6 Replies Latest reply on Dec 12, 2017 1:05 PM by ryanskihead
    iOS build failed...
    mikeb123XXX Level 1
      Hello all, I'm trying desperately to get my iOS game app built using PhoneGap but have been failing for the past month or so. I'm not a developer at heart and am now at my absolute wits' end trying to get this thing to work.
      Ap ID: 2914682
      I thought I had it this time but it came back with the following error.
      Build Date: 2017-12-04 06:15:30 -0800 -------------------------------------------------------------------------------- PLUGIN OUTPUT -------------------------------------------------------------------------------- Fetching plugin "cordova-plugin-inappbrowser" via npm Installing "cordova-plugin-inappbrowser" at "1.7.2" for ios Fetching plugin "construct-mobile-advert@1.0.17" via npm Installing "construct-mobile-advert" at "1.0.17" for ios Fetching plugin "cordova-plugin-add-swift-support@1.7.0" via npm Installing "cordova-plugin-add-swift-support" at "1.7.0" for ios      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current                                     Dload  Upload   Total   Spent    Left  Speed         0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0      0 12.6M    0   831    0     0   3080      0  1:11:47 --:--:--  1:11:47  3077    100 12.6M  100 12.6M    0     0  11.0M      0  0:00:01  0:00:01 --:--:-- 11.0M Fetching plugin "cordova-plugin-whitelist" via npm Installing "cordova-plugin-whitelist" at "1.3.3" for ios Fetching plugin "cordova-plugin-statusbar" via npm Installing "cordova-plugin-statusbar" at "2.3.0" for ios Fetching plugin "cordova-custom-config" via npm Installing "cordova-custom-config" at "4.0.2" for ios Fetching plugin "cordova-plugin-wkwebview-engine" via npm Installing "cordova-plugin-wkwebview-engine" at "1.1.4" for ios Fetching plugin "cordova-plugin-file" via npm Installing "cordova-plugin-file" at "5.0.0" for ios -------------------------------------------------------------------------------- COMPILE OUTPUT -------------------------------------------------------------------------------- Now using system ruby. Building project: /private/project/LftD01.xcworkspace   Configuration: Release   Platform: device User defaults from command line:     IDEArchivePathOverride = /private/project/LftD01.xcarchive Build settings from command line:     CONFIGURATION_BUILD_DIR = /private/project/build/device     SHARED_PRECOMPS_DIR = /private/project/build/sharedpch Build settings from configuration file '/private/project/cordova/build-release.xcconfig':     ALWAYS_EMBED_SWIFT_STANDARD_LIBRARIES = NO     ARCHS = armv7 arm64     CLANG_ALLOW_NON_MODULAR_INCLUDES_IN_FRAMEWORK_MODULES = YES     CODE_SIGN_ENTITLEMENTS = /project/app.entitlements     CODE_SIGN_IDENTITY = iPhone Developer     CONFIGURATION_BUILD_DIR = /project/build     CORDOVALIB = /project/CordovaLib     DEVELOPMENT_TEAM = G25J235Q4H     ENABLE_BITCODE = false     FRAMEWORK_SEARCH_PATHS = $(inherited) "${PODS_ROOT}/Google-Mobile-Ads-SDK/Frameworks/frameworks"     GCC_PREPROCESSOR_DEFINITIONS = $(inherited) COCOAPODS=1     HEADER_SEARCH_PATHS = $(inherited) "${PODS_ROOT}/Headers/Public" "${PODS_ROOT}/Headers/Public/Google-Mobile-Ads-SDK"     IPHONEOS_DEPLOYMENT_TARGET = 9.0     ONLY_ACTIVE_ARCH = NO     OTHER_CFLAGS = $(inherited) -isystem "${PODS_ROOT}/Headers/Public" -isystem "${PODS_ROOT}/Headers/Public/Google-Mobile-Ads-SDK"     OTHER_CODE_SIGN_FLAGS = --keychain /secure.keychain     OTHER_LDFLAGS = $(inherited) -ObjC -framework "AVFoundation" -framework "AudioToolbox" -framework "CoreGraphics" -framework "CoreMedia" -framework "CoreMotion" -framework "CoreTelephony" -framework "CoreVideo" -framework "GLKit" -framework "GoogleMobileAds" -framework "MediaPlayer" -framework "MessageUI" -framework "MobileCoreServices" -framework "OpenGLES" -framework "Security" -framework "StoreKit" -framework "SystemConfiguration" -weak_framework "AdSupport" -weak_framework "JavaScriptCore" -weak_framework "SafariServices" -weak_framework "WebKit"     PODS_BUILD_DIR = $BUILD_DIR     PODS_CONFIGURATION_BUILD_DIR = $PODS_BUILD_DIR/$(CONFIGURATION)$(EFFECTIVE_PLATFORM_NAME)     PODS_ROOT = ${SRCROOT}/Pods     PROVISIONING_PROFILE = a7617499-64ec-47d4-9bd8-ecc6d03378f0     SWIFT_OBJC_BRIDGING_HEADER = $(PROJECT_DIR)/$(PROJECT_NAME)/Bridging-Header.h     TARGETED_DEVICE_FAMILY = 1,2 === BUILD TARGET CordovaLib OF PROJECT CordovaLib WITH CONFIGURATION Release === Check dependencies Write auxiliary files /bin/mkdir -p /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd write-file /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch.pch.hash-criteria write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-own-target-headers.hmap write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-all-target-headers.hmap write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova.hmap /bin/mkdir -p /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64 write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap /bin/mkdir -p /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7 write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList /bin/mkdir -p /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd write-file /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch.pch.hash-criteria write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-all-non-framework-target-headers.hmap SymLink /project/build/libCordova.a /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bCordova.a     cd /project/CordovaLib     /bin/ln -sfh /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bCordova.a /project/build/libCordova.a CpHeader Classes/Public/CDVWebViewEngineProtocol.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVWebViewEngineProtocol.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVWebViewEngineProtocol.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDV.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDV.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDV.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVCommandDelegateImpl.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVCommandDelegateImpl.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVScreenOrientationDelegate.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVScreenOrientationDelegate.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVScreenOrientationDelegate.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVCommandQueue.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVCommandQueue.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVCommandQueue.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVWhitelist.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVWhitelist.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVWhitelist.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVAppDelegate.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVAppDelegate.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVAppDelegate.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVPlugin+Resources.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVPlugin+Resources.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVPlugin+Resources.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVAvailability.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVAvailability.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVAvailability.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVUIWebViewDelegate.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVPluginResult.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVPluginResult.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVPluginResult.