6 Replies Latest reply on May 9, 2008 1:19 PM by Newsgroup_User
    Coldfusion Structures Null Values
    apocalipsis19 Level 1
      Hi community!
      I am writing a report that breaks school down to Grade-Level - Ethnicity - Gender counts for students with more than 3 unlawful absences. I write a query, then I turned that query into a structure in the form:
      <cfset StudentListStruct=session.DBAccess.QueryToStruct(QuerySet=getTruancyCalculations, Grouping="GRADE_LEVEL,ETHNICITY,GENDER")/>
      QueryToStruct is a custom function that we created that turns any resultset in a structure. I am grouping my counts by Grade Level, Ethnicity then Gender. When I dump my structure I can see that for some grade levels one of the elements in my ethnicities is empty, null or whatever you want to call it.
      This is what I do to print:
      <cfif StructKeyExists(StudentListStruct[getUniqueGradeLevels.GRADE_LEVEL[y]],getUniqueEthniciti es.ETHNICITY[z])AND StructKeyExists(StudentListStruct,getUniqueGradeLevels.GRADE_LEVEL[y] AND getUniqueEthnicities.ETHNICITY[z] neq '')>
      #StudentListStruct[getUniqueGradeLevels.GRADE_LEVEL[y]][getUniqueEthnicities.ETHNICITY[z] ][getUniqueGenders.GENDER[looper]]#
      <cfelse>
      0
      </cfif>
      That code is enclosed 3 loops, one loop that loops throught he grade levels, one loop that loops through the ethnicities and one loop that loops through the genders. I am getting all zeros because my first condition is never being accomplished. I don't want that. I attached the code at the end of this message.
      Any thoughts?
      Thanks!
        • 1. Re: Coldfusion Structures Null Values
          Dan Bracuk Level 5
          I only read part of your code but my intitial thought is that you are overengineering something simple. If you want information about students with more than 3 absences, why not write a query that selects that data and then present it?
          • 2. Re: Coldfusion Structures Null Values
            Well, the school wants to show that data in a report broken down by grade level, ethnicity and gender.
            Any thoughts?
            • 3. Re: Coldfusion Structures Null Values
              -==cfSearching==- Level 4
              apocalipsis19 wrote:
              > Any thoughts?
              I agree. This seems like something that could be achieved much more easily done inside a sql query. I think you are over-complicating the code. Perhaps you are unfamiliar with sql, or are uncertain how to write a query that would produce those results. If you could post the structure of the pertinent tables, column names and relationships, others would be better able to assist you.
              • 4. Re: Coldfusion Structures Null Values
                Dan Bracuk Level 5
                quote:
                Any thoughts?
                start with
                select studentid, sex, race, grade, count(race) absents
                from some tables
                where your conditions are met
                group by studentid, sex, race, grade
                having count(race) >= 3
                • 5. Re: Coldfusion Structures Null Values
                  Thanks Dan! I worked my problem around. The problem is that I was dumping my structure. I forgot that the dump function automatically sorts the structure in a way that makes sense to the human eye to see on the screen. So I thought that I could manipulate my elements just the way I was looking at them. I was wrong. I sorted my structure and sub-structures using:
                  ListSort(StructKeyList(StudentListStruct)
                  This way I got a sorted list of elements. I was getting an exception because obviously I was referencing the wrong position of my data because my data was not organized as I thought it was. Once I sorted my data my problems disappeared. I just looped through my lists and verified the existence of the element then printed on screen otherwise prints zero.
                  My problem was not writing a query that group my counts in the form of GRADE LEVEL - ETHNICITY - GENDER, the problem was to layout those elements in an HTML table for printing. I thought it was more intelligent to use the power of structures here. So to print my elements I wrote:
                  <cfif StructKeyExists(StudentListStruct, x) AND StructKeyExists(StudentListStruct[x], y) AND StructKeyExists(StudentListStruct[x][y], z)>
                  #StudentListStruct[x][y][z].TOTALSTUDENTS#
                  <cfelse>
                  0
                  </cfif>
                  Where X represent an array of grade levels, Y represents an array of ethnicities and Z represents a list with two elements F and M for female and male.
                  Thanks to those who replied and helped! I really appreciate it!
                  Apocalipsis!
                  • 6. Re: Coldfusion Structures Null Values
                    Level 7
                    If you care to, you can replace that with the single structSort(...)
                    function. Which returns a list of keys sorted by the desired structure
                    element.
