13 Replies Latest reply on Nov 27, 2017 4:31 AM by Dave Merchant
    javascript obfuscator
    medos20 Level 1
      I was wondering about protecting my JavaScript Code inside pdf- should i copy every code to obfuscator Software or i can do it one time? any suggestion to powerful protection of my pdf or my code ? thanks in advance
        • 1. Re: javascript obfuscator
          Give up Is my advice. It’s inherently unprotectable.
          • 2. Re: javascript obfuscator
            Thom Parker Adobe Community Professional
            An obsfucator can be helpful to hide code, but it doesn't provide any real protection.
            Many obsfucators are designed to be used with HTML JavaScript, and so will not work Acrobat JavaScript, be careful which one you use.
            You'll need to obsfucate each script separately. The "Edit all scripts" options in Acrobat displays all event scripts mixed with XML markers for putting all the script back where they belong. So this code listing cannot be obsfucated without destroying the XML structure.
            • 3. Re: javascript obfuscator
              medos20 Level 1
              what about this website ? does it compatible with acrobat ?
              http://www.javascriptobfuscator.com/?jsov=2.34
              • 4. Re: javascript obfuscator
                Karl Heinz Kremer Adobe Community Professional
                This is something you have to figure out. As you've probably figured, none of us experts are using these tools, which means that we don't know if this particular tool will produce code that works within Acrobat.
                • 5. Re: javascript obfuscator
                  Joel_Geraci Adobe Community Professional
                  Not necessarily true. I use https://jscompress.com/ and the results seem to work just fine in Acrobat.
                  • 6. Re: javascript obfuscator
                    medos20 Level 1
                    i tried something by accident and that was for distribution that add kind of heavy protection without password, even i test the protection that prevent me to change my document or even access my code and i failed also i tried to crack the password that is not even exist and the document property tells me its not allowed to change the document or Document assemble, in first time in using acrobat i feel it really secured.
                    • 7. Re: javascript obfuscator
                      medos20 Level 1
                      but if you don't use this tools as an expert, how could you protect your hard work in coding ? did you alter the PDF file itself with some kind of HEX editor, any advice? most of modern password cracking technology able to easily crack most protected pdf files!.
                      • 8. Re: javascript obfuscator
                        JR_Boulay Adobe Community Professional
                        Hi.
                        This one works fine with Acrobat* 9 to DC: http://www.javascriptobfuscator.com/Javascript-Obfuscator.aspx
                        This one works with Acrobat* XI and DC: https://javascript-obfuscator.org/#intro-sub-2
                        Beware that some corporate networks routinely reject obfuscated PDF documents, and beware that an antivirus detects obfuscated PDF documents as "false positives". I had some issues with Avast…
                        * Reader, Pro and Standard
                        • 9. Re: javascript obfuscator
                          There is no 100% protection.
                          The goal is to make it long and laborious to recover the existing code and thus faster to create a new code from scratch.
                          One can also create false functions, tortuous functions or unnecessarily complicated ones. Do not forget to delete the comments and to minify the script.
                          • 10. Re: javascript obfuscator
                            I rarely use PDF "protections" for this reason, they are OK for grandmas but they are not serious.
                            When I want to avoid inadvertent changes I just save as "Reader Extended".
                            • 11. Re: javascript obfuscator
                              Dave Merchant MVP & Adobe Community Professional
                              Obfuscation was used for years by Adobe themselves, back when they sold Acrobat 3D - the injected code to manipulate and animate the 3D scene was obfuscated by a routine that Right Hemisphere supplied.
                              However, it's important to remember that JavaScript is an interpreted language; most obfuscators work by creating a wrapper function which reads a section of encrypted text, converts it back into 'real' code, then executes it with the eval() function. That is why antivirus software hates it, but it's relatively simple to copy the script and run it in an external compiler to capture the de-obfuscated version. You won't get all your variable names and line breaks back, but it'll be understandable to a JS programmer. It also doesn't necessarily need to be decrypted; if someone simply wants to take your script and use it in another document as-is, they can copy the obfuscated version. Everything in the structure of a PDF file is accessible to the recipients of a document unless you use rights management protection. Most third-party PDF software ignores the password/certificate 'restrictions' applied in Acrobat, which is why you get the big warning message the first time you try to apply it.
                              Other Adobe products support 'Binary JavaScript' (JSXBIN) which is a lot harder to turn back into human-readable text, however the PDF ISO standard does not allow that type of code.
                              2 people found this helpful
                              • 12. Re: javascript obfuscator
                                Of course if it were in the ISO standard the details would have to be completely public, so it would immediately cease to have any protection element...
                                • 13. Re: javascript obfuscator
                                  Not necessarily; SWF content is permitted by Adobe's extension clauses, and the Flash Player source code isn't published. It is theoretically possible to include a definition that permits JSXBIN but only defines the concept of requiring 'a compatible interpreter' to run it. Not going to happen of course, Adobe has stopped tweaking the standards and a document that needs a proprietary handler will break the (now dominant) third party PDF engines in Web browsers etc.
                                  If a PDF file's scripting is so valuable that you cannot possibly allow anyone to inspect the source code, then the only option is DRM (using Adobe's LiveCycle suite). Massively expensive to deploy, but as yet unbroken. Gov/Mil customers trust it.
