7 Replies Latest reply on Dec 10, 2017 7:21 PM by kglad
    Tooltip as3 explaination
    iezqandarzulqarnaen
      Hye guys,
      I currently want to learn how to make tooltip via as3.
      Hoping you guys can help me to explain what the code function in the code;
      import fl.transitions.easing.*;
      import fl.transitions.*;
      mc.addEventListener("mouseOver", mouseRollOver);
      mc.addEventListener("mouseOut", mouseRollOut);
      mc.addEventListener("mouseMove", mouseMove1);
      var tooltip:Tooltip = new Tooltip();
      tooltip.txt.text = "This is a tooltip";
      tooltip.x = stage.mouseX;
      tooltip.y = stage.mouseY - mc.height;
      function mouseRollOver(e:MouseEvent):void {
          addChild(tooltip);
          var myTween:Tween = new Tween(tooltip, "alpha", Regular.easeIn, 0, 1, 0.5, true);
      function mouseRollOut(e:MouseEvent):void {
          removeChild(tooltip);
      function mouseMove1(e:MouseEvent):void {
      Thank you
      cc: RandomlyFish, just.emma,
        • 1. Re: Tooltip as3 explaination
          do you have a Tooltip class?  (just  movieclip with a textfield (named txt) is sufficient.)
          is that your code?
          • 2. Re: Tooltip as3 explaination
            iezqandarzulqarnaen Level 1
            Yes I have create a Movie Clip with instance & class named "Tooltip" with empty Dynamic Text in it.
            This is not my own code, i just copied & pasted from a tutorial (i forgot where).
            But I have no idea the function of the code & need someone to help me to explain it so later I can made my own.
            and I want make a multi tooltip.
            Thanks.
            • 3. Re: Tooltip as3 explaination
              iezqandarzulqarnaen
              mc.addEventListener("mouseOver", mouseRollOver);  // adding mouseevent listeners
              mc.addEventListener("mouseOut", mouseRollOut);  //   ""   ""
              mc.addEventListener("mouseMove", mouseMove1);  //  ""  ""
              var tooltip:Tooltip = new Tooltip();  // create a new Tooltip instance
              tooltip.txt.text = "This is a tooltip";  // assign the help text
              tooltip.x = stage.mouseX;  // assign position
              tooltip.y = stage.mouseY - mc.height;  //  ""   ""
                  addChild(tooltip);  // add to the display when mc is rolledover
                  var myTween:Tween = new Tween(tooltip, "alpha", Regular.easeIn, 0, 1, 0.5, true);  // tween its alpha so it fades in
                  removeChild(tooltip);  // remove the tooltip on mouse out
                  tooltip.x = stage.mouseX;   // move the tooltip when the mouse moves
              • 4. Re: Tooltip as3 explaination
                Thanks for the reply @kglad
                So if I put it to more changeable view:
                <movieClip>.addEventListener("mouseOver", <mouseOver function>);  // adding mouseevent listeners
                <movieClip>.addEventListener("mouseOut", <mouseOut function>);  //   ""   ""
                <movieClip>.addEventListener("mouseMove", <mouseMove function>);  //  ""  ""
                var <instance>:<class>= new <class>();  // create a new instance
                <instance>.<dynamicText instance>.text = "This is a tooltip";  // assign the help text
                <instance>.x = stage.mouseX;  // assign position
                <instance>.y = stage.mouseY - <movieClip>.height;  //  ""   ""
                function <mouseOver function>(e:MouseEvent):void {
                    addChild(<instance>);  // add to the display when mc is rolledover
                    var myTween:Tween = new Tween(<instance>, "alpha", Regular.easeIn, 0, 1, 0.5, true);  // tween its alpha so it fades in
                function <mouseOut function>)(e:MouseEvent):void {
                    removeChild(<instance>);  // remove the tooltip on mouse out
                function <mouseMove function>(e:MouseEvent):void {
                    <instance>.x = stage.mouseX;   // move the tooltip when the mouse moves
                is this correct?
                • 5. Re: Tooltip as3 explaination
                  that's not valid actionscript.  if it's meant to something else, i don't understand it.
                  • 6. Re: Tooltip as3 explaination
                    So sorry,
                    forget my previous post.
                    What i need to change if i want to make another tooltip in the same stage.
                    • 7. Re: Tooltip as3 explaination
                      var tooltip:Tooltip;
                      var ttObj:Object={};
                      //call toolTipF and pass whatever displayobject and tooltip string you want
                      function toolTipF(dobj:DisplayObject,s:String):void{
                      tooltip = new Tooltip();  // create a new Tooltip instance
                      tooltip.txt.text = s;  // assign the help text
                      ttObj.dobj=tooltip;
                      obj.addEventListener(MouseEvent.MOUSE_OVER,mouseRollOver);
                      obj.addEventListener(MouseEvent.MOUSE_OUT,mouseRollOut);
                      tooltip=ttObj.e.currentTarget
                          removeChild(ttObj.e.currentTarget);  // remove the tooltip on mouse out
