4 Replies Latest reply on Nov 28, 2017 8:03 AM by milanh33586006
    3D troubles in new update of Photoshop
    milanh33586006
      Hello there,
      I have big troubles after last Photoshop update (Adobe Photoshop verze: 19.0 20171103.r.190 2017/11/03: 1143799  x64).
      When I open 3D models created by older version and try to rotate or move with camera, everything disappear and complete 3D scene is destroyed. When I have luck, I find this model, but the model is completelly on different place in different possition. It drives me crazy, because I have many scenes already prepared and I can't make everything from zero. Do someone has the same problém? Could someone help me to fix this problem?
      Thanks in advance, M.
      After little moving by camera, sudenly model disappear and when I find it, it's completelly away, with different materials and other crazy things :/
        • 1. Re: 3D troubles in new update of Photoshop
          davescm Adobe Community Professional
          No I am not seeing any changes opening 3D images or objects created in older versions. How did you save it - as a PSD or as a 3D object (if so - in what format)?
          Dave
          • 2. Re: 3D troubles in new update of Photoshop
            milanh33586006 Level 1
            I'm saving it as PSD file. Now I tried to install back older version CC (2017) and there is everything perfect. So it really seems to be problem of newest update. If this problem won't be fixed, I'll have to keep this CC (2017) version. But maybe I'm loosing some new functions ... Thank you, Milan
            • 3. Re: 3D troubles in new update of Photoshop
              What you describe is not normal. I have CC(2018) v19.0.1 installed here (as well as CC2017 and CS6) and all work fine. Try re-installing and resetting preferences (sometimes preferences carried forward from the previous version can cause issues).
              Also post your system info from Photoshop> Help> System Info>Copy
              Dave
              • 4. Re: 3D troubles in new update of Photoshop
                Počet spuštění: 293
                Operační systém: Windows 7 (64bitová verze)
                Verze: 7 SP1 6.1.7601.23915
                Systémová architektura: řada CPU Intel: 6, model: 12, taktování: 3 s MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                Počet fyzických procesorů: 4
                Počet logických procesorů: 8
                Rychlost procesoru: 2793 MHz
                Vestavěná paměť: 32683 MB
                Volná paměť: 17367 MB
                Paměť dostupná pro Photoshop: 29493 MB
                Paměť používaná Photoshopem: 60 %
                Surface Dial: Zapnuto.
                Vrstvy aliasů: Vypnuto.
                Paleta modifikátorů: Vypnuto.
                Dálkový paprsek: Zapnuto.
                Velikost vyrovnávací paměti dlaždice: 132 kB
                Úrovní vyrovnávací paměti pro obrazy: 4
                Náhled písma: Střední
                Algoritmus sazby textu: Latinka
                Dne 16.2.2017 v 12:25:11 (ReallocateSharedGLResources) došlo k chybě počítače Photoshop.
                Zobrazení: 1
                Hranice zobrazení: horní= 0, vlevo= 0, spodní= 1200, vpravo= 1920
                Zobrazení: 2
                Hranice zobrazení: horní= 0, vlevo= 1920, spodní= 1080, vpravo= 3840
                Kreslení OpenGL: Zapnuto.
                OpenGL - povolit staré GPU: Nezjištěno.
                Režim kreslení OpenGL: Základní
                OpenGL - povolit normální režim: True.
                OpenGL - povolit pokročilý režim: True.
