7 Replies Latest reply on Nov 30, 2017 9:00 AM by LeoTaro
    Problem in PutFileDialog and GetFileDialog
    selvakkanit19061983 Level 1
      I have been migrated source from CS4 to CC2018.
      Os: mac 10.13.1
      AIFileDialogFilters ops;
      sAIUser->PutFileDialog(ai::UnicodeString(Title), &ops, ai::UnicodeString(csvFileName), outCSVFile);
      sAIUser->GetFileDialog(ai::UnicodeString(Title), &ops, outCSVFile);
      I have problem in above code snippet. There is no dialog will opened.
      And I tried to set filter of *.csv files.
      But it run correctly in Windows machine.
      How can I set filter to this function?
      Or any other possible cases available to replace this function?
      Regards,
      Sandy
        • 1. Re: Problem in PutFileDialog and GetFileDialog
          LeoTaro Level 4
          This code works for me on CC 2018 on mac:
                  AIFileDialogFilters filter;
                  filter.AddFilter(ai::UnicodeString("*.ai"));
                  filter.AddFilter(ai::UnicodeString("*.*"));
                  ai::UnicodeString path("/Users/Shared");
                  ai::FilePath fp(path);
                  sAIUser->PutFileDialog(ai::UnicodeString("Save File"),&filter,ai::UnicodeString("MyFile.ai"),fp);
          • 2. Re: Problem in PutFileDialog and GetFileDialog
            Thank you for your reply,
            Your code works but, the dialog opens and disappear automatically in fractions of seconds and Illustrator has no responds for any other input. I will quit illustrator by Force Quit... option. Is any other process to do after this snippet?
            There is same problem for following snippet,
            sAIUser->GetFileDialog(ai::UnicodeString("Save File"),&filter, fp);
            regards,
            Sandy
            • 3. Re: Problem in PutFileDialog and GetFileDialog
              LeoTaro Level 4
              It works fine for me. When do you call this code? What else is your plugin doing?
              • 4. Re: Problem in PutFileDialog and GetFileDialog
                fPPLib.AddEventListener(EVENT_TYPE_OK_CLICKED, OkClickedFunc, this);
                static void OkClickedFunc(const csxs::event::Event* const eventParam, void* const context)
                    AIErr erstatus=sAIUser->PutFileDialog(ai::UnicodeString("Save File"),&filter,ai::UnicodeString("MyFile.ai"),fp);
                It doesn't work in Event Listener function.
                Other than its work fine.
                • 5. Re: Problem in PutFileDialog and GetFileDialog
                  LeoTaro Level 4
                  You need to set the app context if your code is not called from a plugin message
                      AppContext appContext(pluginRef);
                  • 6. Re: Problem in PutFileDialog and GetFileDialog
                    Thank you for your replay,
                    But your code yet not work.
                    I will attached Project with your code.
                    FreeGrid.zip - Google Drive
                    Copy this code in sample codes in Adobe Illustrator CC 2018 SDK.
                    Please check the code.
                    Run the plugin by following steps,
                    1. Choose Windows->SDK->FreeGrid
                    2. Press the “Transform” button in bottom of dialog.
                    Then you got an issue.
                    But, I will add this code as follows,
                    freeGridController->UnloadExtension();
                    Then only PutFileDialog dialog will displayed, but freeGridController dialog didn’t close because, I will UnloadExtension().
                    Is this correct process?
                    Is any other possible ways to display PutFileDialog dialog and close freeGridController dialog?
                    • 7. Re: Problem in PutFileDialog and GetFileDialog
                      LeoTaro Level 4
                      I can give you advice and answer questions. I don't have time to debug your code for you.
                      I see you are calling PutFileDialog from a csxs event callback. I have had problems before with showing popups while a panel is open. You could try unloading the extension in the callback and then setting a zero timer to call your code that calls PutFileDialog.
