1 Reply Latest reply on Nov 26, 2017 5:05 PM by Zarushura
    files appear to be open, but can't see anything
    kimh26063891
      I opened a Photoshop file today and while it looks like the file is open (and i tried several files) nothing appears on the screen. Why not? What I've done to try and correct is resetting preference via the ctrl/alt/shift method, I could not fine a prefs file to move. And I've ensured I've downloaded the latest version. I'm on Win10.
      Any ideas?
        • 1. Re: files appear to be open, but can't see anything
          Zarushura
          I've been having the same problem regularly since the November update of Photoshop to CC 2018. If I resize the window, the canvas will update once, but it continues to not display any new edits to the open file. Usually restarting Photoshop will fix the problem, but it's still annoying! If anyone can tell us what's going on that would be great.
          I'm using Photoshop on OSX High Sierra 10.13.1 with a Wacom Intuos 4.
          Adobe Photoshop Version: 19.0 20171103.r.190 2017/11/03: 1143799  x64
          Number of Launches: 345
          Operating System: Mac OS 10.13.1
          System architecture: Intel CPU Family:6, Model:94, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
          Physical processor count: 4
          Logical processor count: 8
          Processor speed: 4000 MHz
          Built-in memory: 16384 MB
          Free memory: 8042 MB
          Memory available to Photoshop: 13614 MB
          Memory used by Photoshop: 70 %
          Alias Layers: Disabled.
          Modifier Palette: Disabled.
          Highbeam: Enabled.
          Touch Bar Property Feedback: Enabled.
          Image tile size: 1024K
          Image cache levels: 4
          Font Preview: Medium
          TextComposer: Latin
          Display: 1
          Main Display
          Display Bounds: top=0, left=0, bottom=1440, right=2560
          OpenGL Drawing: Enabled.
          OpenGL Allow Old GPUs: Not Detected.
          OpenGL Drawing Mode: Advanced
          OpenGL Allow Normal Mode: True.
          OpenGL Allow Advanced Mode: True.
          AIFCoreInitialized=1
          AIFOGLInitialized=1
          OGLContextCreated=1
          NumGLGPUs=1
          NumCLGPUs=1
          NumNativeGPUs=1
          glgpu[0].GLVersion="2.1"
          glgpu[0].IsIntegratedGLGPU=0
          glgpu[0].GLMemoryMB=2048
          glgpu[0].GLName="AMD Radeon R9 M390 OpenGL Engine"
          glgpu[0].GLVendor="ATI Technologies Inc."
          glgpu[0].GLVendorID=4098
          glgpu[0].GLRectTextureSize=16384
          glgpu[0].GLRenderer="AMD Radeon R9 M390 OpenGL Engine"
          glgpu[0].GLRendererID=16915458
          glgpu[0].HasGLNPOTSupport=1
          glgpu[0].CanCompileProgramGLSL=1
          glgpu[0].GLFrameBufferOK=1
          glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
          glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
          glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
          glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
          glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
          glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
          glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
          glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
          glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
          glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
          glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
          glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
          glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
          clgpu[0].CLPlatformVersion="1.2 (Sep  6 2017 16:05:06)"
          clgpu[0].CLDeviceVersion="1.2 "
          clgpu[0].IsIntegratedCLGPU=0
          clgpu[0].CLMemoryMB=2048
          clgpu[0].CLName="AMD Radeon R9 M390 Compute Engine"
          clgpu[0].CLVendor="AMD"
          clgpu[0].CLVendorID=16915456
          clgpu[0].CLDriverVersion="1.2 (Sep 29 2017 18:59:39)"
          clgpu[0].CLBandwidth=1.25211e+11
          clgpu[0].CLCompute=859.064
          nativegpu[0].NativeName="AMD Radeon R9 M390"
          License Type: Subscription
          Serial number: 94070049474887659032
          GUIDBucket:
          Application folder: /Applications/Adobe Photoshop CC 2018/
          Photoshop scratch has async I/O enabled
          Scratch volume(s):
            Startup, 951.8G, 583.3G free
          Required Plug-ins folder: /Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/Plug-ins/
          Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2018/Plug-ins/
          Installed components:
             AdbePM.framework   AdbePM   2.5.00.377243   1.578146
             adobe_caps.framework   adobe_caps   10.0.0.6   1.584361
             AdobeACE.framework   AdobeACE   2.20.02.39233   79.586793
             AdobeAGM.framework   AdobeAGM   4.30.87.39233   79.586793
             AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
             AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
             AdobeBIB.framework   AdobeBIB   1.2.03.39233   79.586793
             AdobeBIBUtils.framework   AdobeBIBUtils   1.1.39233   79.586793
             AdobeCoolType.framework   AdobeCoolType   5.17.00.39233   79.586793
             AdobeCrashReporter.framework   AdobeCrashReporter   7.5.20170906
             AdobeExtendScript.framework   AdobeExtendScript   4.5.7.1   81.1133690
             AdobeJP2K.framework   AdobeJP2K   1.2.2.38423   79.266298
             AdobeLinguistic.framework      22175
             AdobeMPS.framework   AdobeMPS   5.8.1.38423   79.582572
             AdobeOwl.framework   AdobeOwl   5.2.11
             AdobePDFL.framework   AdobePDFL   15.0.0.38423   79.226411
             AdobePDFSettings.framework   AdobePDFSettings   1.4
             AdobePIP.framework   AdobePIP   7.4.1.60.45263
             AdobeScCore.framework   AdobeScCore   4.5.7.1   81.1133690
             AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.38473   79.582907
             AdobeSVGRE.framework   AdobeSVGRE   6.0   79.586793
             AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
             AdobeXMP.framework   AdobeXMPCore   79.160451   79.160451
             AdobeXMPFiles.framework   AdobeXMPFiles   79.160451   79.160451
             AdobeXMPScript.framework   AdobeXMPScript   79.160451   79.160451
             ahclient.framework   ahclient   3.0.0.6
             AIDE.framework   AIDE   1.5.0.36540   79.574279
             aif.framework   aif   6.0.00.1   1.
             amtlib.framework   amtlib   10.0.0.221
