In Acrobat Pro DC a document with measurements fails to print when selecting "Document and Markups" in the dropdown menu under Comments & Forms. The printing progress window appears and stays at 0% indefinitely. The printer status shows "Spooling" but never progresses.
Selecting "Document" only enables printing without the desired measurements visible. How can I print with the measurements viewable? The preview image in the lower right corner of the print window shows the dimensions when selecting "Document and Markups".
Hi Leadvilleone,
Please try selecting "Print as image" option under Printer's properties and check if that helps. Select your printer under Printer > click Advanced > check the box next to Print as Image > OK
Also, try printing to Adobe PDF printer, does that work?
Have you tried printing from other applications like word/textedit, does that work?
Let us know Acrobat dot version installed on the machine? To check the version: Identify the product and its version for Acrobat and Reader DC
And, the ope
...Copy link to clipboard
Hi Leadvilleone,
And, the operating system you have on the machine?
Shivam
