2 Replies Latest reply on Dec 7, 2017 2:14 PM by michaelw45185501
    Group Photo Legend
    michaelw45185501 Level 1
      Is is possible to make a photo legend like the one below in Adobe Elements?
      Image result for group photo legend
      Message was edited by: Moderator (Discussion successfully moved from Adobe Digital Classroom: Discussion Forum to Photoshop Elements)
        • 1. Re: Group Photo Legend
          MichelBParis Adobe Community Professional & MVP
          Let us divide the problem in several parts:
          - creating the list of people with the 6 colums: I would use a text editor like Word. The result can be pasted later on the upper part of a canvas, the bottom will receive the drawing.
          - Creating the 'silhouettes' (contours) for the persons in the group. I can't see a way to do that automatically. If you don't redraw manually, you can perhaps create a 'contour' effect from the various filters available in Elements.
          - Adding the numbers... each number on its own text layer; possible to merge layers by smaller batches to avoid 200 layers.
          I have done such group images (under 50 persons).
          If you really have nearly 200 persons, that's really a big job!
          • 2. Re: Group Photo Legend
            Thank you for the advice.  I don't have that many, it was just an example I found online.  I will try using the filters.