             boost_date_time.framework   boost_date_time   11.1.0.0
             boost_filesystem.framework   boost_filesystem   11.1.0.0
             boost_signals.framework   boost_signals   11.1.0.0
             boost_system.framework   boost_system   11.1.0.0
             boost_threads.framework   boost_threads   11.1.0.0
             Cg.framework   NVIDIA Cg
             CITThreading.framework
             dvaaudiodevice.framework   dvaaudiodevice   11.1.0.0
             dvacore.framework   dvacore   11.1.0.0
             dvamarshal.framework   dvamarshal   11.1.0.0
             dvamediatypes.framework   dvamediatypes   11.1.0.0
             dvametadata.framework   dvametadata   11.1.0.0
             dvametadataapi.framework   dvametadataapi   11.1.0.0
             dvametadataUI.framework   dvametadataUI   11.1.0.0
             dvaplayer.framework   dvaplayer   11.1.0.0
             dvatransport.framework   dvatransport   11.1.0.0
             dvaui.framework   dvaui   11.1.0.0
             dvaunittesting.framework   dvaunittesting   11.1.0.0
             dynamiclink.framework   dynamiclink   11.1.0.0
             ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
             ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
             ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
             LogSession.framework   LogSession   7.4.1.60.45263
             manta.framework   manta   2.0.00.1   1.
             mediacoreif.framework   mediacoreif   11.1.0.0
             PlugPlugExternalObject.framework      8.0.0.55
             PlugPlugOwl.framework   PlugPlugOwl   8.0.0.55
             UpdaterNotifications.framework   UpdaterNotifications   10.0.0.1   "10.0.0.1"
             WRServices.framework
          Required plug-ins:
             3D Studio 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
             Accented Edges 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Adaptive Wide Angle 19.0.1, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
             Angled Strokes 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Average 19.0  ©1993-2017 Adobe Systems Incorporated - from the file “Average.plugin”
             Bas Relief 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             BMP 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Camera Raw 10.0 (827), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
             Camera Raw Filter 10.0 (827), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
             Chalk & Charcoal 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Chrome 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Cineon 19.0  ©2002-2017 Adobe Systems Incorporated - from the file “Cineon.plugin”
             Clouds 19.0  ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
             Collada DAE 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
             Color Halftone 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Colored Pencil 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             CompuServe GIF 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Conté Crayon 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Craquelure 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Crop and Straighten Photos 19.0  Copyright © 2003-2017 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
             Crop and Straighten Photos Filter 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Crosshatch 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Crystallize 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Cutout 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Dark Strokes 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             De-Interlace 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Dicom 19.0.1, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “dicom.plugin”
             Difference Clouds 19.0  ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
             Diffuse Glow 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Displace 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Dry Brush 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Eazel Acquire 19.0  Copyright © 2007-2017 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
             Entropy 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
             Export Color Lookup Tables 19.0  Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
             Extrude 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             FastCore Routines 19.0  ©1990-2017 Adobe Systems Incorporated - from the file “FastCore.plugin”
             Fibers 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Film Grain 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Filter Gallery 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Flash 3D 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
             Fresco 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Glass 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Glowing Edges 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Google Earth 4 KMZ 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
             Graphic Pen 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Halftone Pattern 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Halide Bottlenecks 19.0  Copyright © 2017 Adobe Systems Incorporated - from the file “HalideBottlenecks.plugin”
             HDRMergeUI 19.0.1, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
             HSB/HSL 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             IFF Format 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             IGES 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
             Ink Outlines 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             JPEG 2000 19.0  Copyright © 2001-2017 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
             Kurtosis 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
             Lens Blur 19.0.1, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
             Lens Correction 19.0.1, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
             Lens Flare 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Liquify 19.0.1, Copyright © 2001-2017 Adobe Systems Incorporated - from the file “Liquify.plugin”
             Matlab Operation 19.0  ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
             Maximum 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
             Mean 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
             Measurement Core 19.0  Copyright © 1993-2017 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
             Median 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