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/NSMutableArray+QueueAdditions.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/NSMutableArray+QueueAdditions.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVInvokedUrlCommand.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVInvokedUrlCommand.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/NSDictionary+CordovaPreferences.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/NSDictionary+CordovaPreferences.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVPlugin.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVPlugin.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVPlugin.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVURLProtocol.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVURLProtocol.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVURLProtocol.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVCommandDelegate.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVCommandDelegate.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVCommandDelegate.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVAvailabilityDeprecated.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVAvailabilityDeprecated.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVAvailabilityDeprecated.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVUserAgentUtil.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVUserAgentUtil.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVUserAgentUtil.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVTimer.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVTimer.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVTimer.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVConfigParser.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVConfigParser.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVConfigParser.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova CpHeader Classes/Public/CDVViewController.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova/CDVViewController.h     cd /project/CordovaLib     builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVViewController.h /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/in clude/Cordova ProcessPCH /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch.pch CordovaLib_Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -MD -MT dependencies -MF /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch.d -c /project/CordovaLib/CordovaLib_Prefix.pch -o /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch.pch --serialize-diagnostics /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch.dia ProcessPCH /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch.pch CordovaLib_Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -MD -MT dependencies -MF /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch.d -c /project/CordovaLib/CordovaLib_Prefix.pch -o /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch.pch --serialize-diagnostics /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch.dia CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVViewController.o Classes/Public/CDVViewController.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVViewController.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVViewController.dia -c /project/CordovaLib/Classes/Public/CDVViewController.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVViewController.o /project/CordovaLib/Classes/Public/CDVViewController.m:335:99: warning: 'stringByAddingPercentEscapesUsingEncoding:' is deprecated: first deprecated in iOS 9.0 - Use -stringByAddingPercentEncodingWithAllowedCharacters: instead, which always uses the recommended UTF-8 encoding, and which encodes for a specific URL component or subcomponent since each URL component or subcomponent has different rules for what characters are valid. [-Wdeprecated-declarations]                 errorUrl = [NSURL URLWithString:[NSString stringWithFormat:@"?error=%@", [loadErr stringByAddingPercentEscapesUsingEncoding:NSUTF8StringEncoding]] relativeToURL:errorUrl];        ^ In module 'Foundation' imported from /project/CordovaLib/Classes/Public/CDVAppDelegate.h:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/Foundation.framework/Headers/NSURL.h:541:1: note: 'stringByAddingPercentEscapesUsingEncoding:' has been explicitly marked deprecated here - (nullable NSString *)stringByAddingPercentEscapesUsingEncoding:(NSStringEncoding)enc NS_DEPRECATED(10_0, 10_11, 2_0, 9_0, "Use -stringByAddingPercentEncodingWithAllowedCharacters: instead, which always uses the recommended UTF-8 encoding, and which encodes for a specific URL component or subcomponent since each URL component or subcomponent has different rules for what characters are valid."); ^ 1 warning generated. CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferences.o Classes/Public/NSDictionary+CordovaPreferences.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferences.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferences.dia -c /project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferences.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.o Classes/Public/CDVAppDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.dia -c /project/CordovaLib/Classes/Public/CDVAppDelegate.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o Classes/Public/CDVCommandDelegateImpl.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.dia -c /project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.o Classes/Private/CDVJSON_private.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.dia -c /project/CordovaLib/Classes/Private/CDVJSON_private.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o Classes/Public/CDVWhitelist.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.dia -c /project/CordovaLib/Classes/Public/CDVWhitelist.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o /project/CordovaLib/Classes/Public/CDVWhitelist.m:259:134: warning: 'stringByAddingPercentEscapesUsingEncoding:' is deprecated: first deprecated in iOS 9.0 - Use -stringByAddingPercentEncodingWithAllowedCharacters: instead, which always uses the recommended UTF-8 encoding, and which encodes for a specific URL component or subcomponent since each URL component or subcomponent has different rules for what characters are valid. [-Wdeprecated-declarations]         NSURL* newUrl = [NSURL URLWithString:[NSString stringWithFormat:@"%@://%@%@", kCDVDefaultSchemeName, [url host], [[url path] stringByAddingPercentEscapesUsingEncoding:NSUTF8StringEncoding]]];        ^ In module 'Foundation' imported from /project/CordovaLib/Classes/Public/CDVWhitelist.h:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/Foundation.framework/Headers/NSURL.h:541:1: note: 'stringByAddingPercentEscapesUsingEncoding:' has been explicitly marked deprecated here - (nullable NSString *)stringByAddingPercentEscapesUsingEncoding:(NSStringEncoding)enc NS_DEPRECATED(10_0, 10_11, 2_0, 9_0, "Use -stringByAddingPercentEncodingWithAllowedCharacters: instead, which always uses the recommended UTF-8 encoding, and which encodes for a specific URL component or subcomponent since each URL component or subcomponent has different rules for what characters are valid."); ^ 1 warning generated. CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o Classes/Public/CDVInvokedUrlCommand.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.dia -c /project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVTimer.o Classes/Public/CDVTimer.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVTimer.