ID 2018 crashes while trying to use the dropper in a document originally created in ID 2017.
Here is the crash reporter text:
Process: Adobe InDesign CC 2018 [7538]
Path: /Applications/Adobe InDesign CC 2018/Adobe InDesign CC 2018.app/Contents/MacOS/Adobe InDesign CC 2018
Identifier: com.adobe.InDesign
Version: 13.0.0.125 (13000)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe InDesign CC 2018 [7538]
User ID: 501
Date/Time: 2017-10-18 23:51:06.883 +0200
OS Version: Mac OS X 10.12.6 (16G29)
Report Version: 12
Anonymous UUID: CCBE621C-D960-51AA-AA35-64F8A12286D4
Sleep/Wake UUID: D0A41AE3-2FB7-40D4-B63A-075AEC3D4DC0
Time Awake Since Boot: 330000 seconds
Time Since Wake: 3600 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLT
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.adobe.InDesign.Tables UI 0x00000001222faa9c 0x12227d000 + 514716
1 ObjectModelLib.dylib 0x0000000105660974 0x105658000 + 35188
2 PublicLib.dylib 0x00000001019965e0 MultiControllingUnknown::~MultiControllingUnknown() + 80
3 PublicLib.dylib 0x000000010199664e MultiControllingUnknown::~MultiControllingUnknown() + 14
4 com.adobe.InDesign.AppFramework 0x0000000124093ca1 0x123f28000 + 1490081
5 com.adobe.InDesign.AppFramework 0x0000000123ff4bee 0x123f28000 + 838638
6 ObjectModelLib.dylib 0x0000000105660974 0x105658000 + 35188
7 PublicLib.dylib 0x00000001019965e0 MultiControllingUnknown::~MultiControllingUnknown() + 80
8 com.adobe.InDesign.AppFramework 0x0000000123ff7c3e 0x123f28000 + 851006
9 com.adobe.InDesign.Eyedropper Tool 0x000000012146eb93 0x12145e000 + 68499
10 com.adobe.InDesign.Eyedropper Tool 0x000000012146e238 0x12145e000 + 66104
11 com.adobe.InDesign.Layout UI 0x0000000127474aed 0x127463000 + 72429
12 com.adobe.InDesign.Layout UI 0x000000012747443c 0x127463000 + 70716
13 DV_WidgetBinLib.dylib 0x00000001001ad54b DVEventHandler::DVPointerEvent(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&, bool&) + 315
14 DV_WidgetBinLib.dylib 0x0000000100197154 DVHostedWidgetView::PrivateImpl::PointerEventCallback(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&, bool&) + 68
15 com.adobe.dvaui.framework 0x00000001011ccc74 dvaui::ui::UI_Node::UI_DispatchCustomPointerEventToNode(dvaui::ui::UI_Node*, boost::intrusive_ptr<dvaui::ui::UI_Node>, dvaui::ui::PointerEvent const&, bool&) + 132
16 com.adobe.dvaui.framework 0x00000001011cc808 dvaui::ui::UI_Node::UI_DispatchPointerEventToLeaf(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&) + 168
17 com.adobe.dvaui.framework 0x00000001011cc2cb dvaui::ui::UI_Node::DispatchPointerEvent::operator()(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvacore::geom::PointT<float> const&) const + 139
18 com.adobe.dvaui.framework 0x00000001011cc976 dvaui::ui::UI_Node::UI_DispatchPointerEventToLeaf(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&) + 534
19 com.adobe.dvaui.framework 0x00000001011cc95a dvaui::ui::UI_Node::UI_DispatchPointerEventToLeaf(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&) + 506
20 com.adobe.dvaui.framework 0x00000001011cc95a dvaui::ui::UI_Node::UI_DispatchPointerEventToLeaf(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&) + 506
21 com.adobe.dvaui.framework 0x00000001011cc95a dvaui::ui::UI_Node::UI_DispatchPointerEventToLeaf(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&) + 506
22 com.adobe.dvaui.framework 0x00000001011cc95a dvaui::ui::UI_Node::UI_DispatchPointerEventToLeaf(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&) + 506
23 com.adobe.dvaui.framework 0x00000001011cb85f dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeaf(dvaui::ui::PointerEvent const&, bool) + 63
24 com.adobe.dvaui.framework 0x00000001011cb018 dvaui::ui::UI_Node::UI_DispatchPointerEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&, bool) + 328
25 com.adobe.dvaui.framework 0x00000001011cae22 dvaui::ui::UI_Node::UI_DispatchPointerEvent(dvaui::ui::PointerEvent const&, bool) + 66
26 com.adobe.dvaui.framework 0x0000000101243f19 dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 681
27 com.adobe.dvaui.framework 0x00000001012439de dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event const&) + 510
28 com.adobe.dvaui.framework 0x00000001012419d8 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 120
29 com.adobe.dvaui.framework 0x0000000101241936 dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 22
30 com.adobe.dvaui.framework 0x0000000101243146 dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 70
31 com.adobe.dvacore.framework 0x0000000100a0d16c int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 28
32 com.adobe.InDesign.Application UI 0x00000001242e2de2 0x124165000 + 1564130
33 com.adobe.dvacore.framework 0x0000000100a0d223 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::function0<void>, bool*) + 99
34 com.adobe.dvacore.framework 0x0000000100a0db51 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 161
35 com.adobe.dvaui.framework 0x000000010124f98c dvaui::ui::OS_NodeTimerData::~OS_NodeTimerData() + 31724
