• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Check if the color sampler is present
Advocate ,
Dec 03, 2017 Dec 03, 2017
I tried this solution but it does not work
Where am I doing wrong
var doc = activeDocument;
try{
   if (activeDocument.colorSamplers.length > 0)
   {alert ("color sampler/s exist/s")};
catch(){
       {alert ("color sampler/no exist")};
TOPICS
Actions and scripting
Views
875
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Dec 03, 2017 Dec 03, 2017
Why do you use the try-clause?
As long as a file is open you should be able to use the »else« of the »if«.
if (activeDocument.colorSamplers.length > 0) {alert ("color sampler/s exist/s")}
else {alert ("color sampler/no exist")};
Votes
Translate
Translate
Adobe
LEGEND ,
Simple activeDocument.colorSamplers.length is sufficent.
But if you want try/catch worked you have to add missing value inside rounded brackets, for ex. catch(err)
Votes
Translate
Translate
Report
Report
Advocate ,
tried it too but it does not work?
try{
catch(e){
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Advocate ,
I thought the best way was to try
now I learned another thing
Thank you
Votes
Translate
Translate
Report
Report
Community Expert ,
To use a try clause in a case like this it should include something that is possible only if the desired »thing« exists.
In this case you could define a variable from the first ColorSampler which would throw an error if no ColorSamplers exist.
#target photoshop
try {
var theColorSampler = doc.colorSamplers[0];
} catch (e) {
Votes
Translate
Translate
Report
Report
People's Champ ,
LATEST
Alternative way )
alert( has_property("document", "colorSamplerList") )
function has_property(class_name, prpr_name)
    try
        var r = new ActionReference();
        r.putProperty(charIDToTypeID("Prpr"), stringIDToTypeID(prpr_name));
        r.putEnumerated( stringIDToTypeID( class_name ), charIDToTypeID("Ordn"), charIDToTypeID("Trgt"));
        if (executeActionGet(r).hasKey(stringIDToTypeID(prpr_name))) return true;
        return false;
    catch (e) { alert(e); }
Votes
Translate
Translate
Report
Report