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVTimer.dia -c /project/CordovaLib/Classes/Public/CDVTimer.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVTimer.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o Classes/Public/CDVUserAgentUtil.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.dia -c /project/CordovaLib/Classes/Public/CDVUserAgentUtil.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o Classes/Public/CDVConfigParser.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.dia -c /project/CordovaLib/Classes/Public/CDVConfigParser.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.o Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.o Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDele gate.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate.o /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDele gate.m:81:91: warning: 'stringByAddingPercentEscapesUsingEncoding:' is deprecated: first deprecated in iOS 9.0 - Use -stringByAddingPercentEncodingWithAllowedCharacters: instead, which always uses the recommended UTF-8 encoding, and which encodes for a specific URL component or subcomponent since each URL component or subcomponent has different rules for what characters are valid. [-Wdeprecated-declarations]         errorUrl = [NSURL URLWithString:[NSString stringWithFormat:@"?error=%@", [message stringByAddingPercentEscapesUsingEncoding:NSUTF8StringEncoding]] relativeToURL:errorUrl];        ^ In module 'Foundation' imported from /project/CordovaLib/Classes/Public/CDVPlugin.h:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/Foundation.framework/Headers/NSURL.h:541:1: note: 'stringByAddingPercentEscapesUsingEncoding:' has been explicitly marked deprecated here - (nullable NSString *)stringByAddingPercentEscapesUsingEncoding:(NSStringEncoding)enc NS_DEPRECATED(10_0, 10_11, 2_0, 9_0, "Use -stringByAddingPercentEncodingWithAllowedCharacters: instead, which always uses the recommended UTF-8 encoding, and which encodes for a specific URL component or subcomponent since each URL component or subcomponent has different rules for what characters are valid."); ^ 1 warning generated. CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.o Classes/Public/NSMutableArray+QueueAdditions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.dia -c /project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o Classes/Public/CDVCommandQueue.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.dia -c /project/CordovaLib/Classes/Public/CDVCommandQueue.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o Classes/Public/CDVPluginResult.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.dia -c /project/CordovaLib/Classes/Public/CDVPluginResult.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.o Classes/Public/CDVPlugin+Resources.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.dia -c /project/CordovaLib/Classes/Public/CDVPlugin+Resources.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o Classes/Public/CDVURLProtocol.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.dia -c /project/CordovaLib/Classes/Public/CDVURLProtocol.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o /project/CordovaLib/Classes/Public/CDVURLProtocol.m:60:9: warning: 'ALAssetsLibraryAssetForURLResultBlock' is deprecated: first deprecated in iOS 9.0 - Use fetchAssetsWithLocalIdentifiers:options: on PHAsset to fetch assets by local identifier (or to lookup PHAssets by a previously known ALAssetPropertyAssetURL use fetchAssetsWithALAssetURLs:options:) from the Photos framework instead [-Wdeprecated-declarations]         ALAssetsLibraryAssetForURLResultBlock resultBlock = ^(ALAsset* asset) {         ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetsLibrary.h: 64:16: note: 'ALAssetsLibraryAssetForURLResultBlock' has been explicitly marked deprecated here typedef void (^ALAssetsLibraryAssetForURLResultBlock)(ALAsset *asset) NS_DEPRECATED_IOS(4_0, 9_0, "Use fetchAssetsWithLocalIdentifiers:options: on PHAsset to fetch assets by local identifier (or to lookup PHAssets by a previously known ALAssetPropertyAssetURL use fetchAssetsWithALAssetURLs:options:) from the Photos framework instead");                ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:63:69: warning: 'defaultRepresentation' is deprecated: first deprecated in iOS 9.0 - Use PHImageRequestOptions with the PHImageManager from the Photos framework instead [-Wdeprecated-declarations]                 ALAssetRepresentation* assetRepresentation = [asset defaultRepresentation];        ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAsset.h:51:1: note: 'defaultRepresentation' has been explicitly marked deprecated here - (ALAssetRepresentation *)defaultRepresentation NS_DEPRECATED_IOS(4_0, 9_0, "Use PHImageRequestOptions with the PHImageManager from the Photos framework instead"); ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:64:142: warning: 'UTI' is deprecated: first deprecated in iOS 9.0 - Use requestImageDataForAsset:options:resultHandler: on PHImageManager for a PHAsset to request image data from the Photos framework and check the dataUTI passed to your result handler instead [-Wdeprecated-declarations]                 NSString* MIMEType = (__bridge_transfer NSString*)UTTypeCopyPreferredTagWithClass((__bridge CFStringRef)[assetRepresentation UTI], kUTTagClassMIMEType);        ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetRepresentat ion.h:28:1: note: 'UTI' has been explicitly marked deprecated here - (NSString *)UTI NS_DEPRECATED_IOS(4_0, 9_0, "Use requestImageDataForAsset:options:resultHandler: on PHImageManager for a PHAsset to request image data from the Photos framework and check the dataUTI passed to your result handler instead"); ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:65:82: warning: 'size' is deprecated: first deprecated in iOS 9.0 - Use requestImageDataForAsset:options:resultHandler: on PHImageManager to request image data for a PHAsset from the Photos framework instead [-Wdeprecated-declarations]                 Byte* buffer = (Byte*)malloc((unsigned long)[assetRepresentation size]);        ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetRepresentat ion.h:34:1: note: 'size' has been explicitly marked deprecated here - (long long)size NS_DEPRECATED_IOS(4_0, 9_0, "Use requestImageDataForAsset:options:resultHandler: on PHImageManager to request image data for a PHAsset from the Photos framework instead"); ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:66:133: warning: 'size' is deprecated: first deprecated in iOS 9.0 - Use requestImageDataForAsset:options:resultHandler: on PHImageManager to request image data for a PHAsset from the Photos framework instead [-Wdeprecated-declarations]                 NSUInteger bufferSize = [assetRepresentation getBytes:buffer fromOffset:0.0 length:(NSUInteger)[assetRepresentation size] error:nil];        ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetRepresentat ion.h:34:1: note: 'size' has been explicitly marked deprecated here - (long long)size NS_DEPRECATED_IOS(4_0, 9_0, "Use requestImageDataForAsset:options:resultHandler: on PHImageManager to request image data for a PHAsset from the Photos framework instead"); ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:66:62: warning: 'getBytes:fromOffset:length:error:' is deprecated: first deprecated in iOS 9.0 - Use requestImageDataForAsset:options:resultHandler: on PHImageManager to request image data for a PHAsset from the Photos framework instead [-Wdeprecated-declarations]                 NSUInteger bufferSize = [assetRepresentation getBytes:buffer fromOffset:0.0 