Hello Premiere users,
Our broadcasting standard requires that the audio in an MXF file is WAV/PCM encoded, and BWF or BWAV wrapped. No matter what we try, Premiere / Media Encoder seems to always export the audio wrapped as aes3 which causes our QA system to throw up an alert.
Is there a way to export the audio with the wrapping mode BWF, not AES?
FYI we export in Premiere to MXF(op1a) XDCAM50. The audio defaults to "uncompressed" with no other available options.
Any help would be appreciated!
if you export as a quicktime, you can embed the output file with BWF audio metadata and then use another program to encode the video for QA.
