When I try to export my timeline using Media Encoder, I get the following error:
I have the exact same issue whilst sending to Media Composer CC 2018.
I am using a nested timeline with a LUT and a crop applied. Though nested timeline LUT & the crop whether they are used or not I get the same error now.
To no avail I have tried; clearing prefs, deleting the caches, unnesting timeline removing; LUT, Crop, AE clip but then I copied and pasted contents of timeline into a new sequence and bingo works! And now so does the nested timeline!
Would be good if Adobe can give any help/inpu
...Copy link to clipboard
Would be good if Adobe can give any help/input here to understand what is going on!
Hardware: Mac Pro (late 2013) 3.5Ghz 6-Core, AMD FirePro D700 cards 6144MB, 32GB ram
OS: macOS Sierra
Software: Premiere Pro CC (2018)
Media: 4K DNxHR HQX & XF-AVC & AE clip.
Thanks! I was having the same issue, but copying everything to a new sequence solved the problem.
This solved this same problem for me too. Thank you!
I'm having the same issue. It's still showing the error when I copy to a new sequence though.
FWIW, if anyone else is having similar problems...
I have a Premiere project that is importing various AE projects.
I had imported them into Premiere with a temporary video (with audio) in a composition (as a guide track).
I then deleted that temporary video from the composition, but Premiere, while updating the AE project, seemed to not like that.
Not until I tried to export did I realise the problem....
Deleting the AE projects, from Premiere and re-importing them back into my timeline resolved the problem.
Hope this helps!
