4 Replies Latest reply on Dec 2, 2017 1:54 PM by Bill Gehrke
    Choppy multi cam
    rmartin215 Level 1
      Altho better than in the past, I still have serious choppy playback problems with Mullticam, especially when add video effects and when scrub.  Have implemented suggestions that I can make sense of.
      Would more computer power help:, i.e., Processor, RAM, etc?
      How about Premiere 2018?
      Current System.
      Win 10 Pro – on SSD
      Premiere 2017.1 on internal 7200 rpm drive.
      X64-bsed PC
      Processor: Intel Core 17-4790K CPU@4.0GHz, 4 Cores, 8 Logical Processors
      RAM: 32 GB (max).
      Graphic Card: Quadro K2000
      Media etc., on external Seagate or Western Digital, 2-6 TB, USB3
      Thanks.
      [Moderator note: moved to best forum.]
        • 1. Re: Choppy multi cam
          R Neil Haugen Adobe Community Professional & MVP
          That external spinning disk on USB3 is a good section of the issue, I'd think. Something like the Samsung T5 that Bill Gehrke discusses for media might improve your performance some.
          Of course, the media itself may be an issue ... if it's long-GOP H.264 from a drone, DSLR, mirror-less, whatnot ... well, that's a difficult format/codec to edit.
          Neil
          • 2. Re: Choppy multi cam
            Bill Gehrke Most Valuable Participant
            1. What is your media?  A good way to fully understand your media is to download MediaInfo and open your media in it in an look at Tree View and let us see a screen grab of the video information,
            2. That graphics board is ancient with only a PCIe 2 interface and only 384 cores.  If it is necessary for your media/workflow it might be overloaded.  If you look at its usage with a tool like GPU-Z on the Sensors Tab and see full GPU Load that might be a bottleneck but with your processor maybe not.
            3. Hard disk drives on USB 3.0 are still hard disk drives.  If as Neil suggests you can see your way to acquire a Samsung T3 or the newer T5 you will have about 3x the read and write performance especially if you have your hard disk drives very full of data.
            • 3. Re: Choppy multi cam
              rmartin215 Level 1
              Would you get a portable SSD, USB 3.1, or an internal one?
              • 4. Re: Choppy multi cam
                The SATA III internal SSD"s are slightly faster but the USB 3.1 have great portability.  I use both regularily
