24 Replies Latest reply on Sep 2, 2018 10:16 PM by gabito88671511
    Oh geez. Your build failed. Click the "Log" button above to view the compile log. If you need help diagnosing the issue, you can post to the support forum with your App ID (please do a search first).
    lavanyan27579065 Level 1
      Build Date: 2017-11-21 10:50:40 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-camera" via npm
      Installing "cordova-plugin-camera" at "3.0.0" for android
      Plugin doesn't support this project's cordova-android version. cordova-android: 6.1.2, failed version requirement: >=6.3.0
      Skipping 'cordova-plugin-camera' for android
      Fetching plugin "cordova-plugin-media-capture" via npm
      Installing "cordova-plugin-media-capture" at "2.0.0" for android
      Skipping 'cordova-plugin-media-capture' for android
      Fetching plugin "cordova-plugin-device" via npm
      Installing "cordova-plugin-device" at "1.1.7" for android
      Fetching plugin "cordova-plugin-file" via npm
      Installing "cordova-plugin-file" at "5.0.0" for android
      Skipping 'cordova-plugin-file' for android
      Fetching plugin "cordova-plugin-file-transfer" via npm
      Installing "cordova-plugin-file-transfer" at "1.7.0" for android
      Plugin dependency "cordova-plugin-file@5.0.0" already fetched, using that version.
      Fetching plugin "cordova-plugin-globalization" via npm
      Installing "cordova-plugin-globalization" at "1.0.8" for android
      Fetching plugin "cordova-plugin-inappbrowser" via npm
      Installing "cordova-plugin-inappbrowser" at "1.7.2" for android
      Fetching plugin "cordova-plugin-network-information" via npm
      Installing "cordova-plugin-network-information" at "1.3.4" for android
      Fetching plugin "cordova-plugin-statusbar" via npm
      Installing "cordova-plugin-statusbar" at "2.3.0" for android
      Fetching plugin "cordova-plugin-whitelist" via npm
      Installing "cordova-plugin-whitelist" at "1.3.3" for android
                     This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
      Fetching plugin "cordova-plugin-splashscreen" via npm
      Installing "cordova-plugin-splashscreen" at "4.1.0" for android
      Fetching plugin "cordova-universal-clipboard" via npm
      Installing "cordova-universal-clipboard" at "0.1.0" for android
      Fetching plugin "nl.kingsquare.cordova.background-audio" via npm
      Installing "nl.kingsquare.cordova.background-audio" at "1.0.1" for android
      Fetching plugin "phonegap-plugin-push@1.9.2" via npm
      Installing "phonegap-plugin-push" at "1.9.2" for android
      Subproject Path: CordovaLib
      Fetching plugin "cordova-plugin-customurlscheme" via npm
      Installing "cordova-plugin-customurlscheme" at "4.3.0" for android
      Fetching plugin "ionic-plugin-keyboard" via npm
      Installing "ionic-plugin-keyboard" at "2.2.1" for android
      Fetching plugin "cordova-plugin-zip" via npm
      Installing "cordova-plugin-zip" at "3.1.0" for android
      Fetching plugin "cordova-plugin-local-notifications-mm" via npm
      Installing "cordova-plugin-local-notifications-mm" at "1.0.6" for android
      Plugin dependency "cordova-plugin-device@1.1.7" already fetched, using that version.
      Dependent plugin "cordova-plugin-device" already installed on android.
      Fetching plugin "cordova-plugin-app-event" via npm
      Installing "cordova-plugin-app-event" at "1.2.1" for android
              Your support is needed. If you use the local-notification plugin please support us in order to ensure further development.
              https://github.com/katzer/cordova-plugin-local-notifications#supporting
              Thank you!
      Fetching plugin "https://github.com/Tunts/WebIntent.git" via git clone
      Using shallow clone
      Repository "https://github.com/Tunts/WebIntent.git" checked out to git ref "master" at "15fcb4e".
      Installing "net.tunts.webintent" at "0.2.1" for android
      Fetching plugin "https://github.com/ti8m/DocumentHandler.git" via git clone
      Using shallow clone
      Repository "https://github.com/ti8m/DocumentHandler.git" checked out to git ref "master" at "f501154".
      Installing "ch.ti8m.documenthandler" at "0.2.2" for android
      COMPILE OUTPUT
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preDebugBuild UP-TO-DATE
      :checkDebugManifest
      :preReleaseBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseAidl
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:processReleaseManifest
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportSupportCompat2600Alpha1Library
      :prepareComAndroidSupportSupportCoreUi2600Alpha1Library
      :prepareComAndroidSupportSupportCoreUtils2600Alpha1Library
      :prepareComAndroidSupportSupportFragment2600Alpha1Library
      :prepareComAndroidSupportSupportMediaCompat2600Alpha1Library
      :prepareComAndroidSupportSupportV132340Library
      :prepareComAndroidSupportSupportV42600Alpha1Library
      :prepareComGoogleAndroidGmsPlayServicesBase980Library
      :prepareComGoogleAndroidGmsPlayServicesBasement980Library
      :prepareComGoogleAndroidGmsPlayServicesGcm980Library
      :prepareComGoogleAndroidGmsPlayServicesIid980Library
      :prepareComGoogleAndroidGmsPlayServicesTasks980Library
      :prepareMeLeolinShortcutBadger1111Library
      :prepareProjectCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      :mergeDebugResources
      :processDebugResourcesWarning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
      /project/src/org/apache/cordova/filetransfer/FileTransfer.java:49: error: package org.apache.cordova.file does not exist
      import org.apache.cordova.file.FileUtils;
      /project/src/org/apache/cordova/filetransfer/FileTransfer.java:851: error: cannot find symbol
                              FileUtils filePlugin = (FileUtils) pm.getPlugin("File");
        symbol: class FileUtils
      Note: Some input files use unchecked or unsafe operations.
      Note: Recompile with -Xlint:unchecked for details.
      3 errors
      :compileDebugJavaWithJavac FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':compileDebugJavaWithJavac'.
      > Compilation failed; see the compiler error output for details.
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 5.703 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      3 errors
      * What went wrong:
      * Try:
          at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
          at emitTwo (events.js:106:13)
          at ChildProcess.emit (events.js:191:7)
          at maybeClose (internal/child_process.js:877:16)
          at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
