1 Reply Latest reply on Jan 10, 2018 4:07 PM by Adorobat
    Acrobat won't sign the PDF
    amityunger
      Hello,
      For some reason, Acrobat won’t sign the PDF.
      Once I draw a rectangle, I get this massage: “This signature field requires a digital signature identity. Would you like to configure one now?” and pressing “Configure Digital ID” fill the whole document with 50% transparent black with a white pixel in the middle.
      Afterward, only Esc will make the document available again (without the signature).
      I’m working on an up to date Acrobat CC and I tried “Save as other > Reader extended PDF”.
      What should I do?
      Many thanks,
      Amit
        • 1. Re: Acrobat won't sign the PDF
          Adorobat Adobe Employee
          Hi Amit,
          Sorry for the delay in response.
          Are you still experiencing this issue? If yes, please try the steps given below:
          1- Press Esc button to get back to the pdf.
          2- Click Edit > Preferences > Signatures > Identities & Trusted Certificates > click More.
          3- Click Add ID and follow the steps to create a digital ID. Once finished, relaunch Acrobat and try again. You may refer to the steps given in the following link on how to create a digital id in Acrobat: Digital IDs in Acrobat
          Feel free to update this discussion if you need any help.
          Shivam
