Hi there
I felt with in love with latest version of muse and the power of responsive composition widget!
I am wondering if some can help with code snippet / muse plugin to add a progress bar for composition widget slides?
I was thinking to use some animator widget and set same timing for both but it will not stay in sync if user will switch slides manually 😕
Thanks for any help!
I thought that! Yes, it is possible to a certain degree. Just look at this:
As you see, there are some tricky ways to achieve something like this with Muse’s built in tools, but each way has some slight restrictions, which you may notice, if you download and check my sample .muse file: https://www.dropbox.com/s/3ha50yfn9i3eta7/Progressbars.zip?dl=0​
If you know, what you want, and accept, to make this or that concession, you can solve your issue using creative layout approaches.
Do you have an example of what and where you want to have a progress bar in a slide show?
Uwe
Without a „real“ animation it is a simple task. So: What kind of animation are you looking for?
the qooqee plugin just makes the default Muse widget work a little different... you could put a sideshow inside one or more of the targets and muse can show progress without needing extra code but I'm sure there are some 3rd party options around
HI guys
I was thinking about something like that yellow line here:
https://codepen.io/ccrch/pen/raGVeL
So what you are looking for is something like a preloader?
Best Regards,
Uwe
I cant believe how easy it is thanks Gunter
It’s Muse!
