7 Replies Latest reply on Jan 14, 2018 1:47 PM by Asymetrical
    New surface pro drawing bug / straight lines bug in AnimateCC
    dbs1029 Level 1
      I am using 'New Surface Pro' (i7 / 8GB / 256GB)
      I'm using the latest version of 'animated CC' Version 18.0 (Build 107)
      When using an Animate CC with Surface Pro "pen" in New Surface Pro,
      There is a bug where all drawings a straight line. When drawing a small range with a pen, I think that input is impossible.
      I suspect an animated CC bug that occurs when using the pen
      because the mouse does not have any problems when drawing a small range, and is not a problem with any other program.
      Quickly touch the pen and you will see an input bug in the animated CC.
      There is also a bug that does not apply to pressure.
      When I turn on the pressure function in the toolbox and draw a picture, the pressure does not apply.
      I think it is an animated CC bug because I think that there is no problem in other programs.
      When using Cintiq (13HD) on the desktop, the pressure is applied well. and there are no drawing straight bugs.
      There is a problem only when you use a surface pen in an animated CC.
      I know there are a lot of people who are having problems like me.
      (Surface Pro 4 or New Surface Pro)
      I would like to know the solution to this problem. T_T
