fit the DVD - if file is too large, then Encore may have to transcode anyway to fit.
In Adobe Media Encoder, stand-alone or via Premiere > Export, look for MPEG-2 DVD format, then there will be several presets available like DV NTSC, DV NTSC Widescreen, Progressive, etc. and just choose what is appropriate to the material, set bit rate, and export. This will give you TWO files - .m2v video and .wav a
Votes
Translate
Translate
LEGEND ,
In Adobe Media Encoder, stand-alone or via Premiere > Export, look for MPEG-2 DVD format, then there will be several presets available like DV NTSC, DV NTSC Widescreen, Progressive, etc. and just choose what is appropriate to the material, set bit rate, and export. This will give you TWO files - .m2v video and .wav audio. Encore likes it that way, just put both into Encore. By default, the audio will get (quickly) transcoded to Dolby Digital .ac3, reducing the file size, and video should be left alone.
If coming from an HD source/sequence, you may see thin black bars at edges of export preview - set Scale to Fill to eliminate bars before exporting.
Jeff Pulera
Safe Harbor Computers
Votes
Translate
Translate
Report
Report
Guest
Nov 22, 2017 Nov 22, 2017
LATEST
"In Adobe Media Encoder, stand-alone or via Premiere > Export"
Is Adobe Media Encoder the same as Adobe Encore?
Votes
Translate
Translate
Report
Report