                AIFCoreInitialized=1
                AIFOGLInitialized=1
                OGLContextCreated=1
                NumGLGPUs=1
                NumCLGPUs=1
                NumNativeGPUs=0
                glgpu[0].GLVersion="4.1"
                glgpu[0].IsIntegratedGLGPU=0
                glgpu[0].GLMemoryMB=2048
                glgpu[0].GLName="NVIDIA Quadro K2100M"
                glgpu[0].GLVendor="NVIDIA Corporation"
                glgpu[0].GLVendorID=4318
                glgpu[0].GLDriverVersion="22.21.13.8573"
                glgpu[0].GLRectTextureSize=16384
                glgpu[0].GLRenderer="Quadro K2100M/PCIe/SSE2"
                glgpu[0].GLRendererID=4604
                glgpu[0].HasGLNPOTSupport=1
                glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
                glgpu[0].GLDriverDate="20170925000000.000000-000"
                glgpu[0].CanCompileProgramGLSL=1
                glgpu[0].GLFrameBufferOK=1
                glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
                glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                clgpu[0].CLPlatformVersion="1.2"
                clgpu[0].CLDeviceVersion="1.2 CUDA"
                clgpu[0].IsIntegratedCLGPU=0
                clgpu[0].CLMemoryMB=2048
                clgpu[0].CLName="Quadro K2100M"
                clgpu[0].CLVendor="NVIDIA Corporation"
                clgpu[0].CLVendorID=4318
                clgpu[0].CLDriverVersion="385.73"
                clgpu[0].CLBandwidth=3.52945e+10
                clgpu[0].CLCompute=207.513
                Typ licence: Předplatné
                Sériové číslo: 94070633676087096177
                GUIDBucket:
                Složka aplikace: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
                Photoshop odkládá s použitím asynchronního I/O zapnuto
                Odkládací disk(y):
                    C:\, 458,0 GB, 74,4 GB volného
                Složka vyžadovaných zásuvných modulů: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
                Primární složka zásuvných modulů: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
                Nainstalované komponenty:
                   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                   ACE.dll   ACE 2017/09/19-18:51:44   79.586793   79.586793
                   AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                   AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                   AdobeOwl.dll   Adobe Owl   5.2.11
                   AdobePDFL.dll   PDFL 2017/09/01-01:08:01   79.239219   79.239219
                   AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
                   AdobeSVGAGM.dll   AdobeSVGAGM   79.586793   79.586793
                   AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
                   AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924   79.160924
                   AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924   79.160924
                   adobe_caps.dll   Adobe CAPS   10,0,0,6
                   AGM.dll   AGM 2017/09/19-18:51:44   79.586793   79.586793
                   ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
                   AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                   amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
                   ARE.dll   ARE 2017/09/19-18:51:44   79.586793   79.586793
                   AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                   AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                   Bib.dll   BIB 2017/09/19-18:51:44   79.586793   79.586793
                   BIBUtils.dll   BIBUtils 2017/09/19-18:51:44   79.586793   79.586793
                   boost_date_time.dll   photoshopdva   11.1.0
                   boost_filesystem.dll   photoshopdva   11.1.0
                   boost_signals.dll   photoshopdva   11.1.0
                   boost_system.dll   photoshopdva   11.1.0
                   boost_threads.dll   photoshopdva   11.1.0
                   cg.dll   NVIDIA Cg Runtime   3.0.00007
                   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                   CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                   CoolType.dll   CoolType 2017/09/19-18:51:44   79.586793   79.586793
                   CRClient.dll   Adobe Crash Reporter Client DLL   1.6.1.0
                   dnssd.dll   Bonjour   3,0,0,2
                   dvaaudiodevice.dll   photoshopdva   11.1.0
                   dvacore.dll   photoshopdva   11.1.0
                   dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                   dvamarshal.dll   photoshopdva   11.1.0
                   dvamediatypes.dll   photoshopdva   11.1.0
                   dvametadata.dll   photoshopdva   11.1.0
                   dvametadataapi.dll   photoshopdva   11.1.0
                   dvametadataui.dll   photoshopdva   11.1.0
                   dvaplayer.dll   photoshopdva   11.1.0
                   dvatransport.dll   photoshopdva   11.1.0
                   dvaui.dll   photoshopdva   11.1.0
                   dvaunittesting.dll   photoshopdva   11.1.0
                   dynamiclink.dll   photoshopdva   11.1.0
                   ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1133690   81.1133690
                   icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                   icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                   icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                   igestep30.dll   IGES Reader   9.3.0.113
                   imslib.dll   IMSLib DLL   10.0.0.22
                   JP2KLib.dll   JP2KLib 2017/08/23-01:11:25   79.267771   79.267771
                   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                   libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
                   LogSession.dll   LogSession   7.4.1.60.45263
                   mediacoreif.dll   photoshopdva   11.1.0
                   MPS.dll   MPS 2017/09/01-01:08:01   79.586120   79.586120
                   pdfsettings.dll   Adobe PDFSettings   1.04
                   Photoshop.dll   Adobe Photoshop CC 2018   19.0
                   Plugin.dll   Adobe Photoshop CC 2018   19.0
                   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   8.0.0
                   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   8.0.0.55
                   PSArt.dll   Adobe Photoshop CC 2018   19.0
