Hi - thanks in advance for reading. I am using Captivate 2017.
I have a file in which every slide is set to 3 seconds as standard. I want to add prerecorded audio over a number of slides and then adjust the timing to match the audio. I'm clearly doing something wrong but I don't know what.
I go to Slide 4 which has a duration of 3 seconds and a mouse object of 1 second (starting at 2 seconds).
I go to Audio, Import to... Slide and then choose my audio file which is 51 seconds.
I select Distribute the audio file over several slides.
The Slides Audio box appears and I can see the wav file. I turn on Preview.
When I scroll to the right I can see my markers for my other slides. Slide 5 starts after the audio file finishes. I cannot Move Slide 5 marker to the left because it says I have reached the minimum display time for Slide 4.
But Slide 4 originally had a duration of 3 seconds until I added the audio. So I'm at a loss as to how I move the markers to make the audio play over the slides I want.
I hope the above is enough info but please let me know if you need any further info. Thank you.
Ok I'm an idiot and it seems I just need to select the slides I want to add the audio to (rather than just having one slide selected in the filmstript).
If I save and then make further changes to my project but want to go back to the screen where I could edit where the audio markers were - how do I do that please?
