3 Replies Latest reply on Dec 7, 2017 6:49 AM by NClif
    Child page form template errors
    NClif
      I first created a html page that I liked and then made a .dwt template from it to create other pages on site
      However I keep getting the following errors -see screenshots attached
      when i create child pages from template it says l am making change requires changing code that is locked - etc ...
      Further the template page I created adds a second bootstrap reference to code in the head
      <link rel="stylesheet" type="text/css" href="../bootstrap/3/css/bootstrap.min.css" />
      even if I delete it it keeps adding it back in - this causes my css to get overridden....
      Here is my code on the .dwt file
        • 1. Re: Child page form template errors
          BenPleysier Adobe Community Professional & MVP
          This message is often a red herring.  It usually means "oops, I have found an error on your page".  It may actually have NOTHING to do with editable or non-editable regions, and may in fact even refer to a CSS error rather than an HTML error.
          The first stop is the validator - does this page validate?
          • 2. Re: Child page form template errors
            NClif Level 1
            I did run validator and fixed a few obvious errors but a few left over - will try and fix them all and see if that clears it --- thanks for your reply
            • 3. Re: Child page form template errors
              NClif Level 1
              Problem Fixed. On further investigation we found that the following was our problem. Resolv
              As for your issue - there are two problems on your template:
              1. You have jquery includes in a non-ediatble region in the page head tags, please move them in an editable area named "head" inside the head tags as otherwise, when DW checks these files and they are not editable you get these errors.
              2. You have not turned off the "automatic file update" option in Bootstrap 3 options: Tools > Commands Bootstrap 3 Options.