                   PSCloud.dll                                                   1.0.0.1
                   PSViews.dll   Adobe Photoshop CC 2018   19.0
                   SCCore.dll   ScCore 2017/08/31-12:13:14   81.1133690   81.1133690
                   SVGRE.dll   SVGRE   79.586793   79.586793
                   svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
                   tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
                   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
                   TfFontMgr.dll   FontMgr   9.3.0.113
                   TfKernel.dll   Kernel   9.3.0.113
                   TFKGEOM.dll   Kernel Geom   9.3.0.113
                   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                   updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                   VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                   VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                   WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
                   wu3d.dll   U3D Writer   9.3.0.113
                Vyžadované zásuvné moduly:
                   3D Studio 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “U3D.8bi”
                   Adaptivní široký úhel 19.0 – ze souboru “Adaptive Wide Angle.8bf”
                   Akvarel 19.0 – ze souboru “Filter Gallery.8bf”
                   Asymetrie 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “statistics.8ba”
                   Barevné pastelky 19.0 – ze souboru “Filter Gallery.8bf”
                   Barevný polotón 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Basreliéf 19.0 – ze souboru “Filter Gallery.8bf”
                   BMP 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Camera Raw 10.0 – ze souboru “Camera Raw.8bi”
                   Cesty do Illustratoru 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Chróm 19.0 – ze souboru “Filter Gallery.8bf”
                   Cikcak 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Cineon 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “Cineon.8bi”
                   Collada 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “U3D.8bi”
                   CompuServe GIF 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Conté pastel 19.0 – ze souboru “Filter Gallery.8bf”
                   Dicom 19.0 – ze souboru “Dicom.8bi”
                   Dlaždice 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Dopisní papír 19.0 – ze souboru “Filter Gallery.8bf”
                   Eazel Acquire 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “EazelAcquire.8ba”
                   Entropie 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “statistics.8ba”
                   Exportovat vyhledávací tabulky barev 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “Export3DLUT.8be”
                   FastCore podprogramy 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “FastCore.8bx”
                   Filtr Camera Raw 10.0 – ze souboru “Camera Raw.8bi”
                   Filtr Oříznout a narovnat fotografie 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Filtr Sada obrazů 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “ChannelPort.8bf”
                   Flash 3D 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “U3D.8bi”
                   Formát IFF 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Fotokopie 19.0 – ze souboru “Filter Gallery.8bf”
                   Freska 19.0 – ze souboru “Filter Gallery.8bf”
                   Galerie filtrů 19.0 – ze souboru “Filter Gallery.8bf”
                   Google Earth 4 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “U3D.8bi”
                   Halide Bottlenecks 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “HalideBottlenecks.8bx”
                   HDRMergeUI 19.0 – ze souboru “HDRMergeUI.8bf”
                   Houba 19.0 – ze souboru “Filter Gallery.8bf”
                   Hrubé pastely 19.0 – ze souboru “Filter Gallery.8bf”
                   HSB/HSL 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   IGES 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “U3D.8bi”
                   Inkoustové obrysy 19.0 – ze souboru “Filter Gallery.8bf”
                   Inteligentní rozostření 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Jádro měření 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “MeasurementCore.8me”
                   Jazyk VRML (Virtual Reality Modeling Language) | VRML 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “U3D.8bi”
                   JPEG 2000 19.0 – ze souboru “JPEG2000.8bi”
                   Korekce objektivu 19.0 – ze souboru “Lens Correction.8bf”
                   Křída a uhel 19.0 – ze souboru “Filter Gallery.8bf”
                   Kruhové rozostření 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Krystalizace 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Malířská špachtle 19.0 – ze souboru “Filter Gallery.8bf”
                   Matlab Operation 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “ChannelPort.8bf”
                   Maximum 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “statistics.8ba”
                   Medián 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “statistics.8ba”
                   Mezzotinta 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Minimum 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “statistics.8ba”
                   Míra fluktuace 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “statistics.8ba”
                   MMXCore podprogramy 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “MMXCore.8bx”
                   Modul Photoshop 3D 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “Photoshop3DEngine.8bi”
                   Mozaikové dlaždice 19.0 – ze souboru “Filter Gallery.8bf”
                   Mozaikové okno 19.0 – ze souboru “Filter Gallery.8bf”
                   Multiprocesorová podpora 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “MultiProcessor Support.8bx”
                   Nastříkané tahy 19.0 – ze souboru “Filter Gallery.8bf”
                   Neónová záře 19.0 – ze souboru “Filter Gallery.8bf”
                   NTSC barvy 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “NTSC Colors.8bf”
                   Oblaka 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “Clouds.8bf”
                   Odečíst oblaka 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “Clouds.8bf”
