This was asked before but with no responses from Adobe, I will try my luck here:
This has happened since I updated to MacOS High Sierra (10.13.1), every time I choose Export Release Build the software crashes. However, making a debug build works fine.
I am set up for Android and iOS and I have exported multiple builds from this project before. I have Flash Builder 4.7 Premium with the creative cloud membership.
when the crash started happening, I updated my specs to Adobe Air 27, Flex SDK 4.6 (Air 27 overlay) and updated the compiler directives to:
-locale en_US
-swf-version=38
-use-network=true
but no luck.
I need to release my project before christmas, so, help?
thanks
I'm having the same problem - if it helps to diagnose, I'm trying to Export a release build for this repo: GitHub - cit-jmu/MediaViewer: Standalone desktop MediaViewer for MDID
Some crash details:
Process: Adobe Flash Builder 4.7 [61535]
Path: /Applications/Adobe Flash Builder 4.7/Adobe Flash Builder 4.7.app/Contents/MacOS/Adobe Flash Builder 4.7
Identifier: org.eclipse.eclipse
Version: 4.7 (4.7)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe Flash Builder 4.7 [61535]
Error:
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
Assertion failed: (backing->lock_access > 0), function CGSBackingStoreUnlockReader, file /BuildRoot/Library/Caches/com.apple.xbs/Sources/SkyLight/SkyLight-312.11/SkyLight/Services/Windows/CGSBackingStore.c, line 360.
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff5b05afce __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff5b198150 pthread_kill + 333
2 libsystem_c.dylib 0x00007fff5afb730a abort + 127
3 libsystem_c.dylib 0x00007fff5af7f360 __assert_rtn + 320
4 com.apple.SkyLight 0x00007fff54f11212 SLSUnlockWindowBackingStore + 124
5 com.apple.CoreGraphics 0x00007fff33cde905 CGSImageDataLockDevice + 442
6 com.apple.CoreGraphics 0x00007fff33d917f8 ripc_DrawWindowContents + 1297
7 com.apple.CoreGraphics 0x00007fff33d152d6 CGContextDelegateDrawWindowContents + 106
8 com.apple.SkyLight 0x00007fff5504df94 SLContextCopyWindowContentsToRect + 178
9 libswt-pi-cocoa-3738.jnilib 0x00000001178805ab Java_org_eclipse_swt_internal_cocoa_OS_CGContextCopyWindowContentsToRect + 345
10 ??? 0x000000010de7feee 0 + 4528275182
I gave up on Flash Builder for AIR/Flex Mobile development. Intellij IDEA is the way to go. I pulled all of my code over to it and with very few changes was able to get builds going. I haven't pushed a release yet, but I'm really liking it. I don't have time for Flash Builder. I have work to do. I'm not saying it's Adobe's fault. Could be all Apples fault, but I don't care at this point. I just need something that works.
Hi!
I did a clean install of High Sierra (17A405) and APFS on my SSD. Following the tutorial bellow and also adding "-Djava.util.Arrays.useLegacyMergeSort=true" to FB's .ini, did the job.
To export the Release Build, I'm using ADT (Command-line):
/Applications/Adobe\ Flash\ Builder\ 4.7/sdks/4.16.0_air_25/bin/adt -package -storetype pkcs12 -keystore /path_to_cert/cert.p12 -tsa "http://sha256timestamp.ws.symantec.com/sha256/timestamp" ~/Desktop/MyAirApp.air /path_to_project/bin-debug/MyAirApp-app.xml -C /path_to_project/bin-debug MyAirApp.swf any_aditional_folder_or_assets
* The tutorial does not work for Java 9;
* Some things of IDE related are a little buggy;