length:(NSUInteger)[assetRepresentation size] error:nil];                                                              ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetRepresentat ion.h:40:1: note: 'getBytes:fromOffset:length:error:' has been explicitly marked deprecated here - (NSUInteger)getBytes:(uint8_t *)buffer fromOffset:(long long)offset length:(NSUInteger)length error:(NSError **)error NS_DEPRECATED_IOS(4_0, 9_0, "Use requestImageDataForAsset:options:resultHandler: on PHImageManager to request image data for a PHAsset from the Photos framework instead"); ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:60:63: warning: 'ALAsset' is deprecated: first deprecated in iOS 9.0 - Use PHAsset from the Photos framework instead [-Wdeprecated-declarations]         ALAssetsLibraryAssetForURLResultBlock resultBlock = ^(ALAsset* asset) {                                                               ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAsset.h:42:12: note: 'ALAsset' has been explicitly marked deprecated here @interface ALAsset : NSObject {            ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:63:17: warning: 'ALAssetRepresentation' is deprecated: first deprecated in iOS 9.0 - Use PHImageRequestOptions with the PHImageManager from the Photos framework instead [-Wdeprecated-declarations]                 ALAssetRepresentation* assetRepresentation = [asset defaultRepresentation];                 ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetRepresentat ion.h:22:12: note: 'ALAssetRepresentation' has been explicitly marked deprecated here @interface ALAssetRepresentation : NSObject {            ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:74:9: warning: 'ALAssetsLibraryAccessFailureBlock' is deprecated: first deprecated in iOS 9.0 - Use the Photos framework instead [-Wdeprecated-declarations]         ALAssetsLibraryAccessFailureBlock failureBlock = ^(NSError* error) {         ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetsLibrary.h: 71:16: note: 'ALAssetsLibraryAccessFailureBlock' has been explicitly marked deprecated here typedef void (^ALAssetsLibraryAccessFailureBlock)(NSError *error) NS_DEPRECATED_IOS(4_0, 9_0, "Use the Photos framework instead");                ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:79:9: warning: 'ALAssetsLibrary' is deprecated: first deprecated in iOS 9.0 - Use PHPhotoLibrary from the Photos framework instead [-Wdeprecated-declarations]         ALAssetsLibrary* assetsLibrary = [[ALAssetsLibrary alloc] init];         ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetsLibrary.h: 80:12: note: 'ALAssetsLibrary' has been explicitly marked deprecated here @interface ALAssetsLibrary : NSObject {            ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:79:60: warning: 'ALAssetsLibrary' is deprecated: first deprecated in iOS 9.0 - Use PHPhotoLibrary from the Photos framework instead [-Wdeprecated-declarations]         ALAssetsLibrary* assetsLibrary = [[ALAssetsLibrary alloc] init];                                                            ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetsLibrary.h: 80:12: note: 'ALAssetsLibrary' has been explicitly marked deprecated here @interface ALAssetsLibrary : NSObject {            ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:80:24: warning: 'assetForURL:resultBlock:failureBlock:' is deprecated: first deprecated in iOS 9.0 - Use fetchAssetsWithLocalIdentifiers:options: on PHAsset to fetch assets by local identifier (or to lookup PHAssets by a previously known ALAssetPropertyAssetURL use fetchAssetsWithALAssetURLs:options:) from the Photos framework instead [-Wdeprecated-declarations]         [assetsLibrary assetForURL:url resultBlock:resultBlock failureBlock:failureBlock];                        ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetsLibrary.h: 95:1: note: 'assetForURL:resultBlock:failureBlock:' has been explicitly marked deprecated here - (void)assetForURL:(NSURL *)assetURL resultBlock:(ALAssetsLibraryAssetForURLResultBlock)resultBlock failureBlock:(ALAssetsLibraryAccessFailureBlock)failureBlock NS_DEPRECATED_IOS(4_0, 9_0, "Use fetchAssetsWithLocalIdentifiers:options: on PHAsset to fetch assets by local identifier (or to lookup PHAssets by a previously known ALAssetPropertyAssetURL use fetchAssetsWithALAssetURLs:options:) from the Photos framework instead"); ^ 12 warnings generated. CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o Classes/Public/CDVPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVPlugin.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVPlugin.dia -c /project/CordovaLib/Classes/Public/CDVPlugin.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.o Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ffsiiaesjynvtcbwddanhqjimghd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavi gationFilter.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVViewController.o Classes/Public/CDVViewController.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVViewController.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVViewController.dia -c /project/CordovaLib/Classes/Public/CDVViewController.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVViewController.o /project/CordovaLib/Classes/Public/CDVViewController.m:335:99: warning: 'stringByAddingPercentEscapesUsingEncoding:' is deprecated: first deprecated in iOS 9.0 - Use -stringByAddingPercentEncodingWithAllowedCharacters: instead, which always uses the recommended UTF-8 encoding, and which encodes for a specific URL component or subcomponent since each URL component or subcomponent has different rules for what characters are valid. [-Wdeprecated-declarations]                 errorUrl = [NSURL URLWithString:[NSString stringWithFormat:@"?error=%@", [loadErr stringByAddingPercentEscapesUsingEncoding:NSUTF8StringEncoding]] relativeToURL:errorUrl];        ^ In module 'Foundation' imported from /project/CordovaLib/Classes/Public/CDVAppDelegate.h:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/Foundation.framework/Headers/NSURL.h:541:1: note: 'stringByAddingPercentEscapesUsingEncoding:' has been explicitly marked deprecated here - (nullable NSString *)stringByAddingPercentEscapesUsingEncoding:(NSStringEncoding)enc NS_DEPRECATED(10_0, 10_11, 2_0, 9_0, "Use -stringByAddingPercentEncodingWithAllowedCharacters: instead, which always uses the recommended UTF-8 encoding, and which encodes for a specific URL component or subcomponent since each URL component or subcomponent has different rules for what characters are valid."); ^ 1 warning generated. CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferences.o Classes/Public/NSDictionary+CordovaPreferences.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferences.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferences.dia -c /project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferences.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.o Classes/Public/CDVAppDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.dia -c /project/CordovaLib/Classes/Public/CDVAppDelegate.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o Classes/Public/CDVCommandDelegateImpl.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.dia -c /project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.o Classes/Private/CDVJSON_private.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.dia -c /project/CordovaLib/Classes/Private/CDVJSON_private.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o Classes/Public/CDVWhitelist.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.dia -c /project/CordovaLib/Classes/Public/CDVWhitelist.