• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
need help adding a javascript var to a form url
Contributor ,
Nov 30, 2017 Nov 30, 2017
Hi all,
I need help adding a javascript var to a form url.
So the form url is like:
"url": "https://mypage/info/230",
but I want to replace the number 230 with var MyNum like:
var MyNum = 230;
"url": "https://localhost/mypage/info/" + MyNum + "\"",
but it doesn't seem to work
Is there a better way to write it?
var settings = {
  "async": true,
  "url": "https://localhost/mypage/info/230",
  "method": "Post",
  more stuff.....
Views
3.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Contributor ,
Dec 02, 2017 Dec 02, 2017
Hi - I could still use some help with this - thanks
Votes
Translate
Translate
Report
Report
LEGEND ,
Dec 05, 2017 Dec 05, 2017
You can just change the .action property in JavaScript. Short example:
Example HTML:
<form id="myForm">
<input type="text" id="theInput" value="/script.php">
<button type="button" id="changeForm">Update Action</button>
</form>
Example JS:
(function(){
document.getElementById('changeForm').onclick = function(e) {
    document.getElementById('myForm').action = document.getElementById('theInput').value;
JSFiddle: JSfiddle
This is just assigning a click handler to the button that adjusts the .action property of the form "myForm" to whatever you put in the input text field.
Votes
Translate
Translate
Report
Report
LEGEND ,
Dec 06, 2017 Dec 06, 2017
Can you not set it as below:
<script>
var MyNum = 230;
var url = "https://localhost/mypage/info/"+MyNum;
var settings = {
"async": true,
"url": url,
"method": "Post"
Votes
Translate
Translate
Report
Report
Explorer ,
Jan 03, 2018 Jan 03, 2018
Can you explain what exactly does not work? Maybe we can pick up from there.
Ia there an error message?
What is the behavior and what is the expected behavior?
Thabk you.
Votes
Translate
Translate
Report
Report
LEGEND ,
Jan 11, 2018 Jan 11, 2018
LATEST
Watch out for typos like setting the object value how you are.
e.g.: "url": "https://localhost/mypage/info/" + MyNum + "\"",
That is setting the property .url to: https://localhost/mypage/info/MyNum"
Note the double quote at the end because you specified to end it with "\"". It doesn't take much to break things like that.
Votes
Translate
Translate
Report
Report
