2 Replies Latest reply on Nov 21, 2017 7:35 AM by hectoro43759168
    3d bump on bend x 360
    hectoro43759168
      How to ad a bump image to the flat extrusion material of a revolved (bend x 360) object without it getting distorted. See image.
        • 1. Re: 3d bump on bend x 360
          davescm Adobe Community Professional
          Hi
          You will need to use transform warp on the bump map to bring it into shape
          , also change the UV properties to V/Y Tile 0.5 - so you don't get two pull rings
          If you need it to cross the centre point - then the better way is to create an additional model with the circle as a front surface then put the bump map on that (use combine 3D layers to bring it together with the other model). You will not need to distort it that way.
          Dave
          • 2. Re: 3d bump on bend x 360
            hectoro43759168 Level 1
            Thank you Dave!
            I solved the problem using the second technique you explained, since I needed to cross the center point. I think it would be better if Adobe make it work in the bend x 360. There should be a way in which Photoshop "un-distort" the map for you to place your bump image and then "re-distort" it for it to accommodate in the extrusion surface.
            This is the final result using the frontal extrusion anyway.
            Thank you!