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o /project/CordovaLib/Classes/Public/CDVWhitelist.m:259:134: warning: 'stringByAddingPercentEscapesUsingEncoding:' is deprecated: first deprecated in iOS 9.0 - Use -stringByAddingPercentEncodingWithAllowedCharacters: instead, which always uses the recommended UTF-8 encoding, and which encodes for a specific URL component or subcomponent since each URL component or subcomponent has different rules for what characters are valid. [-Wdeprecated-declarations]         NSURL* newUrl = [NSURL URLWithString:[NSString stringWithFormat:@"%@://%@%@", kCDVDefaultSchemeName, [url host], [[url path] stringByAddingPercentEscapesUsingEncoding:NSUTF8StringEncoding]]];        ^ In module 'Foundation' imported from /project/CordovaLib/Classes/Public/CDVWhitelist.h:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/Foundation.framework/Headers/NSURL.h:541:1: note: 'stringByAddingPercentEscapesUsingEncoding:' has been explicitly marked deprecated here - (nullable NSString *)stringByAddingPercentEscapesUsingEncoding:(NSStringEncoding)enc NS_DEPRECATED(10_0, 10_11, 2_0, 9_0, "Use -stringByAddingPercentEncodingWithAllowedCharacters: instead, which always uses the recommended UTF-8 encoding, and which encodes for a specific URL component or subcomponent since each URL component or subcomponent has different rules for what characters are valid."); ^ 1 warning generated. CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o Classes/Public/CDVInvokedUrlCommand.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.dia -c /project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVTimer.o Classes/Public/CDVTimer.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVTimer.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVTimer.dia -c /project/CordovaLib/Classes/Public/CDVTimer.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVTimer.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o Classes/Public/CDVUserAgentUtil.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.dia -c /project/CordovaLib/Classes/Public/CDVUserAgentUtil.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o Classes/Public/CDVConfigParser.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.dia -c /project/CordovaLib/Classes/Public/CDVConfigParser.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.o Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.o Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDele gate.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate.o /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDele gate.m:81:91: warning: 'stringByAddingPercentEscapesUsingEncoding:' is deprecated: first deprecated in iOS 9.0 - Use -stringByAddingPercentEncodingWithAllowedCharacters: instead, which always uses the recommended UTF-8 encoding, and which encodes for a specific URL component or subcomponent since each URL component or subcomponent has different rules for what characters are valid. [-Wdeprecated-declarations]         errorUrl = [NSURL URLWithString:[NSString stringWithFormat:@"?error=%@", [message stringByAddingPercentEscapesUsingEncoding:NSUTF8StringEncoding]] relativeToURL:errorUrl];        ^ In module 'Foundation' imported from /project/CordovaLib/Classes/Public/CDVPlugin.h:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/Foundation.framework/Headers/NSURL.h:541:1: note: 'stringByAddingPercentEscapesUsingEncoding:' has been explicitly marked deprecated here - (nullable NSString *)stringByAddingPercentEscapesUsingEncoding:(NSStringEncoding)enc NS_DEPRECATED(10_0, 10_11, 2_0, 9_0, "Use -stringByAddingPercentEncodingWithAllowedCharacters: instead, which always uses the recommended UTF-8 encoding, and which encodes for a specific URL component or subcomponent since each URL component or subcomponent has different rules for what characters are valid."); ^ 1 warning generated. CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.o Classes/Public/NSMutableArray+QueueAdditions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.dia -c /project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o Classes/Public/CDVCommandQueue.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.dia -c /project/CordovaLib/Classes/Public/CDVCommandQueue.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o Classes/Public/CDVPluginResult.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.dia -c /project/CordovaLib/Classes/Public/CDVPluginResult.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.o Classes/Public/CDVPlugin+Resources.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.dia -c /project/CordovaLib/Classes/Public/CDVPlugin+Resources.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o Classes/Public/CDVURLProtocol.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.dia -c /project/CordovaLib/Classes/Public/CDVURLProtocol.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o /project/CordovaLib/Classes/Public/CDVURLProtocol.m:60:9: warning: 'ALAssetsLibraryAssetForURLResultBlock' is deprecated: first deprecated in iOS 9.0 - Use fetchAssetsWithLocalIdentifiers:options: on PHAsset to fetch assets by local identifier (or to lookup PHAssets by a previously known ALAssetPropertyAssetURL use fetchAssetsWithALAssetURLs:options:) from the Photos framework instead [-Wdeprecated-declarations]         ALAssetsLibraryAssetForURLResultBlock resultBlock = ^(ALAsset* asset) {         ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetsLibrary.h: 64:16: note: 'ALAssetsLibraryAssetForURLResultBlock' has been explicitly marked deprecated here typedef void (^ALAssetsLibraryAssetForURLResultBlock)(ALAsset *asset) NS_DEPRECATED_IOS(4_0, 9_0, "Use fetchAssetsWithLocalIdentifiers:options: on PHAsset to fetch assets by local identifier (or to lookup PHAssets by a previously known ALAssetPropertyAssetURL use fetchAssetsWithALAssetURLs:options:) from the Photos framework instead");                ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:63:69: warning: 'defaultRepresentation' is deprecated: first deprecated in iOS 9.0 - Use PHImageRequestOptions with the PHImageManager from the Photos framework instead [-Wdeprecated-declarations]                 ALAssetRepresentation* assetRepresentation = [asset defaultRepresentation];        ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAsset.h:51:1: note: 'defaultRepresentation' has been explicitly marked deprecated here - (ALAssetRepresentation *)defaultRepresentation NS_DEPRECATED_IOS(4_0, 9_0, "Use PHImageRequestOptions with the PHImageManager from the Photos framework instead"); ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:64:142: warning: 'UTI' is deprecated: first deprecated in iOS 9.0 - Use requestImageDataForAsset:options:resultHandler: on PHImageManager for a PHAsset to request image data from the Photos framework and check the dataUTI passed to your result handler instead [-Wdeprecated-declarations]                 NSString* MIMEType = (__bridge_transfer NSString*)UTTypeCopyPreferredTagWithClass((__bridge CFStringRef)[assetRepresentation UTI], kUTTagClassMIMEType);        ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetRepresentat ion.h:28:1: note: 'UTI' has been explicitly marked deprecated here - (NSString *)UTI NS_DEPRECATED_IOS(4_0, 9_0, "Use requestImageDataForAsset:options:resultHandler: on PHImageManager for a PHAsset to request image data from the Photos framework and check the dataUTI passed to your result handler instead"); ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:65:82: warning: 'size' is deprecated: first deprecated in iOS 9.0 - Use