• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Stop Generator Image Assets
Explorer ,
Nov 21, 2017 Nov 21, 2017
is there any way to stop the Generator "Image Assets".
To activate i use
var desc1 = new ActionDescriptor();
desc1.putString(app.stringIDToTypeID("javaScriptName"), "Bild-Assets");
executeAction(app.stringIDToTypeID('AdobeScriptAutomation Scripts'), desc1, DialogModes.NO);
TOPICS
Actions and scripting
Views
1.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
People's Champ , Nov 23, 2017 Nov 23, 2017
Try universal localized code. I have it working in the russian version ).
var d = new ActionDescriptor();
d.putString( charIDToTypeID( "jsNm" ), localize("$$$/JavaScripts/Generator/ImageAssets/Menu") );
d.putString( charIDToTypeID( "jsMs" ), "undefined" );
executeAction( stringIDToTypeID( "AdobeScriptAutomation Scripts" ), d, DialogModes.NO );
You can also take the code from the one that is executed in the Scripts / generate.jsx file. It seems to work as it should.
start_assets()
function start_assets
Votes
Translate
Translate
Adobe
People's Champ ,
Nov 22, 2017 Nov 22, 2017
Never used this thing. If I correctly understood what you meant, then in the CC2018 you can turn off for the active document in this way (verified):
try {
    var r = new ActionReference();
    r.putProperty( charIDToTypeID( "Prpr" ), stringIDToTypeID( "generatorSettings" ) );
    r.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
    var d = executeActionGet(r);
    var generatorSettings = d.getObjectValue(stringIDToTypeID("generatorSettings"));
    var generator_45_assets = generatorSettings.getObjectValue(stringIDToTypeID("generator_45_assets"));
    var json = generator_45_assets.getString(stringIDToTypeID("json"));
    generator_45_assets.putString(stringIDToTypeID("json"), "{\"enabled\":false}");
    generatorSettings.putObject(stringIDToTypeID("generator_45_assets"), stringIDToTypeID("generator_45_assets"), generator_45_assets);
    d.putReference( charIDToTypeID( "null" ), r );
    d.putObject( charIDToTypeID( "T   " ), charIDToTypeID( "null" ), generatorSettings );
    executeAction( charIDToTypeID( "setd" ), d, DialogModes.NO );
catch(e) { alert(e); }
Votes
Translate
Translate
Report
Report
Explorer ,
My goal is to activate and deactivate the generator (Image Assets) from my html panel
File > Generate > Image Assets
The code from the scriptlistener looks like this:
But with that I can only activate the generator (Image Assets)
Thank you very much
Votes
Translate
Translate
Report
Report
Explorer ,
Thank you! I have another question, though.
Is it possiblt to start the generator the same way?
With my code, it only works in the german Photoshop version.
Setting the value for generatorSettigns "{\"enabled\":false}" to true only works, once the generator is started.
generator_45_assets.putString(stringIDToTypeID("json"), "{\"enabled\":true}");
Votes
Translate
Translate
Report
Report
People's Champ ,
start_assets()
function start_assets()
    var pluginName = "generator-assets-dummy-menu";
    try {
        var generatorDesc = new ActionDescriptor();
        generatorDesc.putString (app.stringIDToTypeID ("name"), pluginName);
        var returnDesc = executeAction( app.stringIDToTypeID ("generateAssets"), generatorDesc, DialogModes.NO );
    catch( e ) { alert(); }
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks a lot!
Votes
Translate
Translate
Report
Report
Explorer ,
Sep 25, 2020 Sep 25, 2020
r-bin,
I have tried your code but it does not stop Generator "Image Assets" for me (As I believe was Joachim_Hiller's question.)  It will only start asset generation.  I am not a pro on Action Manager so I might be missing something basic.
I've tried this exact code in a JS and, as I mentioned, it will TURN ON asset generation but not off...
start_assets()
    try {
Many thanks,
Votes
Translate
Translate
Report
Report
LEGEND ,
Start means start? 😛 For stop look few posts higher.
Votes
Translate
Translate
Report
Report
People's Champ ,
Can not say anything, especially if you are going to use it in an extension.
Most likely in 2020 the behavior was changed and the script (for stopping) does not work.
Try just turning off the generator.
r.putProperty(stringIDToTypeID("property"), stringIDToTypeID("pluginPicker"));
r.putEnumerated(stringIDToTypeID("application"), stringIDToTypeID("ordinal"), stringIDToTypeID("targetEnum"));
d.putReference(stringIDToTypeID("null"), r);
var d1 = new ActionDescriptor();
d1.putBoolean(stringIDToTypeID("generatorEnabled"), false);
d1.putBoolean(stringIDToTypeID("generatorDisabled"), true);
d.putObject(stringIDToTypeID("to"), stringIDToTypeID("pluginPicker"), d1);
executeAction(stringIDToTypeID("set"), d, DialogModes.NO);
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
 r-bin,
(I obviously copied and pasted the wrong code in my post... Had intended to past the stop code).
Yeah, it appears it something broke it in the 2019 release. It still works on 2018.
Turning off the generator completely will get me through for now.
Thanks!
Votes
Translate
Translate
Report
Report
