1 Reply Latest reply on Dec 2, 2017 6:10 PM by davescm
    Select and Mask - is re-edit possible after clicking OK
    herddav
      After working for some time in Select and mask and making sure that the edges of heair and face were correct I clicked on ok but the iamge I am left with is untidy where it was tidied before clicking ok. Is this normal and can I re-open the select and mask again any way to make further adjustments or do I have to start again or work using brush tools etc to tidy the image?
      Any assistance will be greatly appreciated/
      David Herd
      [Personal Info Removed by moderator]
        • 1. Re: Select and Mask - is re-edit possible after clicking OK
          davescm Adobe Community Professional
          It depends on what your output settings were when you clicked OK in Select and Mask.
          If your output was a Mask or a "New Layer with mask" and you did not check decontaminate colors (which destructively alters pixels)  - then just double click the mask* to re-enter the select and mask workspace and modify the mask.
          If the output was a selection - then just click on Select and Mask again and modify it.
          Alternatively you may need to step back in history and re-mask.
          *Note - this needs "Double Click Layer Mask Launches Select and Mask workspace" to be checked in Preferences >Tools
          Dave
