5 Replies Latest reply on Dec 4, 2017 5:18 AM by OMOTI
    Mismatch type Illustrator 32bit and 64 bit
    Marcel Leclerc
      I am running a script for the last 10 years without problem and suddenly it doesn't work
      This script do not work on Illustrator 64 bit but no problem on illustrator 32 bit until last week, no library or reference missing.
      Maybe somebody may help me to solve this problem below, in reality I have hundred of script with the same mismatch type error
      THE ERROR IS ON THIS LINE BELOW            set FirstMi2 = PointMi2(Ligne) ' ERROR MISMATCH TYPE
      Sub length2()
      Dim Ligne As Long
      Dim FirstMi2 As Illustrator.PathPoint    'if I write only  Dim FirstMi2   then the same error will be at the next line  Set NextMi2 = PointMi2(Ligne + 1)
      Dim NextMi2 As Illustrator.PathPoint   'if I write only  Dim NextMi2  then the same error will be at the next line   dPoint1X = FirstMi2.Anchor(0)
      Dim numPointMi2 As Double
      Dim EachLength As Double
      Dim TotalLength As Double
      Dim dPoint1X As Double    'if I write only Dim dPoint1X  then the same error will be at the next line  dPoint1Y = FirstMi2.Anchor(1)
                                                  'If I do not dim all point as Double then I cannot use my        Public Function BezierLength(dPoint1X As Double, ....
      Dim dPoint1Y As Double
      Dim dPoint2X As Double
      Dim dPoint2Y As Double
      Dim dPoint3X As Double
      Dim dPoint3Y As Double
      Dim dPoint4X As Double
      Dim dPoint4Y As Double
      Dim appRef
      Set appRef = CreateObject("Illustrator.Application.CS6")
      Set docRef = appRef.ActiveDocument
      Set LayerRef1 = docRef.ActiveLayer()
      If Not IsEmpty(appRef.Selection) Then
      mySelection = appRef.Selection
      endIndex = UBound(mySelection)
      startIndex = LBound(mySelection)
      TotalLength = 0
      For i = startIndex To endIndex
      Set MyPathItem = mySelection(i)
      Set PointMi2 = MyPathItem.PathPoints
      numPointMi2 = PointMi2.Count
              For Ligne = 1 To (numPointMi2 - 1) Step 1
                  Set FirstMi2 = PointMi2(Ligne)                '  ERROR MISMATCH TYPE
                  dPoint2X = FirstMi2.RightDirection(0)
                  dPoint2Y = FirstMi2.RightDirection(1)
                  dPoint3X = NextMi2.LeftDirection(0)
                  dPoint3Y = NextMi2.LeftDirection(1)
                  dPoint4X = NextMi2.Anchor(0)
                  dPoint4Y = NextMi2.Anchor(1)
                  EachLength = BezierLength(dPoint1X, dPoint1Y, dPoint2X, dPoint2Y, dPoint3X, dPoint3Y, dPoint4X, dPoint4Y)
                  TotalLength = TotalLength + EachLength
              Next Ligne
      Next
      MsgBox "Longeur " & (Round((TotalLength / 72), 4)) & "   " & "Nombre de points " & numPointMi2 & "   " & i & " de " & endIndex
      End If
      End Sub
      Thanks Marcel
        • 1. Re: Mismatch type Illustrator 32bit and 64 bit
          OMOTI Level 3
          Hi, Marcel Leclerc.
          I couldn't run your script. There is something to worry about.
          I think that VBScript is a typeless language. Is there no problem if the script is executed via application like Excel?
          Microsoft Windows 2000 Scripting Guide - VBScript Data Types
          Also, there is no process in the script to verify whether each selected object is a pathItem. So if an object other than pathItem is included, an error will occur.
          And I tried it by writing a similar script. All of the following ways are fine. But the process of subroutine "BezierLength" is my expectation.
          Execution environment:
          • Windows 7 64-bit
          • Illustrator CS6 Version 16.0.0(32-bit)
          • Illustrator CS6 Version 16.0.3(64-bit)
          How to run this script in Illustrator CS6 Version 16.0.0(32-bit):
          • via CUI "Command Line".(C:\Windows\SysWow64\cscript.exe length2.vbs)
          How to run this script in Illustrator CS6 Version 16.0.3(64-bit):
          • via menu. (File > Scripts > Other Script and choose the file "length2.vbs")
          • via doubleclick the file "length2.vbs" in explorer.
