Please help me I'm stuck with a small problem that is my anchor point of the shape layer. I have an animated Shape layer that if you adjust the animation it gets all messed up because the anchor point changes with it. I want the anchor point to be stuck on the left center of the shape. Is there an expression for that? If so please explain how...
See print screen 1 and 2 the anchor point is changing to a different position when typing something different. I want it to be stuck to its first position. At least for know at the left center.
Thanks in advance.
Did some experimenting and found a way to keep the anchor point always on the center. See print screen for the expression. I keep struggling with snapping it to the left center. Somebody who can put the final touch at the top of this expression or even has a simpler one?
Also these settings I have made for the solid to connect with the text doesn't effect my sliders with the anchor point thank god. The anchor point only effects the animation that is why I would like to snap it to the left center. (The solid animates in from the left).
