1 Reply Latest reply on Nov 24, 2017 2:53 AM by davescm
    Convert Semi-Transparent Pixels to Fully Opaque
    johnt53984649 Level 2
      Suppose I have a layer in Photoshop containing completely transparent, semi-transparent, and fully opaque pixels.  Now, suppose my goal is to keep all fully opaque pixels identical, convert all semi-transparent pixels to fully opaque, and keep all completely transparent pixels identical.
      One way that I've found I can do this is by duplicating the layer around 20 to 30 times and then merging them all together, but I need a way to automate this process in a Photoshop script for hundreds and hundreds of layers, so making that many copies is extremely inefficient and will waste a lot of time.
      Is there a simpler, faster way to achieve this, preferably something I can use easily in a .jsx Photoshop script?
        • 1. Re: Convert Semi-Transparent Pixels to Fully Opaque
          davescm Adobe Community Professional
          Hi
          You could record an action with the following steps
          1. Layer > Layer Mask >From Transparency    (this creates a mask from the transparency and selects the mask)
          2. Image adjustment threshold 1                       (this changes the mask to only leave the fully transparent pixels)
          3. Apply Layer Mask                                          (this applies the mask to the layer )
          Recorded it looks like this :
          Then it is just select the layer and run the action - which you could build into a larger action or a batch process
          Dave