requestImageDataForAsset:options:resultHandler: on PHImageManager to request image data for a PHAsset from the Photos framework instead [-Wdeprecated-declarations]                 Byte* buffer = (Byte*)malloc((unsigned long)[assetRepresentation size]);        ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetRepresentat ion.h:34:1: note: 'size' has been explicitly marked deprecated here - (long long)size NS_DEPRECATED_IOS(4_0, 9_0, "Use requestImageDataForAsset:options:resultHandler: on PHImageManager to request image data for a PHAsset from the Photos framework instead"); ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:66:133: warning: 'size' is deprecated: first deprecated in iOS 9.0 - Use requestImageDataForAsset:options:resultHandler: on PHImageManager to request image data for a PHAsset from the Photos framework instead [-Wdeprecated-declarations]                 NSUInteger bufferSize = [assetRepresentation getBytes:buffer fromOffset:0.0 length:(NSUInteger)[assetRepresentation size] error:nil];        ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetRepresentat ion.h:34:1: note: 'size' has been explicitly marked deprecated here - (long long)size NS_DEPRECATED_IOS(4_0, 9_0, "Use requestImageDataForAsset:options:resultHandler: on PHImageManager to request image data for a PHAsset from the Photos framework instead"); ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:66:62: warning: 'getBytes:fromOffset:length:error:' is deprecated: first deprecated in iOS 9.0 - Use requestImageDataForAsset:options:resultHandler: on PHImageManager to request image data for a PHAsset from the Photos framework instead [-Wdeprecated-declarations]                 NSUInteger bufferSize = [assetRepresentation getBytes:buffer fromOffset:0.0 length:(NSUInteger)[assetRepresentation size] error:nil];                                                              ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetRepresentat ion.h:40:1: note: 'getBytes:fromOffset:length:error:' has been explicitly marked deprecated here - (NSUInteger)getBytes:(uint8_t *)buffer fromOffset:(long long)offset length:(NSUInteger)length error:(NSError **)error NS_DEPRECATED_IOS(4_0, 9_0, "Use requestImageDataForAsset:options:resultHandler: on PHImageManager to request image data for a PHAsset from the Photos framework instead"); ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:60:63: warning: 'ALAsset' is deprecated: first deprecated in iOS 9.0 - Use PHAsset from the Photos framework instead [-Wdeprecated-declarations]         ALAssetsLibraryAssetForURLResultBlock resultBlock = ^(ALAsset* asset) {                                                               ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAsset.h:42:12: note: 'ALAsset' has been explicitly marked deprecated here @interface ALAsset : NSObject {            ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:63:17: warning: 'ALAssetRepresentation' is deprecated: first deprecated in iOS 9.0 - Use PHImageRequestOptions with the PHImageManager from the Photos framework instead [-Wdeprecated-declarations]                 ALAssetRepresentation* assetRepresentation = [asset defaultRepresentation];                 ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetRepresentat ion.h:22:12: note: 'ALAssetRepresentation' has been explicitly marked deprecated here @interface ALAssetRepresentation : NSObject {            ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:74:9: warning: 'ALAssetsLibraryAccessFailureBlock' is deprecated: first deprecated in iOS 9.0 - Use the Photos framework instead [-Wdeprecated-declarations]         ALAssetsLibraryAccessFailureBlock failureBlock = ^(NSError* error) {         ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetsLibrary.h: 71:16: note: 'ALAssetsLibraryAccessFailureBlock' has been explicitly marked deprecated here typedef void (^ALAssetsLibraryAccessFailureBlock)(NSError *error) NS_DEPRECATED_IOS(4_0, 9_0, "Use the Photos framework instead");                ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:79:9: warning: 'ALAssetsLibrary' is deprecated: first deprecated in iOS 9.0 - Use PHPhotoLibrary from the Photos framework instead [-Wdeprecated-declarations]         ALAssetsLibrary* assetsLibrary = [[ALAssetsLibrary alloc] init];         ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetsLibrary.h: 80:12: note: 'ALAssetsLibrary' has been explicitly marked deprecated here @interface ALAssetsLibrary : NSObject {            ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:79:60: warning: 'ALAssetsLibrary' is deprecated: first deprecated in iOS 9.0 - Use PHPhotoLibrary from the Photos framework instead [-Wdeprecated-declarations]         ALAssetsLibrary* assetsLibrary = [[ALAssetsLibrary alloc] init];                                                            ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetsLibrary.h: 80:12: note: 'ALAssetsLibrary' has been explicitly marked deprecated here @interface ALAssetsLibrary : NSObject {            ^ /project/CordovaLib/Classes/Public/CDVURLProtocol.m:80:24: warning: 'assetForURL:resultBlock:failureBlock:' is deprecated: first deprecated in iOS 9.0 - Use fetchAssetsWithLocalIdentifiers:options: on PHAsset to fetch assets by local identifier (or to lookup PHAssets by a previously known ALAssetPropertyAssetURL use fetchAssetsWithALAssetURLs:options:) from the Photos framework instead [-Wdeprecated-declarations]         [assetsLibrary assetForURL:url resultBlock:resultBlock failureBlock:failureBlock];                        ^ In module 'AssetsLibrary' imported from /project/CordovaLib/Classes/Public/CDVURLProtocol.m:20: /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk/System/Library/Frameworks/AssetsLibrary.framework/Headers/ALAssetsLibrary.h: 95:1: note: 'assetForURL:resultBlock:failureBlock:' has been explicitly marked deprecated here - (void)assetForURL:(NSURL *)assetURL resultBlock:(ALAssetsLibraryAssetForURLResultBlock)resultBlock failureBlock:(ALAssetsLibraryAccessFailureBlock)failureBlock NS_DEPRECATED_IOS(4_0, 9_0, "Use fetchAssetsWithLocalIdentifiers:options: on PHAsset to fetch assets by local identifier (or to lookup PHAssets by a previously known ALAssetPropertyAssetURL use fetchAssetsWithALAssetURLs:options:) from the Photos framework instead"); ^ 12 warnings generated. CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o Classes/Public/CDVPlugin.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVPlugin.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVPlugin.dia -c /project/CordovaLib/Classes/Public/CDVPlugin.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.o Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/CordovaLib     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DCOCOAPODS=1 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Wno-infinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/project/CordovaLib/Pods/Headers/Public -I/project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-ipho neos/CordovaLib.build/DerivedSources -F/project/build -F/project/CordovaLib/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/CordovaLib/Pods/Headers/Public -isystem /project/CordovaLib/Pods/Headers/Public/Google-Mobile-Ads-SDK -include /private/project/build/sharedpch/CordovaLib_Prefix-ecyoyopfsuucotesafyauninepqd/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavi gationFilter.