36 com.apple.AppKit 0x00007fff91df324f -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 6341
37 com.apple.AppKit 0x00007fff91defa6c -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 1942
38 com.apple.AppKit 0x00007fff91deef0a -[NSWindow(NSEventRouting) sendEvent:] + 541
39 com.adobe.owl 0x000000010066ddad 0x100633000 + 241069
40 com.apple.AppKit 0x00007fff91c73681 -[NSApplication(NSEvent) sendEvent:] + 1145
41 com.adobe.dvaui.framework 0x00000001012481bb dvaui::ui::OS_NodeTimerData::~OS_NodeTimerData() + 1051
42 com.adobe.exo.framework 0x0000000102f861b4 exo::app::OS_AppBase::SetResetMenuShortcutsOnClose(bool) + 852
43 DV_WidgetBinLib.dylib 0x0000000100226755 0x100189000 + 644949
44 com.adobe.InDesign.Application UI 0x00000001242edd86 0x124165000 + 1609094
45 com.apple.AppKit 0x00007fff914ee427 -[NSApplication run] + 1002
46 com.adobe.exo.framework 0x0000000102f85bb8 exo::app::OS_AppBase::RunEventLoop() + 56
47 com.adobe.InDesign.AppFramework 0x0000000124084ad3 0x123f28000 + 1428179
48 com.adobe.InDesign.AppFramework 0x00000001240836ca 0x123f28000 + 1423050
49 com.adobe.InDesign 0x000000010013f09a main + 730
50 libdyld.dylib 0x00007fffa95cc235 start + 1
[snipped by moderator]
Hi All,
We have released a patch update for InDesign CC 2018 today. It addresses many crash issues and reported bugs. Would request you all to update your InDesign app. If the update is not visible/available in InDesign please check Creative Cloud Desktop App for the app updates.
Regards
Srishti
Hi DesignRob,
We are aware of the issue that you have mentioned where InDesign crashes while using Eyedropper tool with text inside a table.
We are currently investigating into it.
Other issues that are being reported on this thread are mainly crash on launch.
Regards,
Abhinav
Here is my crash report.
Sorry, it is here https://pastebin.com/yKemjXHy
Having the same problem!
Take a look @ my solution above. I fixed it on 5+ machines now already.
Why would you replace the 2018 crash reporter with the 2017 crash reporter? Seems that may lead to other issues. Why not just use CC 2017 then? Just wondering if this is a viable solution or just temp.
Because the crashreporter in 2018 is corrupt and you cannot open 2018 files in 2017. Probably Adobe will come with a fix in the future for this
Okay I didn't realize people with 2017 cannot open 2018 documents. I am the only one on the team testing 2018 out and haven't needed to open 2018 in 2017 yet. Thanks for the info!
It didn't fix anything for me, unfortunately.
We believe we have a fix available for the same. Can you follow the steps mentioned in the following KB document - https://helpx.adobe.com/indesign/kb/crash-fixes-october-2017-release.html and confirm if it resolves your issue?
Regards
Sanyam Talwar
InDesign Engineering Team
Works for me !! Thx !! Finally i can use IDCC18
This didn't fix the 'crashing at splash screen' issue, but then I don't think it was intended to.
Didn't work for me either... still crashes on splash screen (osx high sierra)
This fix was only for the five specific issues described in the document. I think the engineers are still investigating other issues in order to create an update.
Tried the downloaded fix. Did not have an effect. Still crashed immediately after opening.
Can you explain again how to generate a crash report?
I have the same problem, InDesign CC 2018 is log out when just after opening.
I deleted the preference folders as you indicated. I installed BugFixes_MAC as you indicated.
But result is always same, crashed immediately after opening…
I send to you my crash report by mail.
Regards
I applied the fix and it did not fix my issues. it still crashes on launching. My crash report is the begin sent to Apple but I can send one to you if you let me know where. Strange thing is we have 7 iMacs all running OS10.12.6. All but 2 work with ID2018 We checking to see if there is something different but can find any disparages between the working and non working. One thing to note is the reason code for the termination is DYLD, [0x1] Libary missing. Then there is a line under Dyld Error message:Image not found. Could this be the slash screen image used when ID launches?
Mike Johnson
not working for me still crashing
Can you please send the crash report with forum thread in notes and your email id. After submitting please send a mail to me at santalwa@adobe.com
Any update yet please Adobe? It's still not working.
I followed the steps. Didn’t work for me.
Please restart the machine and Trash Preference and cache.
Launch InDesign
If the issue still persists,
Copy the crash thread stack and send to me at santalwa@adobe.com
Hi
Well, have just tried another install after about a fortnight and Indesign 2018 is still crashing at the splash screen.
Have just mailed you my data.
VBW
M
Hi
Is there any update on the 'crash at splash' issue?
A response and update on there situation would be appreciated.
VBW
M
