Expand my Community achievements bar.
SOLVED
[AEM 6.3] Add SVG drag and drop support to Content Explorer
Avatar
Level 1
Is there a method within 6.3 to support use of SVG assets in the Assets Panel similar to how raster-format images work? Eg preview, drag and drop? Not finding anything specifically about allowing/enabling other image formats there.
1 Accepted Solution
Avatar
Correct answer by
Level 1
Well, after re-enabling the workflow that we had disabled when doing our 6.3 environment sync, and then invoking it on the necessary paths, the SVGs do in fact have thumbnails and appear to work fine with drag and drop into components. Sorry, false alarm.
View solution in original post
Avatar
Level 10
We are checking with the Asset team - I will post back the response.
Avatar
Community Advisor
You should be able to drag and drop like other raster images. They will work. However, you can't see the image preview on the left hand pane.
Thanks.
Avatar
Level 1
In our 6.3sp1 environment, SVG graphics do not show up in the asset panel while editing a page. Other file formats do. We have also seen that intermittently, folders that contain both SVG and other image types do not show any images in the ass it’s panel.
Avatar
Level 10
Double checking with Asset team to see if this is intended or a bug.
Avatar
Correct answer by
Level 1
