1 Reply Latest reply on May 8, 2008 6:51 PM by Henk2
    large xml model
    lsOz
      I have a big performance problem using an xml based model for my air application. The model has grown up to a couple of hundred kilobytes and is used by the GUI via bindings and also as input and output for various calculations and that's where the performance gets real ugly.
      I did some simple tests and it seems that reading the values from the xml model is not an expensive operation but to write them back (set) is taking up 80 - 90 % of the time. What can I do?
      Use smaller xml blocks? Use ArrayCollections instead of xml as model? Any other idea?
      Help is very appreciated since I'm running out of time. Thanks!
      Lars
        • 1. Re: large xml model
          Henk2
          I recommend running the profiler to identify what operation is so expensive. Once that is determine you might find another way of doing the same thing.
          Without more details its hard to say.