          This is my script named "length2.vbs":
          Sub length2()
              Dim totalLength
              Dim pathPointCount
              Dim endIndex
              Dim i
              Dim app
              Dim doc
              Dim sel
              Dim pathItem
              Set app = CreateObject("Illustrator.Application.CS6")
              Set doc = app.ActiveDocument
              If IsEmpty(app.Selection) Then
                  Exit Sub
              End If
              sel = app.Selection
              endIndex = UBound(sel)
              totalLength = 0
              pathPointCount = 0
              For i = 0 To endIndex
                  Set pathItem = sel(i)
                  If pathItem.Typename = "PathItem" Then
                      totalLength = totalLength + pathItem.Length
                      pathPointCount = pathPointCount + pathItem.PathPoints.Count
                  End If
              Next
              MsgBox "Longeur " & (Round((totalLength / 72), 4)) & "   " & "Nombre de points " & pathPointCount & "   " & i & " de " & endIndex
          End Sub
          length2()
          • 2. Re: Mismatch type Illustrator 32bit and 64 bit
            Marcel Leclerc Level 1
            Thanks for your help,
            I should have been more explicit; all my scripts are in Excel Visual Basic editor.
            I do not use the      menu. (File > Scripts > Other Script and choose the file "MyScript")
            Here is a very basic script which is still working in all my computers.
            Last week only the “Window 10” has stop to accept this script.
            Sub Test()
            Dim appRef
            Set docRef = appRef.Documents.Add
            Set smoothPath = appRef.ActiveDocument.PathItems.Add
            smoothPath.Closed = False
            smoothPath.Stroked = True
            smoothPath.StrokeWidth = 2
            smoothPath.Filled = False
            smoothPath.Name = "MyPath"
            Set newPathPoint = smoothPath.PathPoints.Add
            newPathPoint.Anchor = Array(100, 200)
            newPathPoint.LeftDirection = Array(100, 20)
            newPathPoint.RightDirection = Array(100, 180)
            newPathPoint.PointType = 2 ' aiSmooth
            newPathPoint.Anchor = Array(300, 400)
            newPathPoint.LeftDirection = Array(330, 250)
            newPathPoint.RightDirection = Array(270, 350)
            Dim FirstPointX As Double
            Dim FirstPointY As Double
            Set LayerRef = docRef.ActiveLayer()
            Dim FirstPathPoint As Illustrator.PathPoint
            Set PathBase = LayerRef.PathItems("MyPath")
            Set PointBase = PathBase.PathPoints
            Set FirstPathPoint = PointBase(1)      '  ERROR MISMATCH TYPE
            FirstPointX = FirstPathPoint.Anchor(0)
            FirstPointY = FirstPathPoint.Anchor(1)
            MsgBox "My first point  " & FirstPointX & " X  " & FirstPointY & " Y  "
            End Sub
            • 3. Re: Mismatch type Illustrator 32bit and 64 bit
              OMOTI Level 3
              My pleasure. The slightly edited following script is fine in my environment. Unfortunately I don't have Excel, so I can't specify data types. Can you try to debug this via Excel Visual Basic editor?
                  Windows 7 64-bit
                  Use the menu or doubleclick the VBS file
              Sub Test()
                  Dim appRef
                  Dim FirstPointX 'As Double
                  Dim FirstPointY 'As Double
                  Dim FirstPathPoint 'As Illustrator.PathPoint
                  'It's enough that remove the three lines below and append this.
                  'Set PathBase = docRef.PathItems("MyPath")
                  Set LayerRef = docRef.ActiveLayer '() isn't needed.
                  FirstPointX = FirstPathPoint.Anchor(0)(0) 'The dimensions of the array are different.
                  FirstPointY = FirstPathPoint.Anchor(0)(1) 'The dimensions of the array are different.
              End Sub
              Test()
              • 4. Re: Mismatch type Illustrator 32bit and 64 bit
                Thank you so much, it works very well.
                I will get more information about    .Anchor(0)(0)
                There is no problem to get the point position as a Double, which is important for all my script
                Dim FirstPointX As Double    ‘ is accepted
                Marcel
                • 5. Re: Mismatch type Illustrator 32bit and 64 bit
                  OMOTI Level 3
                  I also wonder why is .Anchor(0)(0) going well, not .Anchor(0).
                  In javascript, .anchor returns array of 2 numbers. Additionally, "Illustrator - Scripting - Reference - VBScript - cs 6" also says that Anchor will return Variant Array of 2 Doubles. Umm...
