Hi! I'm new to photoshop element and I used to have an older version of photoshop 7. Is there a way to make the letters spacing closer to each other? There's no pop up tool compared to photoshop 7 that helps with this. I am making a thank you note.
ivyg88412764 wrote
Thanks for the reply. I have tried the asian text and its still very far apart even on 100%.
I have tried it with 70% and the spacing was reduced to 70% of the original spacing.
For the Element+, is that the Premiere element or I can buy that separately?
($12)
Photoshop Elements does not provide all the text tools available in Photoshop.
In your case, there is a way:
- check in your prefernces, option 'Type...' that 'show asian text' is ticked.
- in the bottom tool bar, open the drop-down option for Asian text and choose your percentage.
To get back Photoshop text options, you might use the affordable toolset of scripts from Elements+, which has additional text options.
Thanks for the reply. I have tried the asian text and its still very far apart even on 100%. For the Element+, is that the Premiere element or I can buy that separately?
($12)
Thank you
