Hey,
I'm working on a fixed-width Muse site where I'd like to apply a graphic style to a text with the intention of using the graphic style name in a widget. Unfortunately, I'm unable to create a graphic style that actually links to the text. The style details come up with very generic style settings (see below). I can affect/apply graphic styles images just fine, but applying text seems to not work.
I've even attempted to create a fresh, new project where some generic text is the only object on the page with the purpose of testing the graphic style feature. Once again, it creates a style but its settings are very generic (and inaccurate).
"border color: R=0 G=0 B=0 + border weight: 0 + background color: [None]"
Thanks!
Okay, so I'm not sure what I'm doing differently. There might be an order of operations that I stumbled upon. In attempting to create a very simple project for you to review, I applied the style and widget... gave it a test... and it seems to be working.
When I tried to do this on the main project, it behaved as it had. It was only after I deleted the text I had and started over that it seems to be behaving correctly. I can still provide a file to you if you like. I'd hate to waste any more of y
...Copy link to clipboard
Text itself can’t have a graphic style, but character styles or paragraph styles. Only text frames can have graphic styles.
Thank you so much for the reply!
I considered that. However, this is the product I'm using. The creator is using a graphic style to affect the text for use by the widget. Unless, I'm seeing something that isn't there.
This is quite simple:
Thank you again!
I'm pleased to know that I'm doing this correctly. The style is getting assigned to the text layer (as I can see that the layer highlights when I click on the various graphic styles I currently have). Unfortunately, the widget is having difficulty recognizing the text as a layer worthy of animation. (I will also mention that the style name I'm picking is rather simple with lowercase characters and no funky symbols. Just in case there was curiosity there.)
I've sent an email to the creator of the widget to hopefully get some answers.
Could you please share a .muse file containing only one text frame and this widget with us? Then we can have a closer look. You may upload this .muse file to Dropbox, Creative Cloud or a similar file sharing service and post the download link here.
When I tried to do this on the main project, it behaved as it had. It was only after I deleted the text I had and started over that it seems to be behaving correctly. I can still provide a file to you if you like. I'd hate to waste any more of your time at this point.
Thank you so much for taking the time to deal with this little headache. I truly appreciate it!
I will also mention, after gaining further success, I found that the font style I was choosing was (oddly enough) affecting the ability to utilize the widget. I'm certainly not educated enough to figure that logic out, but I just thought I'd include that in this mess. Thanks!
Hello, I've got the same problem as remyzero111​ mentioned. Does anybody know how can I enable widgets to other fonts I have? The font type actually doesn't matter in this case, cause widgets for example works with Helvetica.ttc smoothly but not with Avenir.ttc
Thanks.
This is a completely different issue.
Please start a new thread.
