Hello, I am trying to upload a SCORM file to my LMS platform MATRIX, and I have not had any problems before but with this one file it wont upload. This is the email info that I recieve. But i dont understand what needs changing to upload it. Any ideas? Thanks
An exception occurred during the import:
Cannot find the SCORM manifest file 'imsmanifest.xml' in the archive. Please check it's a SCORM module.
/home/edu20/releases/20171121184706/app/models/import_scorm_job.rb:84:in `process_module'
/home/edu20/releases/20171121184706/app/models/import_scorm_section_job.rb:18:in `process_module'
/home/edu20/releases/20171121184706/app/models/import_scorm_job.rb:24:in `block in run'
/home/edu20/shared/bundle/ruby/1.9.1/gems/activerecord-3.0.20/lib/active_record/connection_adapters/abstract/database_statements.rb:139:in `transaction'
/home/edu20/shared/bundle/ruby/1.9.1/gems/activerecord-3.0.20/lib/active_record/transactions.rb:207:in `transaction'
/home/edu20/releases/20171121184706/app/models/import_scorm_job.rb:23:in `run'
(eval):3:in `block in run_with_newrelic_transaction_trace'
/home/edu20/shared/bundle/ruby/1.9.1/gems/newrelic_rpm-3.12.1.298/lib/new_relic/agent/instrumentation/controller_instrumentation.rb:361:in `perform_action_with_newrelic_trace'
(eval):2:in `run_with_newrelic_transaction_trace'
/home/edu20/releases/20171121184706/app/models/job_server.rb:163:in `run_job'
(eval):3:in `block in run_job_with_newrelic_transaction_trace'
(eval):2:in `run_job_with_newrelic_transaction_trace'
/home/edu20/releases/20171121184706/app/models/job_server.rb:107:in `run'
script/run_jobs.rb:61:in `
Agreed. In the past, I've seen double-zipped SCORM files - or zip files that have zipped-up the folder, not the folder contents in the root.
So poster, check this .zip carefully.
Is there just one folder inside? If so, the folder was .zipped, not the contents.
Or is there a .zip inside a .zip?
You *should* see a few folders and a few files inside that .zip, and one of those files should be the 'imsmanifest.xml', right at the root.
It appears your imsmanifest.xml is not in the root of the zip package.
Did you set up the Reporting in that file?
No!! This was the problem. Many thanks
OK, you forgot to set up reporting, that means you'll not have a SCO.