             Mezzotint 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Minimum 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
             MMXCore Routines 19.0  ©1990-2017 Adobe Systems Incorporated - from the file “MMXCore.plugin”
             Mosaic Tiles 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Multiprocessor Support 19.0  Copyright © 1990-2017 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
             Neon Glow 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Note Paper 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             NTSC Colors 19.0  ©1993-2017 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
             Ocean Ripple 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             OpenEXR 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Paint Daubs 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Palette Knife 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Patchwork 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Paths to Illustrator 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             PCX 19.0  ©1989-2017 Adobe Systems Incorporated - from the file “PCX.plugin”
             Photocopy 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Photoshop 3D Engine 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
             Photoshop Touch Copyright ©2013-2017 Adobe Systems Incorporated - from the file “PSDX.plugin”
             Picture Package Filter 19.0  ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
             Pinch 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Pixar 19.0  ©1989-2017 Adobe Systems Incorporated - from the file “Pixar.plugin”
             Plaster 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Plastic Wrap 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             PLY 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
             Pointillize 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Polar Coordinates 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Portable Bit Map 19.0  ©1989-2017 Adobe Systems Incorporated - from the file “PBM.plugin”
             Poster Edges 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             PRC 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
             Radial Blur 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Radiance 19.0  ©2003-2017 Adobe Systems Incorporated - from the file “Radiance.plugin”
             Range 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
             Render Color Lookup Grid 19.0  Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
             Reticulation 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Ripple 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Rough Pastels 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Save for Web 19.0.1, Copyright © 1999-2017 Adobe Systems Incorporated - from the file “Save for Web.plugin”
             ScriptingSupport 19.0, Copyright © 2017 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
             Shake Reduction 19.0.1, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
             Shear 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Skewness 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
             Smart Blur 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Smudge Stick 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Solarize 19.0  Copyright © 1993-2017 Adobe Systems Incorporated - from the file “Solarize.plugin”
             Spaces 19.0, Copyright © 2017 Adobe Systems Incorporated - from the file “Spaces.plugin”
             Spatter 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Spherize 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Sponge 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Sprayed Strokes 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Stained Glass 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Stamp 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Standard Deviation 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
             STL 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
             Sumi-e 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Summation 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
             Targa 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Texturizer 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Tiles 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Torn Edges 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Twirl 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             U3D 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
             Underpainting 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Vanishing Point 19.0.1, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
             Variance 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
             Virtual Reality Modeling Language | VRML 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
             Water Paper 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Watercolor 19.0.1, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
             Wave 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Wavefront|OBJ 19.0  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
             Wind 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
             Wireless Bitmap 19.0  ©1989-2017 Adobe Systems Incorporated - from the file “WBMP.plugin”
             ZigZag 19.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
          Optional and third party plug-ins: NONE
          Duplicate and Disabled plug-ins: NONE
          Plug-ins that failed to load: NONE
          Extensions:
             com.adobe.Butler.backend  2.0.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.Butler.backend/index.html”
             com.adobe.inapp.purchase  2.11.27 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/purchase.html ”
             New Document  2.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.ccx.fnft/fnft.html”
             Libraries  2.11.27 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/index.html”
             Start  2.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html”
             Space Equal  1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.uebele.eqspace/index.html”
             Adobe Color Themes  6.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
             Export As  3.0.13 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
             Shutterstock  1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.shutterstock/index.html”
          Installed TWAIN devices: NONE
