Expand my Community achievements bar.
SOLVED
Can't access Data Warehouse
Avatar
Level 2
Hi!
I can no longer access the "Data Warehouse" on my account, any ideas?
It worked fine yesterday morning since then it just won't load.
Thanks!
1 Accepted Solution
Avatar
Correct answer by
Level 2
Thanks!
I found the issue, apparently I need to have Global settings enabled and a not account specific settings enabled when navigating to the Data warehouse.
View solution in original post
Avatar
Community Advisor
Hello,
Are you an Admin? Kindly confirm to advice.
Thank You!
Arun
Avatar
Level 2
Yes I believe so, I have been using this for a few days but suddenly it stopped working.
Thanks for your advice!
Avatar
Community Advisor
Hello,
Ifyou are admin, go to Admin >> User Management >> Users and click on your name to see that you have access to all groups. If not, select everything, re-login and see whether you can see Data warehouse
If you still cannot, go to Admin >> User Management >> Groups, create a New User Group at the top right, select the report suites, give "All Access" to all the Report Access and pull your name into the group members to select okay. Re-login again, you can see it for sure!
If you are not Admin, you cannot do any of the above. So please reach Admin to give the access in the same way as said.
Thank You!
Arun
Avatar
Correct answer by
Level 2
Thanks!
