1 Reply Latest reply on Nov 20, 2017 1:59 AM by Mylenium
    Save from Photoshop or Illustrator for Instagram
    piercee62312239 Level 1
      Hello,
      I've been searching through the internet trying to find out how to save graphic, typography, work to Instagram. Mostly what quality and size is best for this? I find that when I use lots of colours, shapes, and text that it compresses and has an unfortunate look to it. If I could have any help on fixing this, it would be much appreciated!
      Thanks so much,
      P
        • 1. Re: Save from Photoshop or Illustrator for Instagram
          IG will always crunch your images through its own "optimization", especially for the preview images and low-res versions, so this is ultimately a moot point. essentially once you upload, your original source image is gone and the service is really not meant to distribute high-quality artwork. You can improve results by adhering to their default resolutions, which are all based on using 1080 pixels for height and width, but that's pretty much it. If that's to lo-res for you, then simply use Flickr or another service that also retains the original image.
          Mylenium