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.o Libtool /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/libCordova.a normal armv7     cd /project/CordovaLib     export IPHONEOS_DEPLOYMENT_TARGET=9.0     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static -arch_only armv7 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -L/project/build -filelist /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/libCordova.a Libtool /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/libCordova.a normal arm64     cd /project/CordovaLib     export IPHONEOS_DEPLOYMENT_TARGET=9.0     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static -arch_only arm64 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -L/project/build -filelist /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/libCordova.a CreateUniversalBinary /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bCordova.a normal armv7\ arm64     cd /project/CordovaLib     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/armv7/libCordova.a /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/CordovaLib.build/Release-iphone os/CordovaLib.build/Objects-normal/arm64/libCordova.a -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bCordova.a Strip /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bCordova.a     cd /project/CordovaLib     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -S /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bCordova.a SetOwnerAndGroup phonegap:staff /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bCordova.a     cd /project/CordovaLib     /usr/sbin/chown -RH phonegap:staff /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bCordova.a SetMode u+w,go-w,a+rX /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bCordova.a     cd /project/CordovaLib     /bin/chmod -RH u+w,go-w,a+rX /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bCordova.a === BUILD TARGET Pods-LftD01 OF PROJECT Pods WITH CONFIGURATION Release === Check dependencies Write auxiliary files write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Pods-LftD01-all-non-framework-target-headers.hmap /bin/mkdir -p /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/armv7 write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/armv7/Pods-LftD01.LinkFileList write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Pods-LftD01-generated-files.hmap write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Pods-LftD01.hmap /bin/mkdir -p /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/arm64 write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/arm64/Pods-LftD01.LinkFileList write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Pods-LftD01-project-headers.hmap write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Pods-LftD01-all-target-headers.hmap write-file /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Pods-LftD01-own-target-headers.hmap SymLink /project/build/libPods-LftD01.a /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bPods-LftD01.a     cd /project/Pods     /bin/ln -sfh /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bPods-LftD01.a /project/build/libPods-LftD01.a CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/armv7/Pods-LftD01-dummy.o Target\ Support\ Files/Pods-LftD01/Pods-LftD01-dummy.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/Pods     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=gnu11 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -fno-common -Wno-missing-field-initializers -Wno-missing-prototypes -Werror=return-type -Wdocumentation -Wunreachable-code -Wno-implicit-atomic-properties -Werror=deprecated-objc-isa-usage -Werror=objc-root-class -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wconditional-uninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DPOD_CONFIGURATION_RELEASE=1 -DCOCOAPODS=1 -DCOCOAPODS=1 -DNS_BLOCK_ASSERTIONS=1 -DOBJC_OLD_DISPATCH_PROTOTYPES=0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Winfinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Pods-LftD01-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/P ods-LftD01.build/Pods-LftD01-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/P ods-LftD01.build/Pods-LftD01-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Pods-LftD01-project-headers.hmap -I/project/build/include -I/project/Pods/Pods/Headers/Public -I/project/Pods/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/P ods-LftD01.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/P ods-LftD01.build/DerivedSources -F/project/build -F/project/Pods/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/Pods/Pods/Headers/Public -isystem /project/Pods/Pods/Headers/Public/Google-Mobile-Ads-SDK -isystem /project/Pods/Pods/Headers/Public -isystem /project/Pods/Pods/Headers/Public/Google-Mobile-Ads-SDK -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/armv7/Pods-LftD01-dummy.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/armv7/Pods-LftD01-dummy.dia -c /project/Pods/Target\ Support\ Files/Pods-LftD01/Pods-LftD01-dummy.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/armv7/Pods-LftD01-dummy.o CompileC /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/arm64/Pods-LftD01-dummy.o Target\ Support\ Files/Pods-LftD01/Pods-LftD01-dummy.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler     cd /project/Pods     export LANG=en_US.US-ASCII     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=gnu11 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache/Session.modulevalid ation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -fno-common -Wno-missing-field-initializers -Wno-missing-prototypes -Werror=return-type -Wdocumentation -Wunreachable-code -Wno-implicit-atomic-properties -Werror=deprecated-objc-isa-usage -Werror=objc-root-class -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wconditional-uninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DPOD_CONFIGURATION_RELEASE=1 -DCOCOAPODS=1 -DCOCOAPODS=1 -DNS_BLOCK_ASSERTIONS=1 -DOBJC_OLD_DISPATCH_PROTOTYPES=0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=9.0 -g -Wno-sign-conversion -Winfinite-recursion -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Pods-LftD01-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/P ods-LftD01.build/Pods-LftD01-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/P ods-LftD01.build/Pods-LftD01-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Pods-LftD01-project-headers.hmap -I/project/build/include -I/project/Pods/Pods/Headers/Public -I/project/Pods/Pods/Headers/Public/Google-Mobile-Ads-SDK -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/P ods-LftD01.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermed iates/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/P ods-LftD01.build/DerivedSources -F/project/build -F/project/Pods/Pods/Google-Mobile-Ads-SDK/Frameworks/frameworks -isystem /project/Pods/Pods/Headers/Public -isystem /project/Pods/Pods/Headers/Public/Google-Mobile-Ads-SDK -isystem /project/Pods/Pods/Headers/Public -isystem /project/Pods/Pods/Headers/Public/Google-Mobile-Ads-SDK -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/arm64/Pods-LftD01-dummy.