                   Odlesk objektivu 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Odstranit prokládání 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   OpenEXR 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Oříznout a narovnat fotografie 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “CropPhotosAuto.8li”
                   Otisk 19.0 – ze souboru “Filter Gallery.8bf”
                   PCX 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “PCX.8bi”
                   Photoshop Touch 19.0 – ze souboru “PSDX.8bi”
                   Pixar 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “Pixar.8bi”
                   Plakátové obrysy 19.0 – ze souboru “Filter Gallery.8bf”
                   Plastikový obal 19.0 – ze souboru “Filter Gallery.8bf”
                   PLY 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “U3D.8bi”
                   Podmalba 19.0 – ze souboru “Filter Gallery.8bf”
                   Podpora skriptování 19.0 – ze souboru “ScriptingSupport.8li”
                   Podpora WIA 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “WIASupport.8li”
                   Pointilizace 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Polární souřadnice 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Polotónový vzorek 19.0 – ze souboru “Filter Gallery.8bf”
                   Portable Bit Map 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “PBM.8bi”
                   Postřik 19.0 – ze souboru “Filter Gallery.8bf”
                   Potrhané obrysy 19.0 – ze souboru “Filter Gallery.8bf”
                   Praskliny 19.0 – ze souboru “Filter Gallery.8bf”
                   PRC 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “U3D.8bi”
                   Přestavět 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Prohnutí 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Průměr 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “Average.8bf”
                   Radiance 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “Radiance.8bi”
                   Redukce chvění 19.0 – ze souboru “Shake Reduction.8bf”
                   Rozmazání 19.0 – ze souboru “Filter Gallery.8bf”
                   Rozostření objektivu 19.0 – ze souboru “Lens Blur.8bf”
                   Rozptyl 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “statistics.8ba”
                   Rozptýlené světlo 19.0 – ze souboru “Filter Gallery.8bf”
                   Rozsah 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “statistics.8ba”
                   Rýsovací pero 19.0 – ze souboru “Filter Gallery.8bf”
                   Sádra 19.0 – ze souboru “Filter Gallery.8bf”
                   Síťovina 19.0 – ze souboru “Filter Gallery.8bf”
                   Sklo 19.0 – ze souboru “Filter Gallery.8bf”
                   Slátanina 19.0 – ze souboru “Filter Gallery.8bf”
                   Šmouhy barvy 19.0 – ze souboru “Filter Gallery.8bf”
                   Solarizace 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “Solarize.8bf”
                   Součet 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “statistics.8ba”
                   Spaces 19.0 – ze souboru “Spaces.8li”
                   Šrafování 19.0 – ze souboru “Filter Gallery.8bf”
                   Standardní odchylka 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “statistics.8ba”
                   STL 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “U3D.8bi”
                   Stř. hodnota 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “statistics.8ba”
                   Střih 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Suchý štětec 19.0 – ze souboru “Filter Gallery.8bf”
                   Sumi-e 19.0 – ze souboru “Filter Gallery.8bf”
                   Targa 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Texturování 19.0 – ze souboru “Filter Gallery.8bf”
                   Tmavé tahy 19.0 – ze souboru “Filter Gallery.8bf”
                   Tvarování 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   U3D 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “U3D.8bi”
                   Úběžný bod 19.0 – ze souboru “VanishingPoint.8bf”
                   Uhlokresba 19.0 – ze souboru “Filter Gallery.8bf”
                   Úhlové tahy 19.0 – ze souboru “Filter Gallery.8bf”
                   Uložit pro Web 19.0 – ze souboru “Save for Web.8be”
                   Vítr 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Vlákna 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Vlhký papír 19.0 – ze souboru “Filter Gallery.8bf”
                   Vlna 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Vyhledávací mřížka barev pro vykreslování 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “Export3DLUT.8be”
                   Vystřižení 19.0 – ze souboru “Filter Gallery.8bf”
                   Wavefront|OBJ 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “U3D.8bi”
                   WBMP 19.0 (20171103.r.190 2017/11/03: 1143799) – ze souboru “WBMP.8bi”
                   Zaoblení 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Zářící obrysy 19.0 – ze souboru “Filter Gallery.8bf”
                   Zkapalnění 19.0 – ze souboru “Liquify.8bf”
                   Zkroutit 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Zrnění 19.0 – ze souboru “Filter Gallery.8bf”
                   Zrnitý film 19.0 – ze souboru “Filter Gallery.8bf”
                   Zvlnění 19.0 – ze souboru “Standard MultiPlugin.8bf”
                   Zvlnění moře 19.0 – ze souboru “Filter Gallery.8bf”
                   Zvýraznění obrysů 19.0 – ze souboru “Filter Gallery.8bf”
                Doplňkové zásuvné moduly a zásuvné moduly jiných výrobců: ŽÁDNÉ
                Duplicitní a zakázané zásuvné moduly: ŽÁDNÉ
                Zásuvné moduly, které se nepodařilo zavést: žádné
                Rozšíření:
                   com.adobe.inapp.purchase  2.11.27 – ze souboru “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
                   com.adobe.Butler.backend  2.0.0 – ze souboru “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
                   Nový dokument  2.1.0 – ze souboru “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.fnft\fnft.html”
                   Knihovny  2.11.27 – ze souboru “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
                   Začít  2.1.0 – ze souboru “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.start\index.html”
                   Motivy Adobe Color  6.1.0 – ze souboru “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                   Exportovat jako  3.0.13 – ze souboru “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                Instalovaná zařízení TWAIN: ŽÁDNÁ
