9 Replies Latest reply on Dec 8, 2017 3:37 AM by Laubender
    How do I convert manual endnotes to InDesign 2018 endnotes
    matts2619583
      Hi there
      Hopefully someone can help. I have a long document with over 370 references which I imported from a couple of Word documents. All the endnotes are essentially manual entries superscript entries - though there are no other superscript entries other than the place and they are in assorted text boxes.
      Basically I'm looking for a way to automatically convert the superscript text and manual endnotes into the new InDesign endnotes format. I'm going to have to do some fairly major edits on the document and this would make life so much easier.
      Does anyone know if this is possible? I've found https://indesignsecrets.com/topic/superscript-numbers-to-footnotes and https://forums.adobe.com/external-link.jspa?url=http%3A%2F%2Fwww.kahrel.plus.com%2Findesig n%2Ffootnote_endnote_conversio…  but I don't think either of these will quite do what I'm looking for. The first one ran an error and now won't do anything and the second only works for InDesign endnotes/footnotes.
      Hopefully someone can help, either to do everything automatically or at the very least tell me how I can batch convert a manual superscript into an inserted footnote which I can then copy and paste the reference text into.
      Thanks in advance
      Matt
        • 1. Re: How do I convert manual endnotes to InDesign 2018 endnotes
          amaarora Adobe Employee
          Can you reimport the word file in the document while working with CC 2018?
          What do you mean by manual endnotes? is it footnotes acting as endnotes?
          -Aman
          • 2. Re: How do I convert manual endnotes to InDesign 2018 endnotes
            for this task you need a custom script that is able to gather all your faked endnote numbers plus the corresponding texts and will create real endnotes in InDesign. Such a script is not written yet, I guess. So you have to pay a scripter to do that. Don't know if it's worth the effort for only 370 references. But if this task comes more often the amount of money you have to spend could pay off.
            How do want your endnotes be positioned:
            Endnotes per story?
            Endnotes per document?
            How do you want your endnotes be numbered:
            Should numbering continue throughout the document or should it restart with every story?
            Just to make that clear:
            A story can consist of one single text frame (or text path) or can be constructed out of many text frames threaded together.
            You cannot have renumbering in a single story.
            And you have to know, that you cannot have the endnote's texts in the same story with the text that has the endnote reference numbers. The endnote's texts is always a separate text frame or a couple of threaded text frames that is either positioned automatically on an extra page just after the last text frame of a story or on an extra page at the end of the document.
            FWIW: Jongware's script:
            Re: Loosing Footnotes when placing word in InDesign
            is from 2013 and is not what you need with InDesign CC 2018's brand new endnote feature.
            And Peter Kahrel's script requires real footnotes:
            Footnote–endnote conversion (CC2018+) | Peter Kahrel
            Regards,
            Uwe
            • 3. Re: How do I convert manual endnotes to InDesign 2018 endnotes
              matts2619583 Level 1
              Hi Uwe (and everyone else)
              I think I probably agree - it's probably not going to be the simplest job. To answer your questions:
              How do want your endnotes be positioned?... Endnotes per document
              How do you want your endnotes be numbered? numbering to continue throughout the document
              In answer to others questions, it's a long document made up of multiple Word documents including illustrations that have since been edited in InDesign so sadly I can't reimport from Word easily.
              I'm happy I can do this manually if there isn't a script (well, not happy... more resigned!). My main question now is: is there a way to automate inserting blank endnotes into the document using a find and replace function? It's a bit of a pain to insert with keyboard shortcut and then return to reference via right hand click. I was thinking it would be easier to have all the numbers automatically replaced as endnotes and then I just have to double check the numbers, then just cut and paste the endnotes all in one go at the end, comparing it my original document rather than jumping about all over the place.
              Thanks for all your help
              Matt
              • 4. Re: How do I convert manual endnotes to InDesign 2018 endnotes
                Obi-wan Kenobi Level 5
                If you know where and how is defined each note call and where and how is defined each note, so, it's simple!
                … and you'll need a script!
                [Such a script is not proposed for free because I think such a gratuity no longer values scripters' real work and knowledge, as it may have been the case by the past!]
                • 5. Re: How do I convert manual endnotes to InDesign 2018 endnotes
                  Laubender  wrote
                  .. FWIW: Jongware's script:
                  So why not use my script to convert the fake endnotes to real footnotes, followed by Peter's to convert these footnotes to "live" endnotes?
                  • 6. Re: How do I convert manual endnotes to InDesign 2018 endnotes
                    Hi Jongware,
                    I may be wrong, but I think, that Matt—our OP—had an error message with your script:
                    So it would be wise to see what kind of error this was.
                    Regards,
                    Uwe
                    • 7. Re: How do I convert manual endnotes to InDesign 2018 endnotes
                      Ah, he already tried it. Well... my script will only work if there is exactly one superscript number for each separate end note, and if that is not the case then any other script surely wont work either.
                      The error message may help in determining what to fix (in the document).
                      • 8. Re: How do I convert manual endnotes to InDesign 2018 endnotes
                        Thanks everyone. I had another go this morning (UK time zone) and got it all working. To give you a quick run-through:
                        I restarted InDesign 2018 with a fresh backup version of my file. @Jongware’s script then ran correctly. However I had a message that said it was failing part way through the document due mismatched number of superscripts and references.
                        I worked out that all the frames needed linking for the whole document before the script would run all the way through  - I had some orphan frames for tables etc. I also found a typos of two on the superscripts so double checked that all the numbers ran in sequence using the find superscript option in the Find search box.
                        I also worked out that the cursor needed to be at the beginning of the document otherwise it would again fail as it wouldn’t find all the superscript references - it only goes forwards. Obvious in hindsight I guess!
                        Every page then had footnotes on it. Interestingly the references started at 315. I left it as that and then ran Peter Kahrel’s script which also worked brilliantly. Moved this now endnote frame to where I wanted it and linked additional frames until all references were included. I did have to run it twice as I’d forgotten to set the various styles etc. in Endnote settings.
                        Brilliant that InDesign now has this feature and that it is actually possible to move all the manual endnote superscripts and references into this new format using Scripts.
                        Thanks so much for all your help! Hope the outline is helpful for others looking to do the same.
                        Next question is around automatically converting hyperlinks specifically for references as they’ve all disappeared. However I think this is best in a new correctly classified post.
                        • 9. Re: How do I convert manual endnotes to InDesign 2018 endnotes
                          Aha. Now, I think that at least one of this issues in the document was discussed briefly in the thread where Jongware's script is discussed in details.
                          Regards,
                          Uwe
