5 Replies Latest reply on May 7, 2008 9:53 AM by Newsgroup_User
    Change the resolution from 72 dpi
    stu legend
      Hi
      When I open photo's in Fireworks it automaticaly opens withe the resolution set at 72 dpi. How can I change this so when I open photo's they open at a high res? I'm running Fireworks MX 2004 if that makes any difference. Any help appreciated.
        • 1. Re: Change the resolution from 72 dpi
          Level 7
          Stoo safe wrote:
          > Hi
          > appreciated.
          Just change it as you open a new document window. Why do you want to
          work with a high resolution?
          Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          http://www.adobe.com/communities/experts/
          • 2. Re: Change the resolution from 72 dpi
            Level 7
            Stoo safe wrote:
            > Hi
            > appreciated.
            AFAIK, They will open at their native resolution - are you saying that
            photos that you KNOW to be of a higher resolution default back to 72 dpi?
            I'm using FW8 - but am pretty sure the same applies - if I scanned at my
            scanners default 300dpi - then this image retains that dpi when opened
            in FW8
            chin chin
            Sinclair
            • 3. Re: Change the resolution from 72 dpi
              Level 7
              djinn wrote:
              > Stoo safe wrote:
              >> Hi
              > in FW8
              Your image resolution is in pixels. Note the upper part of the image
              size dialog. The resolution you are referring to is printing resolution
              and controls essentially how large the image will be when printed. It
              has no effect on the true capture resolution of the image.
              Digital cameras typically set the base printing resolution to 72 ppi. .
              The lower the printing resolution, the larger the output and as a
              result, the poorer quality the image is.
              Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
              http://www.communityMX.com/
              CommunityMX - Free Resources:
              http://www.communitymx.com/free.cfm
              .:Adobe Community Expert for Fireworks:.
              http://tinyurl.com/2a7dyp
              See my work on Flickr
              http://www.flickr.com/photos/jim_babbage/
              • 4. Re: Change the resolution from 72 dpi
                Level 7
                Thanks Jim,
                Perhaps I'm wrong here, but I think that the OP is saying that the print
                resolution defaults to 72ppi when opening a doc with that originally had
                a higher print resolution - my DW8 stays at the original ppi.
                chin chin
                Sinclair
                • 5. Re: Change the resolution from 72 dpi
                  Level 7
                  >> resolution and controls essentially how large the image will be when
                  >> printed. It has no effect on the true capture resolution of the image.
                  >> . The lower the printing resolution, the larger the output and as a
                  > Thanks Jim,
                  Maybe, but it's not the way I read it. I think the issue here is the OP
                  is not being very clear as to WHAT resolution he's referring to. I tried
                  to clear that up in my post, but I should have replied directly to the
                  OP's post rather than to yours. Sorry for the confusion. :-)
