4 Replies Latest reply on Dec 19, 2017 5:06 PM by JRAA
    Acrobat Reader DC, 64bit windows 10, StackHash_#### crashes
    JRAA
      Hi all,
      Our company has recently upgraded to windows 10, and we are seeing a large amount of crashes with Acrobat Reader DC.
      The crashes are repeatable on the Continuous Release - version 2018.009.20044
      The crashes are not tied to particular documents but occur at random, typically while users are opening and closing multiple documents.
      The fault module is consistently StackHash_####
      Searching the forums there are some old threads about StackHash, but I haven't been able to locate a fix.
      The install has been repaired, crashes persist.
      Version=1
      EventType=APPCRASH
      EventTime=131570775179703652
      ReportType=2
      Consent=1
      UploadTime=131570775183350183
      ReportIdentifier=82b5efd1-dadf-11e7-8bb9-f8633f4ef19b
      IntegratorReportIdentifier=3690d8fa-1ecc-43f1-8b10-ade633dc5a9d
      WOW64=1
      NsAppName=AcroRd32.exe
      AppSessionGuid=000032c0-0001-002f-53f0-649aeb6ed301
      TargetAppId=W:00069122786c41ef650bd4c12d9a1c6c8fb300000904!0000897f79d95a8c3d9e3a78830615f 1cee079bfafd2!AcroRd32.exe
      TargetAppVer=2017//11//04:20:06:42!22a6b5!AcroRd32.exe
      BootId=4294967295
      Response.BucketId=3eb474f9302376531fd4fb696037766b
      Response.BucketTable=1
      Response.LegacyBucketId=2293734540242810475
      Response.type=4
      Sig[0].Name=Application Name
      Sig[0].Value=AcroRd32.exe
      Sig[1].Name=Application Version
      Sig[1].Value=18.9.20044.55097
      Sig[2].Name=Application Timestamp
      Sig[2].Value=59fe1dd2
      Sig[3].Name=Fault Module Name
      Sig[3].Value=StackHash_0533
      Sig[4].Name=Fault Module Version
      Sig[4].Value=10.0.14393.1715
      Sig[5].Name=Fault Module Timestamp
      Sig[5].Value=59b0d8f3
      Sig[6].Name=Exception Code
      Sig[6].Value=c0000374
      Sig[7].Name=Exception Offset
      Sig[7].Value=PCH_38_FROM_ntdll+0x0006EB2C
      Any help would be greatly appreciated.
      Thanks!
      James
        • 1. Re: Acrobat Reader DC, 64bit windows 10, StackHash_#### crashes
          Adorobat Adobe Employee
          Hi James,
          Could you try installing the latest patch (18.009.20050) for Reader and check if that resolves the issue? To download the patch, click check for updates under help menu. You may also download the update manually using this link: 18.009.20050 Optional update, November 29, 2017 — Acrobat and Adobe Reader Release Notes
          Reboot the machine once and try again.
          Let us know if that helps.
          Shivam
          • 2. Re: Acrobat Reader DC, 64bit windows 10, StackHash_#### crashes
            JRAA Level 1
            Hi Shivam,
            I updated to 18.009.20050 and opened a bunch of pdf documents, I received a message that I had opened the maximum number of concurrent documents, closed a few, opened few more and browsed around. This seemed to be better performance.
            I exited Adobe Reader, and selected close all documents. Adobe began closing each tab, however before finishing I got the "(not responding)" message in the title bar for a few moments then Adobe crashed.
            Looking at Windows Error Reporting logs shows the stackhash error once again.
            Version=1
            EventType=APPCRASH
            EventTime=131574291061801912
            ReportType=2
            Consent=1
            UploadTime=131574291065434242
            ReportIdentifier=1d98d5fa-de12-11e7-8bb9-f8633f4ef19b
            IntegratorReportIdentifier=fb341e58-c636-47f0-a83a-766f9c9cf783
            WOW64=1
            AppSessionGuid=000001c0-0001-002f-29cb-f3e51d72d301
            TargetAppId=W:00066861560bb7e3985e0bd61e0e9257c86200000904!000014c10eb00e59cb9407b94a4a119 636cead1cb4dc!AcroRd32.exe
            TargetAppVer=2017//11//27:20:21:25!2281e6!AcroRd32.exe
            BootId=4294967295
            1. Response.BucketId=09b0e719eb8c08a02d6815f782dc42d9
            2. Response.BucketTable=1
            3. Response.LegacyBucketId=2118967777474396889
            4. Response.type=4
            Sig[1].Value=18.9.20050.57426
            Sig[2].Value=5a1c73c5
            Sig[3].Value=StackHash_560e
            DynamicSig[1].Name=OS Version
            DynamicSig[1].Value=10.0.14393.2.0.0.256.125
            DynamicSig[2].Name=Locale ID
            DynamicSig[2].Value=3081
            DynamicSig[22].Name=Additional Information 1
            DynamicSig[22].Value=560e
            DynamicSig[23].Name=Additional Information 2
            DynamicSig[23].Value=560e23789839283ed968ed4d135072a3
            DynamicSig[24].Name=Additional Information 3
            DynamicSig[24].Value=64f4
            DynamicSig[25].Name=Additional Information 4
            DynamicSig[25].Value=64f45f43c5431d710138e329c5125774
            UI[2]=C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AcroRd32.exe
            Kind regards,
            James
            • 3. Re: Acrobat Reader DC, 64bit windows 10, StackHash_#### crashes
              Thanks for the information, James.
              Please try following troubleshooting steps:
              1- Uninstall Reader using cleaner tool which you can download from here: Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs
              2- Reboot the machine,
              3- Download Reader DC from here: Adobe - Adobe Acrobat Reader DC Distribution
              4- Reboot the machine and try again.
              Keep us posted with the results.
              Shivam
              • 4. Re: Acrobat Reader DC, 64bit windows 10, StackHash_#### crashes
                JRAA Level 1
                Hi Shivam,
                I've run the cleaner and reinstalled.
                I put adobe reader dc through it's paces and didn't notice a crash, however looking at my event logs I can see the cleaner application reported a crash which isn't too encouraging. I will deploy this to one of our impacted users to see if they see any improvement.
                Version=1
                EventType=APPCRASH
                EventTime=131582043762128206
                ReportType=2
                Consent=1
                UploadTime=131582043765309466
                ReportIdentifier=2edd3567-e51f-11e7-8bbf-f8633f4ef19b
                IntegratorReportIdentifier=902e622f-ffbe-4eae-bddf-cdc6e06cdf61
                WOW64=1
                NsAppName=AdobeAcroCleaner_DC2015.exe
                AppSessionGuid=00002374-0001-0035-25fd-93c52b79d301
                TargetAppId=W:000698c5a26fe66a4427e9e996335239b99a00000904!000095e1746b53edb3fca3db0f1de01 f6a215730304b!AdobeAcroCleaner_DC2015.exe
                TargetAppVer=2015//07//03:02:47:00!22bd16!AdobeAcroCleaner_DC2015.exe
                BootId=4294967295
                Response.BucketId=c5e964f48ea65d5969c85585b93adfc0
                Response.LegacyBucketId=109136295072
                Response.type=4
                Sig[0].Value=AdobeAcroCleaner_DC2015.exe
                Sig[1].Value=4.0.0.15957
                Sig[2].Value=5595f7a4
                Sig[3].Value=StackHash_eace
                Sig[7].Value=PCH_24_FROM_ntdll+0x0006EB2C
