2 Replies Latest reply on Nov 20, 2017 3:28 PM by Shulipa Bernad
    Create a copy of the current document in a subfolder as the tiff format
    Shulipa Bernad Level 1
      Hello! This script creates a copy.jpg of the current document in the same folder with the name of the active layer. How do I modify this script so that it works as follows:
      • Whenever I run this script, a copy is no longer jpg but a copy.tiff of the current document with the name of the active layer inside a subfolder called "Rolad Prints"
      Script: Can anyone guide me? Thank you
      // Backup_Estampa
      (function() {
          try {
              #target photoshop;
              if (app.documents.length > 0) {
                  var thedoc = app.activeDocument;
                  // getting the name and location;
                  var docName = thedoc.name;
                  var basename = docName;
                  if (docName.indexOf(".") != -1)
                      basename = docName.match(/(.*)\.[^\.]+$/)[1]
                  // getting the location, if unsaved save to desktop;
                  var docPath = "~/Desktop";
                  try {
                      docPath = thedoc.path;
                  } catch (e) {}
                  // jpg options;
                  var jpegOptions = new JPEGSaveOptions();
                  jpegOptions.quality = 9;
                  jpegOptions.embedColorProfile = true;
                  jpegOptions.matte = MatteType.NONE;
                  //save jpg as a copy:
                  var saveFile = docPath + '/' + thedoc.activeLayer.name + '.jpg';
                  if (File(saveFile).exists)
                      saveFile = incrementFile(saveFile);
                  thedoc.saveAs(new File(saveFile), jpegOptions, true);
                  //that’s it; thanks to xbytor;
              function incrementFile(pathToFile) {
                  var saveSufixLength = 2,
                      suffix = zeroPad(0, saveSufixLength),
                      newPathToFile = pathToFile,
                      suffixInteger, folder, fileName, extension;
                  while (File(newPathToFile).exists) {
                      suffixInteger = parseInt(suffix, 10);
                      suffixInteger += 1;
                      suffix = zeroPad(suffixInteger, saveSufixLength);
                      folder = File(pathToFile).path;
                      fileName = File(pathToFile).name.substring(0, File(pathToFile).name.lastIndexOf("."));
                      extension = File(pathToFile).name.substring(File(pathToFile).name.lastIndexOf(".") + 1, File(pathToFile).name.length);
                      newPathToFile = folder + "/" + fileName + "_" + suffix + "." + extension;
                  return newPathToFile;
                  function zeroPad(num, digit) {
                      var tmp = num.toString();
                      while (tmp.length < digit) {
                          tmp = "0" + tmp;
                      return tmp;
          } catch (e) {
              alert(e.toString() + "\nScript File: " + File.decode(e.fileName).replace(/^.*[\|\/]/, '') +
                  "\nFunction: " + arguments.callee.name +
                  "\nError on Line: " + e.line.toString())
        • 1. Re: Create a copy of the current document in a subfolder as the tiff format
          r-bin Level 4
          Check. This is it or not?
          var subfolder = "Rolad Prints";
          var tif_layers = true; // change to false if you want flatten image
          // Backup_Estampa
          (function() {
              try {
                  #target photoshop;
                      try {
                      } catch (e) {}
                      // tif options;
                      var tiffOptions = new TiffSaveOptions();
                      with (tiffOptions)
                          alphaChannels      = true;
                          annotations        = true;
                          byteOrder          = ByteOrder.IBM;
                          imageCompression   = TIFFEncoding.NONE;
                          interleaveChannels = true;
                          jpegQuality        = 12;
                          layerCompression   = LayerCompression.ZIP;
                          layers             = tif_layers;
                          saveImagePyramid   = false;
                          spotColors         = true;
                          transparency       = false;
                      //save tif as a copy:
                      if (!Folder(docPath + "/" + subfolder).exists) Folder(docPath + "/" + subfolder).create();
                      var saveFile = docPath + '/' + subfolder + '/' + thedoc.activeLayer.name + '.tif';
                      thedoc.saveAs(new File(saveFile), tiffOptions, true);
                          suffixInteger += 1;
                          newPathToFile = folder + "/" + subfolder + "/" + fileName + "_" + suffix + "." + extension;
                              tmp = "0" + tmp;
                          return tmp;
              } catch (e) {
          2 people found this helpful
          • 2. Re: Create a copy of the current document in a subfolder as the tiff format
            Wow, perfect! r-bin you are phenomenal. You can not imagine how much this will expedite my tasks. Thank you so much.
