1 2 3 4 Previous Next 144 Replies Latest reply on Jul 17, 2018 6:57 PM by rosem60269785 Branched to a new discussion.
    Photoshop 2018 Memory Issue
    klausd52593774 Level 1
      when i try to go to preferences > performance i get this error
      An integer between 96 ans 8 is required: Closest value is inserted.
      i can open files but i can´t work with the file ... memory error
      everything worked fine befor i upgraded to 2018
      Adobe Photoshop Version: 19.0 20171103.r.190 2017/11/03: 1143799  x64
      Number of Launches: 1
      Operating System: Windows 10 64-bit
      Version: 10 or greater 10.0.16299.15
      System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
      Physical processor count: 16
      Logical processor count: 32
      Processor speed: 2610 MHz
      Built-in memory: 32717 MB
      Free memory: 2 MB
      Memory available to Photoshop: 8 MB
      Memory used by Photoshop: 100 %
      Surface Dial: Enabled.
      Alias Layers: Disabled.
      Modifier Palette: Enabled.
      Highbeam: Enabled.
      Image tile size: 128K
      Image cache levels: 4
      Font Preview: Medium
      TextComposer: Latin
      Display: 1
      Display Bounds: top=0, left=0, bottom=1440, right=2560
      Display: 2
      Display Bounds: top=0, left=2560, bottom=1440, right=5120
      OpenGL Drawing: Enabled.
      OpenGL Allow Old GPUs: Not Detected.
      OpenGL Drawing Mode: Advanced
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: True.
      AIFCoreInitialized=1
      AIFOGLInitialized=1
      OGLContextCreated=1
      NumGLGPUs=1
      NumCLGPUs=1
      NumNativeGPUs=0
      glgpu[0].GLVersion="4.1"
      glgpu[0].IsIntegratedGLGPU=0
      glgpu[0].GLMemoryMB=6144
      glgpu[0].GLName="NVIDIA GeForce GTX 980 Ti"
      glgpu[0].GLVendor="NVIDIA Corporation"
      glgpu[0].GLVendorID=4318
      glgpu[0].GLDriverVersion="23.21.13.8831"
      glgpu[0].GLRectTextureSize=16384
      glgpu[0].GLRenderer="GeForce GTX 980 Ti/PCIe/SSE2"
      glgpu[0].GLRendererID=6088
      glgpu[0].HasGLNPOTSupport=1
      glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_c791f 781cd94491f\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64 _c791f781cd94491f\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf _amd64_c791f781cd94491f\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dis pi.inf_amd64_c791f781cd94491f\nvldumdx.dll"
      glgpu[0].GLDriverDate="20171114000000.000000-000"
      glgpu[0].CanCompileProgramGLSL=1
      glgpu[0].GLFrameBufferOK=1
      glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
      glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
      glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
      glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
      glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
      glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
      glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
      glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
      clgpu[0].CLPlatformVersion="1.2"
      clgpu[0].CLDeviceVersion="1.2 CUDA"
      clgpu[0].IsIntegratedCLGPU=0
      clgpu[0].CLMemoryMB=6144
      clgpu[0].CLName="GeForce GTX 980 Ti"
      clgpu[0].CLVendor="NVIDIA Corporation"
      clgpu[0].CLVendorID=4318
      clgpu[0].CLDriverVersion="388.31"
      clgpu[0].CLBandwidth=2.39998e+11
      clgpu[0].CLCompute=2333.18
      License Type: Subscription
      Serial number: xxxxxxxxxxxxxxx
      GUIDBucket:
      Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
      Temporary file path: C:\Users\Xeon\AppData\Local\Temp\
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        Startup, 237,5G, 45,1G free
      Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
      Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
      Serial number removed by moderator. This is a public forum.
