0 Replies Latest reply on Dec 3, 2017 11:51 AM by Darrell444
    VM warning: INFO: os::commit_memory(0x00000000cb380000, 143130624, 0) failed; error='Cannot allocate memory' (errno=12)
    Darrell444
      when i do a build for android it will work sometimes, but more often than not the build will fail, and i check the logs.
      Note: Recompile with -Xlint:unchecked for details.
      :compileReleaseNdk UP-TO-DATE
      :compileReleaseSources
      :transformClassesWithDexForReleaseOpenJDK 64-Bit Server VM warning: INFO: os::commit_memory(0x00000000cb380000, 143130624, 0) failed; error='Cannot allocate memory' (errno=12)
      FAILED
      BUILD FAILED
      Total time: 26.723 secs
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':transformClassesWithDexForRelease'.
      > com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.151-1.b12.35.amzn1.x86_64/bin/java'' finished with non-zero exit value 1
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      if i try rebuilding enough times it will eventually work, but is there anything i can do to prevent this?
