0 Replies Latest reply on Dec 7, 2017 1:11 AM by evae65336835
    CA - radial pressing together
    evae65336835 Level 1
      Hi!
      I have a feature request that would be a lot time saving, and make it possible to do more with a single character without the need to draw extra.
      When you push a rectangle you equally change the graphic in one direction. I would like that the graphic is changed radially around a fixed pin when you drag around it. For example if I have a wide open spanish fan and want to close that a little, then the graphic would change radially around the fixed point. Other uses could be for example an angel spreading its wings.
      To get it nice now you can't have too much and too wide "content" in for example an arm. I would have a solution for when you have content there, between arm and body for example, like angel, bat etc.
      Maybe this feature could be used to make nice motion blur also?
      Thanks!