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/arm64/Pods-LftD01-dummy.dia -c /project/Pods/Target\ Support\ Files/Pods-LftD01/Pods-LftD01-dummy.m -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/arm64/Pods-LftD01-dummy.o Libtool /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/arm64/libPods-LftD01.a normal arm64     cd /project/Pods     export IPHONEOS_DEPLOYMENT_TARGET=9.0     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static -arch_only arm64 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -L/project/build -filelist /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/arm64/Pods-LftD01.LinkFileList -framework Foundation -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/arm64/libPods-LftD01.a Libtool /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/armv7/libPods-LftD01.a normal armv7     cd /project/Pods     export IPHONEOS_DEPLOYMENT_TARGET=9.0     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static -arch_only armv7 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.3.sdk -L/project/build -filelist /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/armv7/Pods-LftD01.LinkFileList -framework Foundation -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/armv7/libPods-LftD01.a CreateUniversalBinary /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bPods-LftD01.a normal armv7\ arm64     cd /project/Pods     /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/armv7/libPods-LftD01.a /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/Pods.build/Release-iphoneos/Pod s-LftD01.build/Objects-normal/arm64/libPods-LftD01.a -o /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bPods-LftD01.a SetOwnerAndGroup phonegap:staff /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bPods-LftD01.a     cd /project/Pods     /usr/sbin/chown -RH phonegap:staff /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bPods-LftD01.a SetMode u+w,go-w,a+rX /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bPods-LftD01.a     cd /project/Pods     /bin/chmod -RH u+w,go-w,a+rX /Library/Developer/Xcode/DerivedData/LftD01-aekpomiyecogmualccgkiqqcfedb/Build/Intermedia tes/ArchiveIntermediates/LftD01/IntermediateBuildFilesPath/UninstalledProducts/iphoneos/li bPods-LftD01.a === BUILD TARGET LftD01 OF PROJECT LftD01 WITH CONFIGURATION Release === Check dependencies “Swift Language Version” (SWIFT_VERSION) is required to be configured correctly for targets which use Swift. Use the [Edit > Convert > To Current Swift Syntax…] menu to choose a Swift version or use the Build Settings editor to configure the build setting directly. “Swift Language Version” (SWIFT_VERSION) is required to be configured correctly for targets which use Swift. Use the [Edit > Convert > To Current Swift Syntax…] menu to choose a Swift version or use the Build Settings editor to configure the build setting directly. ** ARCHIVE FAILED ** The following build commands failed:   Check dependencies (1 failure) Error code 65 for command: xcodebuild with args: -xcconfig,/private/project/cordova/build-release.xcconfig,-workspace,LftD01.xcworkspace,- scheme,LftD01,-configuration,Release,-destination,generic/platform=iOS,-archivePath,LftD01 .xcarchive,archive,CONFIGURATION_BUILD_DIR=/private/project/build/device,SHARED_PRECOMPS_D IR=/private/project/build/sharedpch /gimlet/bin/system_ruby: line 22: shell_session_update: command not found
      I'd appreciate any help here as I'm flailing around in the dark.
      Thanks all
        • 1. Re: iOS build failed...
          ryanskihead Adobe Employee
          I'm trying desperately to get my iOS game app built... I'm not a developer at heart
          The error is:
          “Use Legacy Swift Language Version” (SWIFT_VERSION) is required to be configured correctly for targets which use Swift. Use the [Edit > Convert > To Current Swift Syntax…] menu to choose a Swift version or use the Build Settings editor to configure the build setting directly.
          which is being caused by the plugin construct-mobile-advert. I can't seem to find any documenation on this plugin which makes it difficult to debug...
          • 2. Re: iOS build failed...
            mikeb123XXX Level 1
            Thanks for replying - I've deleted the construct-mobile-plugin for the time being, but still get the following error:
            === BUILD TARGET LftD01 OF PROJECT LftD01 WITH CONFIGURATION Release === Check dependencies “Use Legacy Swift Language Version” (SWIFT_VERSION) is required to be configured correctly for targets which use Swift. Use the [Edit > Convert > To Current Swift Syntax…] menu to choose a Swift version or use the Build Settings editor to configure the build setting directly. “Use Legacy Swift Language Version” (SWIFT_VERSION) is required to be configured correctly for targets which use Swift. Use the [Edit > Convert > To Current Swift Syntax…] menu to choose a Swift version or use the Build Settings editor to configure the build setting directly. ** ARCHIVE FAILED ** The following build commands failed: Check dependencies (1 failure) Error code 65 for command: xcodebuild with args: -xcconfig,/private/project/cordova/build-release.xcconfig,-workspace,LftD01.xcworkspace,- scheme,LftD01,-configuration,Release,-destination,generic/platform=iOS,-archivePath,LftD01 .xcarchive,archive,CONFIGURATION_BUILD_DIR=/private/project/build/device,SHARED_PRECOMPS_D IR=/private/project/build/sharedpch
            Can you let me know where about the [Edit > Convert > To Current Swift Syntax…] menu is? Or does this mean when I initially export the html etc I choose Xcode project as the build rather than Cordova? Or does it mean I have to take it into Xcode to alter it?
            Thank you
            • 3. Re: iOS build failed...
              construct-mobile-advert is still in your config.xml, so you haven't deleted it.
              Those swift instructions are assuming you are building using Xcode, which you aren't. You don't have access to those menus when you're building with PhoneGap Build.
              • 4. Re: iOS build failed...
                mikeb123XXX Level 1
                OK - so I've deleted construct-mobile-advert and have added the additional code required for the social share button from this page https://github.com/EddyVerbruggen/SocialSharing-PhoneGap-Plugin
                The build goes through and I can download and install the .ipa file.
                That said I've no idea how to make the social share button activate the relevant code. There is some additional code in the above GitHub page that I'm not sure where to implement it:
                SHARE SHEET
                // this is the complete list of currently supported params you can pass to the plugin (all optional)
                var options = {
                  message: 'share this', // not supported on some apps (Facebook, Instagram)
                  subject: 'the subject', // fi. for email
                  files: ['', ''], // an array of filenames either locally or remotely
                  url: 'https://www.website.com/foo/#bar?a=b',
                  chooserTitle: 'Pick an app' // Android only, you can override the default share sheet title
                var onSuccess = function(result) {
                  console.log("Share completed? " + result.completed); // On Android apps mostly return false even while it's true
                  console.log("Shared to app: " + result.app); // On Android result.app is currently empty. On iOS it's empty when sharing is cancelled (result.completed=false)
                var onError = function(msg) {
                  console.log("Sharing failed with message: " + msg);
                window.plugins.socialsharing.shareWithOptions(options, onSuccess, onError);
                Any idea?
                • 5. Re: iOS build failed...
                  mikeb123XXX Level 1
                  Hi all - can anyone help with this?
                  Thanks.
                  • 6. Re: iOS build failed...
                    If you're unsure how to make an html button activate javascript code, you may want to take a step back and learn the basics first.
                    That said, try adding this to your html file:
                    <button onclick="window.plugins.socialsharing.share('Message only')">message only</button>
