9 Replies Latest reply on May 6, 2008 6:38 AM by tookiebunten
    Date and Time
    tookiebunten Level 1
      Hi
      Is there an easy way to display the users system time and date?
        • 1. Re: Date and Time
          jylaxx Level 1
          date = new Date() ;
          then format the date object with DateFormatter if necessary.
          add a label to the stage and set the text property.
          Is that your question ?
          • 2. Re: Date and Time
            Hi
            Sorry for being dump but I'm new to flex and actionscript have only been using it for about 3 weeks and haven't had a course yet. How do I use that and does it also show the time and will it update on its own?
            • 3. Re: Date and Time
              jylaxx Level 1
              Well try first without the DateFormatter, just set the text property of the Label to date.toString().
              To refresh the value you have to use a Timer and update the date in the TIMER event. To get the new date just recreate a new Date object.
              If all is working then look at the documentationi about DateFormatter.
              • 4. Re: Date and Time
                I'm getting the date displayed ok but I'm struggling to get a formatter to work can you check my code and tell me where I'm going wrong?
                I'm probably doing something silly thanks
                • 5. Re: Date and Time
                  jylaxx Level 1
                  the wrong code is not here. What you post is correct. But I don't know where you call the formatDisplayTime method ???
                  • 6. Re: Date and Time
                    This is my full code. Be nice I'm just learning and the code might be all other the place. Thanks for having a look.
                    • 7. Re: Date and Time
                      jylaxx Level 1
                      OK !
                      1- You never call formatDisplayTime.
                      2- dateTime is defined once at the creation of the application and then it doesn't change. Making this variable bindable is useless.
                      You have to use a timer as I told you :
                      (1) Add this code
                      [Bindable]
                      private var strNow : String ;
                      private var timer : Timer ;
                      /*private var dateTime:Date = new Date();
                      private function formatDisplayTime(item:Date):String
                      return timeDisplayFormatter.format(item);
                      private function init() : void
                      murdochRoomData.send() ;
                      edisonRoomData.send() ;
                      monierRoomData.send() ;
                      bellRoomData.send() ;
                      timer = new Timer( 1000 ) ;
                      timer.addEventListener( TimerEvent.TIMER, onTimer ) ;
                      timer.start() ;
                      private function onTimer( event : TimerEvent ) : void
                      strNow = timeDisplayFormatter.format( new Date() ) ;
                      (2) Call the init() function in the Application.creationComplete event : creationComplete="init();"
                      (3) Replace the label binding : <mx:Label text="{strNow}" fontWeight="bold"/>
                      That's all !
                      • 8. Re: Date and Time
                        jylaxx Level 1
                        Well I keep binding as example, but it is not necessary in this case.
                        Add an id to the date-time label and set the text property of the label in the onTimer event :
                        dateTimeLabel.text = timeDisplayFormatter.format( new Date() ) ;
                        <mx:Label id="dateTimeLabel" fontWeight="bold"/>
                        • 9. Re: Date and Time
                          thanks
                          for that
